Home » Eclipse Projects » JavaServer Faces » A quick question on the tutorial - New JSF Project Not displayed
A quick question on the tutorial - New JSF Project Not displayed [message #475200] |
Mon, 19 November 2007 03:57  |
Im doing the tutorial on:
http://www.eclipse.org/webtools/jsf/docs/tutorial/JSFTools_1 _0_tutorial.html
And I don't get the New JSF Project option.
I think I have installed everything correctly.
Config Details below. . . .
Any clues?
Stu
*** Date: Monday, 19 November 2007 7:56:59 PM Sydney (Australia)
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20071023-1652
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\apps\jsf_assessment\eclipse\\plugins\org.eclipse.platform _3.3.2.R33x_v20071022\splash.bmp
-launcher
C:\apps\jsf_assessment\eclipse\eclipse.exe
-name
Eclipse
--launcher.library
C:\apps\jsf_assessment\eclipse\plugins\org.eclipse.equinox.l auncher.win32.win32.x86_1.0.2.R331_v20071019\eclipse_1021.dl l
-startup
C:\apps\jsf_assessment\eclipse\plugins\org.eclipse.equinox.l auncher_1.0.1.R33x_v20070828.jar
-vm
C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1195461270593
eclipse.vm=C:\Program Files\Java\jre1.6.0_03\bin\client\jvm.dll
eclipse.vmargs=-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-XX:MaxPermSize=256M
-Djava.class.path=C:\apps\jsf_assessment\eclipse\plugins\org .eclipse.equinox.launcher_1.0.1.R33x_v20070828.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\apps\jsf_assessment\eclipse\plugins\org.e clipse.equinox.launcher_1.0.1.R33x_v20070828.jar
java.class.version=50.0
java.endorsed.dirs=C:\Program Files\Java\jre1.6.0_03\lib\endorsed
java.ext.dirs=C:\Program
Files\Java\jre1.6.0_03\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
java.home=C:\Program Files\Java\jre1.6.0_03
java.io.tmpdir=C:\DOCUME~1\STUART~1\LOCALS~1\Temp\
java.library.path=C:\apps\jsf_assessment\eclipse;.;C:\WINDOW S\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\Program
Files\Java\jre1.6.0_03\bin\client;C:\Program
Files\Java\jre1.6.0_03\bin;C:\Program Files\PC Connectivity
Solution\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32 \Wbem;C:\Program
Files\Microsoft SQL Server\80\Tools\Binn\;C:\Program
Files\UltraEdit;C:\Program Files\Common Files\Ulead Systems\MPEG;c:\Program
Files\Microsoft SQL Server\90\Tools\binn\;C:\Program
Files\QuickTime\QTSystem\
java.runtime.name=Java(TM) SE Runtime Environment
java.runtime.version=1.6.0_03-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.6
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.6.0_03
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.6.0_03-b05
line.separator=
org.apache.commons.logging.Log=org.apache.commons.logging.im pl.SimpleLog
org.apache.commons.logging.simplelog.log.httpclient.wire.hea der=off
org.apache.commons.logging.simplelog.log.org.apache.commons. httpclient=off
org.eclipse.equinox.launcher.splash.location=C:\apps\jsf_ass essment\eclipse\\plugins\org.eclipse.platform_3.3.2.R33x_v20 071022\splash.bmp
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5,Ja vaSE-1.6
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activation,javax.activity,javax.annotation,javax.annotation .processing,javax.crypto,javax.crypto.interfaces,javax.crypt o.spec,javax.imageio,javax.imageio.event,javax.imageio.metad ata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,jav ax.imageio.spi,javax.imageio.stream,javax.jws,javax.jws.soap ,javax.lang.model,javax.lang.model.element,javax.lang.model. type,javax.lang.model.util,javax.management,javax.management .loading,javax.management.modelmbean,javax.management.monito r,javax.management.openmbean,javax.management.relation,javax .management.remote,javax.management.remote.rmi,javax.managem ent.timer,javax.naming,javax.naming.directory,javax.naming.e vent,javax.naming.ldap,javax.naming.spi,javax.net,javax.net. ssl,javax.print,javax.print.attribute,javax.print.attribute. standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.r mi.ssl,javax.script,javax.security.auth,javax.security.auth. callback,javax.security.auth.kerberos,javax.security.auth.lo gin,javax.security.auth.spi,javax.security.auth.x500,javax.s ecurity.cert,javax.security.sasl,javax.sound.midi,javax.soun d.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax .sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rows et.spi,javax.swing,javax.swing.border,javax.swing.colorchoos er,javax.swing.event,javax.swing.filechooser,javax.swing.pla f,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing. plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.sw ing.text,javax.swing.text.html,javax.swing.text.html.parser, javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax .tools,javax.transaction,javax.transaction.xa,javax.xml,java x.xml.bind,javax.xml.bind.annotation,javax.xml.bind.annotati on.adapters,javax.xml.bind.attachment,javax.xml.bind.helpers ,javax.xml.bind.util,javax.xml.crypto,javax.xml.crypto.dom,j avax.xml.crypto.dsig,javax.xml.crypto.dsig.dom,javax.xml.cry pto.dsig.keyinfo,javax.xml.crypto.dsig.spec,javax.xml.dataty pe,javax.xml.namespace,javax.xml.parsers,javax.xml.soap,java x.xml.stream,javax.xml.stream.events,javax.xml.stream.util,j avax.xml.transform,javax.xml.transform.dom,javax.xml.transfo rm.sax,javax.xml.transform.stax,javax.xml.transform.stream,j avax.xml.validation,javax.xml.ws,javax.xml.ws.handler,javax. xml.ws.handler.soap,javax.xml.ws.http,javax.xml.ws.soap,java x.xml.ws.spi,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w 3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom. ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.4.0
org.osgi.supports.framework.extension=true
org.osgi.supports.framework.fragment=true
org.osgi.supports.framework.requirebundle=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\apps\jsf_assessment\eclipse\configuratio n\org.eclipse.osgi\bundles
osgi.compatibility.bootdelegation=true
osgi.configuration.area=file:/C:/apps/jsf_assessment/eclipse /configuration/
osgi.framework=file:/c:/apps/jsf_assessment/eclipse/plugins/ org.eclipse.osgi_3.3.1.R33x_v20070828.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.3.1.R33x_v20070828
osgi.install.area=file:/C:/apps/jsf_assessment/eclipse/
osgi.instance.area=file:/C:/apps/jsf_assessment/workspace_js f_assessment/
osgi.instance.area.default=file:/C:/Documents and Settings/Stuart
Plummer/workspace/
osgi.logfile=C:\apps\jsf_assessment\workspace_jsf_assessment \.metadata\.log
osgi.manifest.cache=C:\apps\jsf_assessment\eclipse\configura tion\org.eclipse.osgi\manifests
osgi.nl=en_AU
osgi.os=win32
osgi.splashLocation=C:\apps\jsf_assessment\eclipse\\plugins\ org.eclipse.platform_3.3.2.R33x_v20071022\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\apps\jsf_assessment\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program
Files\Java\jre1.6.0_03\lib\resources.jar;C:\Program
Files\Java\jre1.6.0_03\lib\rt.jar;C:\Program
Files\Java\jre1.6.0_03\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.6.0_03\lib\jsse.jar;C:\Program
Files\Java\jre1.6.0_03\lib\jce.jar;C:\Program
Files\Java\jre1.6.0_03\lib\charsets.jar;C:\Program
Files\Java\jre1.6.0_03\classes
sun.boot.library.path=C:\Program Files\Java\jre1.6.0_03\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=AU
user.dir=C:\apps\jsf_assessment\eclipse
user.home=C:\Documents and Settings\Stuart Plummer
user.language=en
user.name=Stuart Plummer
user.timezone=Australia/Sydney
user.variant=
*** Features:
org.eclipse.cvs (1.0.1.R33x_r20070802-7C79_9_KKG-mDM9e3H5D) "Eclipse CVS
Client"
org.eclipse.datatools.connectivity.feature (1.5.1.200709261) "Data Tools
Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature (1.5.1.200709261)
"DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.5.1.200709261) "DTP Open
Data Access"
org.eclipse.datatools.doc.user (1.5.1.200710161) "Data Tools Platform User
Guide"
org.eclipse.datatools.enablement.apache.derby.feature (1.5.1.200709261)
"High-level Sybase Enablement Plug-in"
org.eclipse.datatools.enablement.feature (1.5.1.200709261) "Eclipse Data
Tools Platform Enablement"
org.eclipse.datatools.enablement.hsqldb.feature (1.5.1.200709261) "Eclipse
Data Tools Platform Enablement"
org.eclipse.datatools.enablement.ibm.feature (1.5.1.200709261) "Eclipse Data
org.eclipse.datatools.enablement.jdbc.feature (1.5.1.200709261) "High-level
org.eclipse.datatools.enablement.msft.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.mysql.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.oda.designer.feature (1.5.1.200709261)
"Eclipse Data Tools Platform XML ODA Designer"
org.eclipse.datatools.enablement.oda.feature (1.5.1.200709261) "Eclipse Data
Tools Platform XML ODA Runtime Driver"
org.eclipse.datatools.enablement.oracle.feature (1.5.1.200709261) "Eclipse
org.eclipse.datatools.enablement.postgresql.feature (1.5.1.200709261)
"Eclipse Data Tools Platform Enablement"
org.eclipse.datatools.enablement.sybase.feature (1.5.1.200709261)
org.eclipse.datatools.modelbase.feature (1.5.1.200709261) "Eclipse Data
Tools Platform SQLModel Plug-in"
org.eclipse.datatools.sqldevtools.feature (1.5.1.200709261) "Eclipse Data
Tools Platform SQL Tools Common UI Plug-in"
org.eclipse.emf (2.3.1.v200709252135) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.3.1.v200709252135) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.3.1.v200709252135) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.3.0.v200709252135) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.3.0.v200709252135) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.3.0.v200709252135) "EMF Common"
org.eclipse.emf.common.ui (2.3.1.v200709252135) "EMF Common UI"
org.eclipse.emf.converter (2.3.1.v200709252135) "EMF Model Convert Support"
org.eclipse.emf.ecore (2.3.1.v200709252135) "EMF Ecore"
org.eclipse.emf.ecore.edit (2.3.0.v200709252135) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.3.1.v200709252135) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.3.0.v200709252135) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.edit (2.3.1.v200709252135) "EMF Edit"
org.eclipse.emf.edit.ui (2.3.1.v200709252135) "EMF Edit UI"
org.eclipse.emf.mapping (2.3.0.v200709252135) "EMF Mapping "
org.eclipse.emf.mapping.ecore (2.3.0.v200709252135) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore"
org.eclipse.emf.mapping.ecore.editor (2.3.0.v200709252135) "Eclipse Modeling
Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
org.eclipse.emf.mapping.ui (2.3.0.v200709252135) "EMF Mapping UI"
org.eclipse.gef (3.3.1.v20070814) "Graphical Editing Framework"
org.eclipse.jdt (3.3.1.r331_v20070629-7o7jE72EDlXAbqAcnbmyg1rf8RIL) "Eclipse
Java Development Tools"
org.eclipse.jem (1.2.4.v200704181020--6zXJK0L0SE3a95) "Java EMF Model"
org.eclipse.jpt.feature.source (1.0.1.v200709130000-77-5CYQCCz-D7LQCCCD)
"Dali Java Persistence API (JPA) Tools"
org.eclipse.jst (2.0.1.v200709110510-7B-68dDTNImaz0di_Tvks1JyDPVe) "J2EE
Standard Tools (JST)"
org.eclipse.jst.common_core.feature.source
(2.0.0.v200706041905-1007w311817231426) "J2EE Standard Tools - Common Core
Source"
org.eclipse.jst.enterprise_core.feature.source
(2.0.1.v200709130705-42Aq_kE77Y7gBHDE77) "J2EE Standard Tools - Enterprise
Core Source"
org.eclipse.jst.enterprise_ui.feature.source
(2.0.1.v200709130705-7b7_ErsEU6AXKM4z-H2OSyjeRYcY) "J2EE Standard Tools -
Enterprise UI Source"
org.eclipse.jst.sdk (2.0.1.v200709110510-7F-788fNWpoJCFladAFBfkeXa3lR) "J2EE
org.eclipse.jst.server_adapters.feature.source
(2.0.1.v200709110550-787KE8gDUUEF6F_KxpHEQ) "J2EE Standard Tools - Server
Adapters Source"
org.eclipse.jst.server_core.feature.source
(2.0.1.v200709110550-56CQ9rC7EK_UAblGAD2537) "J2EE Standard Tools - Server
Core Source"
org.eclipse.jst.server_ui.feature.source
(2.0.1.v200709110550-77-CR9yJXEkuiKVeQrclqTHQ3648) "J2EE Standard Tools -
Server UI Source"
org.eclipse.jst.web_core.feature.source
(2.0.200.v200709122200-7Q7AE7BEHhHegvh89ftNyC) "J2EE Standard Tools - Web
Core Source"
org.eclipse.jst.web_ui.feature.source
(2.0.1.v200709110605-7B1COCkuNa_RHevwkwAwi9_guOz-) "J2EE Standard Tools -
Web UI Source"
org.eclipse.jst.webpageeditor.feature.source
(1.0.1.v200709110605-3-29oA55P5V8A) "Web Page Editor Source"
org.eclipse.mylyn_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.bugzilla_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.context_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.ide_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.java_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.mylyn.pde_feature (2.1.0.v20070927-0900) "Mylyn"
org.eclipse.pde (3.3.2.R33x_r20071022-7N7M4CYWLBCz-yHkMIuHN) "Eclipse
Plug-in Development Environment"
org.eclipse.platform (3.3.2.R33x_v20071022-_19UEksF-G8Yc6bUv3Dz) "Eclipse
Platform"
org.eclipse.rcp (3.3.2.R33x_r20071022-8y8eE9CEV3FspP8HJrY1M2dS) "Eclipse
RCP"
org.eclipse.wst (2.0.1.v200709110510-7C-778k0JWNr93WEIHvplSVojWel) "Web
Standard Tools (WST)"
org.eclipse.wst.common_core.feature.source
(2.0.1.v200709110622-7C78EKGE_EkMNfNleyerlz) "Web Standard Tools - Common
Core Source"
org.eclipse.wst.common_ui.feature.source
(2.0.1.v200709110622-7C5EH2E9RvTVnijrspVz0bgOmfz-) "Web Standard Tools -
Common UI Source"
org.eclipse.wst.sdk (2.0.1.v200709110510-7E-788aNUivSRfjWLEcbxlUXG72x) "Web
org.eclipse.wst.server_core.feature.source
(2.0.1.v200709110637-2-CM8s733G3G5Jc) "Web Standard Tools - Server Core
Source"
org.eclipse.wst.server_ui.feature.source
(2.0.1.v200709110637-77-CU9vCXCjvdHL7ATINi447) "Web Standard Tools - Server
UI Source"
org.eclipse.wst.web_core.feature.source
(2.0.1.v200709111200-42CK_kE77Y7ZBNCQGG) "Web Standard Tools - Web Core
Source"
org.eclipse.wst.web_ui.feature.source
(2.0.1.v200709111200-7A0EAiCiWfGJsJZlAhE3TMaQW) "Web Standard Tools - Web UI
Source"
org.eclipse.wst.ws_core.feature.source
(2.0.1.v200709051445-7E7KEB0EC3wSU4Tuh9iKz) "Web Standard Tools - Web
Service Core Source"
org.eclipse.wst.ws_ui.feature.source
(2.0.1.v200709051445-791ECFAufYO8Az-ajoKBCFe8tVjL) "Web Standard Tools - Web
Service UI Source"
org.eclipse.wst.xml_core.feature.source
(2.0.1.v200709110650-787BE_1CYQCCz-CvRQLQSV) "Web Standard Tools - XML Core
Source"
org.eclipse.wst.xml_ui.feature.source
(2.0.1.v200709110650-7A1ECGCnbckz0bnr5wCp8KNAjipR) "Web Standard Tools - XML
UI Source"
org.eclipse.xsd (2.3.1.v200709252135) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.edit (2.3.0.v200709252135) "XML Schema Edit Framework"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Starting]
com.ibm.icu (3.6.1.v20070906) "International Components for Unicode for Java
(ICU4J)" [Active]
com.jcraft.jsch (0.1.31) "JSch" [Resolved]
com.sysdeo.eclipse.tomcat (3.2.1) "Tomcat Plugin" [Starting]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
javax.wsdl (1.4.0.v200706111329) "WSDL4J" [Resolved]
javax.wsdl15 (1.5.1.v200705290614) "WSDL4J" [Resolved]
javax.xml.rpc (1.1.0.v200706111329) "JAX-RPC" [Resolved]
javax.xml.soap (1.2.0.v200706111329) "SAAJ" [Resolved]
org.apache.ant (1.7.0.v200706080842) "Apache Ant" [Resolved]
org.apache.axis (1.4.0.v200706191647) "Apache Web Services" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in" [Starting]
org.apache.commons_logging (1.0.4.v200608011657) "Apache commons logging
Plug-in" [Resolved]
org.apache.commons.discovery (0.2.0.v200706111329) "Jakarta-Commons
Discovery" [Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.jakarta_log4j (1.2.8.v200607172048) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.log4j (1.2.13.v200706111418) "Apache Jakarta log4j Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene Analysis"
[Resolved]
org.apache.wsil4j (1.0.0.v200706111329) "WSIL4J" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.apache.xml.resolver (1.1.0.v200705310020) "Apache XmlResolver"
[Resolved]
org.eclipse.ant.core (3.1.200.v20070522) "Ant Build Tool Core" [Starting]
org.eclipse.ant.ui (3.2.200.v20070825_r331) "Ant UI" [Active]
org.eclipse.compare (3.3.1.r33x_20070906) "Compare Support" [Active]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Starting]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.databinding (1.0.1.M20070822-0800) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.1.M20070910-0800b) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.3.1.r331_v20070829) "File Buffers" [Active]
org.eclipse.core.filesystem (1.1.0.v20070606) "Core File Systems" [Starting]
org.eclipse.core.filesystem.win32.x86 (1.1.0.v20070510) "Core File System
for Windows" [Resolved]
org.eclipse.core.jobs (3.3.1.R33x_v20070709) "Eclipse Jobs Mechanism"
[Active]
org.eclipse.core.net (1.0.1.r33x_20070709) "Internet Connection Management"
[Active]
org.eclipse.core.resources (3.3.0.v20070604) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.100.v20070502) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.3.0.v20070226) "Core Resource Management
Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.200.v20070502) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.100.v20070316) "Eclipse
Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.2.0.v20070426) "Core Variables" [Starting]
org.eclipse.cvs (1.0.0.v20070606) "Eclipse CVS Client" [Starting]
org.eclipse.datatools.connectivity (1.0.1.200709061) "Data Tools Platform
Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.derby (1.0.0.200706071) "Eclipse Data
Tools Platform Apache Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic (1.0.0.200706071) "Eclipse
Data Tools Platform Generic DB Connectivity Plug-in" [Starting]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.1.200708201) "Eclipse
Data Tools Platform Generic DB UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.derby (1.0.0.200706071)
"Eclipse Data Tools Platform Apache Derby Database Definition" [Starting]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.0.200706071) "Eclipse Data Tools Platform DBDefinition Generic JDBC
Plug-in" [Starting]
org.eclipse.datatools.connectivity.derby (1.0.0.200706071) "Eclipse Data
Tools Platform Derby Plug-in" [Starting]
org.eclipse.datatools.connectivity.derby.ui (1.0.0.200706071) "Eclipse Data
Tools Platform Apache Derby UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda (3.1.0.200708161) "DTP Open Data
Access" [Starting]
org.eclipse.datatools.connectivity.oda.consumer (3.1.1.200708221) "DTP ODA
Consumer Helper Component Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.design (3.0.5.200709071) "DTP ODA
Design Session Model" [Starting]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.5.200709071) "DTP ODA
Designer UI Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.4.200706071) "Eclipse
Data Tools Platform Flat File ODA Runtime Driver" [Starting]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.5.200707301)
"Eclipse Data Tools Platform Flat File ODA Designer" [Starting]
org.eclipse.datatools.connectivity.oda.profile (3.0.5.200708131) "DTP ODA
Connection Profile Framework Plug-in" [Starting]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.5.200707301) "DTP
ODA New Plug-in Template Wizard" [Starting]
org.eclipse.datatools.connectivity.sqm.core (1.0.1.200709071) "Eclipse Data
Tools Platform SQM Core Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.core.ui (1.0.1.200708201) "Eclipse
Data Tools Platform SQM UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui (1.0.0.200706071) "Eclipse Data
Tools Platform FE UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.fe.ui.actions (1.0.0.200706071)
"Eclipse Data Tools Platform FE Ui Actions Plug-in" [Starting]
org.eclipse.datatools.connectivity.sqm.server.ui (1.0.0.200709141) "Eclipse
Data Tools Platform Server UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui (1.0.1.200708231) "Data Tools Platform
Connectivity UI Plug-in" [Starting]
org.eclipse.datatools.connectivity.ui.dse (1.0.1.200709171) "Eclipse Data
Tools Platform Data Source Explorer Plug-in" [Starting]
org.eclipse.datatools.doc.user (1.0.0.200706071) "Data Tools Platform User
Guide" [Starting]
org.eclipse.datatools.enablement.finfo (1.5.1.200708161) "Eclipse Data Tools
Platform Enablement" [Starting]
org.eclipse.datatools.enablement.hsqldb (1.0.0.200706071) "Eclipse Data
Tools Platform Hypersonic DB Enablement Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.0.200706071) "DB2 UDB iSeries Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.iseries.profile (1.0.0.200706071)
"Eclipse Data Tools Platform IBM DB2 UDB iSeries Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition (1.0.0.200706071)
"Eclipse Data Tools Platform DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.luw.profile (1.0.0.200706071)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.0.200706071) "DB2 UDB Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.ibm.db2.zseries.profile (1.0.0.200706071)
"Eclipse Data Tools Platform IBM DB2 UDB zSeries Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition (1.0.0.200706071)
"Eclipse Data Tools Platform Informix Database Definition Plug-in"
[Starting]
org.eclipse.datatools.enablement.ibm.informix.profile (1.0.0.200706071)
"Eclipse Data Tools Platform Informix Plug-in" [Resolved]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.200706071) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.profile (1.0.1.200709041)
"Eclipse Data Tools Platform Microsoft SQL Server Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql (1.0.0.200706071) "Eclipse Data Tools
Platform MySQL enablement plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.1.200709181)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.mysql.profile (1.0.0.200706071) "Eclipse
Data Tools Platform MySQL Plug-in" [Starting]
org.eclipse.datatools.enablement.oda.ws (1.0.1.200709111) "Eclipse Data
Tools Platform Web Services ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.ws.ui (1.0.1.200709111) "Eclipse Data
Tools Platform Web Services ODA Designer" [Starting]
org.eclipse.datatools.enablement.oda.xml (1.0.2.200709101) "Eclipse Data
Tools Platform XML ODA Runtime Driver" [Starting]
org.eclipse.datatools.enablement.oda.xml.ui (1.0.2.200709071) "Eclipse Data
Tools Platform XML ODA Designer" [Starting]
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.0.200706071)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.oracle.profile (1.0.0.200706151) "Eclipse
Data Tools Platform Oracle Plug-in" [Starting]
org.eclipse.datatools.enablement.postgresql.dbdefinition (1.0.0.200706071)
"PostgreSQL DB Definition" [Resolved]
org.eclipse.datatools.enablement.postgresql.profile (1.0.1.200709061)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase (1.0.1.200707131) "High-level Sybase
org.eclipse.datatools.enablement.sybase.asa (1.0.0.200706071) "Sybase ASA
Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.asa.models (1.0.0.200706071) "Sybase
ASA SQL Model" [Starting]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition (1.0.0.200706071)
"Eclipse Data Tools Platform Sybase Database Definition Plug-in" [Starting]
org.eclipse.datatools.enablement.sybase.ase.profile (1.0.0.200706071)
"Eclipse Data Tools Platform Sybase ASE Plug-in" [Starting]
org.eclipse.datatools.help (1.5.0.200706181) "Data Tools Platform Help
Utilities" [Resolved]
org.eclipse.datatools.lpg (1.0.0.200706071) "Wrapper for the LPG java
runtime" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.200706071) "Eclipse Data
Tools Platform DBDefinition Model" [Starting]
org.eclipse.datatools.modelbase.derby (1.0.0.200706071) "Derby Plug-in"
[Starting]
org.eclipse.datatools.modelbase.sql (1.0.0.200708161) "Eclipse Data Tools
Platform SQLModel Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.edit (1.0.0.200706071) "Eclipse Data
Tools Platform SQLModel Edit Plug-in" [Starting]
org.eclipse.datatools.modelbase.sql.query (1.0.0.200706151) "Eclipse Data
Tools Platform SQL Query Model Plugin" [Starting]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.200706151) "Eclipse
Data Tools Platform SQL XML Query Model Plugin" [Starting]
org.eclipse.datatools.oda.cshelp (1.0.0.200708161) "DTP ODA
Context-sensitive Help" [Starting]
org.eclipse.datatools.sqltools.common.ui (1.0.0.200708161) "Eclipse Data
Tools Platform SQL Tools Common UI Plug-in" [Starting]
org.eclipse.datatools.sqltools.data.core (1.0.0.200706151) "Data Core
Plugin" [Starting]
org.eclipse.datatools.sqltools.data.ui (1.0.0.200706151) "Data UI Plugin"
[Starting]
org.eclipse.datatools.sqltools.db.derby (1.0.0.200706071) "Eclipse Data
Tools Platform Derby SQL Tools Plug-in" [Starting]
org.eclipse.datatools.sqltools.db.generic (1.0.0.200706131) "Eclipse Data
Tools Platform SQL Tools Generic Database Plug-in" [Starting]
org.eclipse.datatools.sqltools.debugger.core (1.0.0.200709251) "Eclipse Data
Tools Platform SQL Debugger Framework" [Starting]
org.eclipse.datatools.sqltools.editor.core (1.0.0.200709261) "Eclipse Data
Tools Platform SQL Editor Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql (1.0.0.200706161) "Eclipse Data
Tools Platform SQL Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.lexer (1.0.0.200706161) "Eclipse
Data Tools Platform Lexer Plug-in" [Starting]
org.eclipse.datatools.sqltools.parsers.sql.query (1.0.0.200706162) "Eclipse
Data Tools Platform SQL Query Parser Plugin" [Resolved]
org.eclipse.datatools.sqltools.parsers.sql.xml.query (1.0.0.200706151)
"Eclipse Data Tools Platform SQL XML Query Parser Plugin" [Starting]
org.eclipse.datatools.sqltools.plan (1.0.0.200709061) "Eclipse Data Tools
Platform SQL Execution Plan View Plug-in" [Starting]
org.eclipse.datatools.sqltools.result (1.0.0.200709061) "Eclipse Data Tools
Platform SQL Results View Plug-in" [Starting]
org.eclipse.datatools.sqltools.routineeditor (1.0.0.200708161) "Eclipse Data
Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.sql (1.0.0.200706111) "Eclipse Data Tools
Platform SQL Core Plug-in" [Starting]
org.eclipse.datatools.sqltools.sqleditor (1.0.0.200709061) "Eclipse Data
Tools Platform SQL Editor" [Starting]
org.eclipse.datatools.sqltools.sqlscrapbook (1.0.0.200709141) "Eclipse Data
Tools Platform Sqlscrapbook Plug-in" [Starting]
org.eclipse.datatools.sqltools.tabledataeditor (1.0.0.200706071) "Eclipse
Data Tools Platform Table Data Editor Plug-in" [Starting]
org.eclipse.datatools.sqltools.tablewizard (1.0.0.200706071) "Eclipse Data
Tools Platform Database Table Creation Plug-in" [Starting]
org.eclipse.debug.core (3.3.1.v20070731_r331) "Debug Core" [Active]
org.eclipse.debug.ui (3.3.1.v20070731_r331) "Debug UI" [Active]
org.eclipse.draw2d (3.2.100.v20070529) "Graphical Editing Framework Draw2d"
[Starting]
org.eclipse.emf (2.3.0.v200709252135) "Eclipse Modeling Framework (EMF)"
[Starting]
org.eclipse.emf.ant (2.3.1.v200709252135) "EMF Ant Tasks" [Starting]
[Starting]
Generation" [Starting]
Generation UI" [Starting]
Generator UI" [Starting]
org.eclipse.emf.common (2.3.0.v200709252135) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.3.1.v200709252135) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.3.0.v200709252135) "CommonJ SDO" [Starting]
org.eclipse.emf.converter (2.3.0.v200709252135) "EMF Model Convert Support"
[Starting]
org.eclipse.emf.ecore (2.3.1.v200709252135) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.3.0.v200709252135) "EMF Ecore Change Model"
[Starting]
org.eclipse.emf.ecore.change.edit (2.3.0.v200709252135) "EMF Ecore Change
Edit Support" [Starting]
[Starting]
[Starting]
(SDO)" [Starting]
org.eclipse.emf.ecore.xmi (2.3.1.v200709252135) "EMF XMI" [Active]
org.eclipse.emf.edit (2.3.1.v200709252135) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.3.1.v200709252135) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.3.0.v200709252135) "EMF Model Export Support"
[Starting]
org.eclipse.emf.importer (2.3.1.v200709252135) "EMF Model Import Support"
[Starting]
org.eclipse.emf.importer.ecore (2.3.1.v200709252135) "EMF Ecore Importer"
[Starting]
org.eclipse.emf.importer.java (2.3.1.v200709252135) "EMF Annotated Java
Importer" [Starting]
org.eclipse.emf.importer.rose (2.3.1.v200709252135) "EMF Rose Importer"
[Starting]
org.eclipse.emf.mapping (2.3.0.v200709252135) "EMF Mapping" [Starting]
Framework (EMF) - org.eclipse.emf.mapping.ecore" [Starting]
Framework (EMF) - org.eclipse.emf.mapping.ecore.editor" [Starting]
org.eclipse.emf.mapping.ecore2ecore (2.3.0.v200709252135) "Ecore to Ecore
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2ecore.editor (2.3.0.v200709252135) "Ecore to
Ecore Mapping Editor" [Starting]
org.eclipse.emf.mapping.ecore2xml (2.3.0.v200709252135) "Ecore to XML
Mapping" [Starting]
org.eclipse.emf.mapping.ecore2xml.ui (2.3.0.v200709252135) "Ecore to XML
Mapping UI" [Starting]
org.eclipse.emf.mapping.ui (2.3.0.v200709252135) "EMF Mapping UI" [Starting]
org.eclipse.equinox.app (1.0.1.R33x_v20070828) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.http.jetty (1.0.1.R33x_v20070816) "Jetty Http Service"
[Starting]
org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service Registry
Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.1.R33x_v20070816) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.1.R33x_v20070816) "Jasper Jsp Support
Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.1.R33x_v20070828) "Equinox Launcher"
[Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.2.R331_v20071019) "Equinox
Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.3.1.R33x_v20070802) "Extension Registry
Support" [Active]
org.eclipse.gef (3.2.101.v20070814) "Graphical Editing Framework" [Starting]
org.eclipse.help (3.3.1.v20070726_33x) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.1.v20070813_33x) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.1.v20070726_33x) "Help System UI" [Starting]
org.eclipse.help.webapp (3.3.1.v20070823_33x) "Help System Webapp"
[Starting]
org.eclipse.jdt (3.3.0.v20070607-1300) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.3.1.R33x_v20070831-0435) "Java Annotation
Processing Core" [Starting]
org.eclipse.jdt.apt.pluggable.core (1.0.1.R33x_v20070831-0435) "Java
Compiler Apt IDE" [Starting]
org.eclipse.jdt.apt.ui (3.3.1.R33x_v20070801-1930) "Java Annotation
Processing UI" [Starting]
org.eclipse.jdt.compiler.apt (1.0.1.R33x_v20070831-0435) "Java Compiler Apt"
[Resolved]
org.eclipse.jdt.compiler.tool (1.0.1.v_780_R33x) "Java Compiler Tool
Support" [Resolved]
org.eclipse.jdt.core (3.3.1.v_780_R33x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.1.0.v20070606-0010) "Java Code
Manipulation Functionality" [Active]
org.eclipse.jdt.debug (3.3.1.v20070719_r331) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.101.v20070718_r331) "JDI Debug UI" [Starting]
org.eclipse.jdt.doc.user (3.3.1.r331_v20070912a) "Eclipse Java Development
User Guide" [Starting]
org.eclipse.jdt.junit (3.3.1.r331_v20070829) "Java Development Tools JUnit
support" [Starting]
org.eclipse.jdt.junit.runtime (3.3.0.v20070606-0010) "Java Development Tools
JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.100.v20070606-0010) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.3.1.v20070808_r331) "Java Development Tools
Launching Support" [Starting]
org.eclipse.jdt.ui (3.3.1.r331_v20070906) "Java Development Tools UI"
[Active]
org.eclipse.jem (2.0.100.v200709051030) "Java EMF Model" [Starting]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Installed]
org.eclipse.jem.beaninfo (2.0.0.v200705302225) "Java EMF Model BeanInfo
(Introspection) Support" [Starting]
org.eclipse.jem.beaninfo (1.2.2.v20061027_M) "Java EMF Model BeanInfo
(Introspection) Support" [Installed]
org.eclipse.jem.proxy (2.0.0.v200705302225) "Java EMF Model Proxy Support"
[Starting]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy Support"
[Installed]
org.eclipse.jem.ui (2.0.0.v200705302225) "Java EMF Model UI" [Starting]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Installed]
org.eclipse.jem.util (2.0.1.v200709051030) "Java EMF Model Utilities"
[Active]
org.eclipse.jem.util (1.2.1.v200704181020) "Java EMF Model Utilities"
[Installed]
org.eclipse.jem.workbench (2.0.0.v200705302225) "Java EMF Model Workbench
Support" [Starting]
org.eclipse.jem.workbench (1.2.4.v200704181020) "Java EMF Model Workbench
org.eclipse.jface (3.3.1.M20070910-0800b) "JFace" [Active]
org.eclipse.jface.databinding (1.1.1.M20070910-0800b) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.jface.text (3.3.1.r331_v20070629) "JFace Text" [Resolved]
org.eclipse.jpt.core (1.0.1.v200709180000) "Java Persistence API Tools -
Core" [Starting]
org.eclipse.jpt.db (1.0.1.v200709100000) "Java Persistence API Tools - DB"
[Starting]
org.eclipse.jpt.db.ui (1.0.0.v200705300001) "Java Persistence API Tools - DB
UI" [Resolved]
org.eclipse.jpt.doc.user (1.0.1.v200709120000) "Java Persistence
Documentation - Doc" [Starting]
"Dali Java Persistence API (JPA) Tools" [Resolved]
org.eclipse.jpt.gen (1.0.1.v200709100000) "Java Persistence API Tools -
Entity Gen" [Resolved]
org.eclipse.jpt.ui (1.0.1.v200709100000) "Java Persistence API Tools - UI"
[Starting]
org.eclipse.jpt.utility (1.0.1.v200709140000) "Java Persistence API Tools -
Utility" [Resolved]
org.eclipse.jsch.core (1.0.0.I20070426) "JSch Core" [Active]
org.eclipse.jsch.ui (1.0.1.r33x_20070709) "JSch UI" [Starting]
org.eclipse.jst (1.0.2.v200706120315) "J2EE Standard Tools (JST)" [Resolved]
Source" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.2.v200708301745)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.2.v200706120315) "Annotation
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.2.v200706120315) "Annotations UI
Plug-in" [Starting]
org.eclipse.jst.common.frameworks (1.1.102.v200709122200) "Integration
Plug-in" [Starting]
org.eclipse.jst.common.project.facet.core (1.1.1.v200706120315) "Project
Facet Core (Java Support)" [Starting]
org.eclipse.jst.doc.isv (1.0.302.v200708290613) "JST ISV Documentation"
[Starting]
org.eclipse.jst.ejb.doc.user (1.0.300.v200705302225) "EJB docs" [Starting]
org.eclipse.jst.ejb.ui (1.1.102.v200709122200) "WTP EJB UI Plug-in"
[Starting]
Core Source" [Resolved]
Enterprise UI Source" [Resolved]
org.eclipse.jst.j2ee (1.1.105.v200709122200) "J2EE Component" [Starting]
org.eclipse.jst.j2ee.core (1.1.103.v200709191000) "J2EE Core Component"
[Starting]
org.eclipse.jst.j2ee.doc.user (1.0.300.v200705302225) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.104.v200709122200) "EJB component Plug-in"
[Starting]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.2.v200706120315) "EJB
Annotation Model Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.2.v200708301745) "EJB
Emitter Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.2.v200706191638) "EJB
Annotations Ui Plug-in" [Starting]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.2.v200708301745) "Xdoclet
Annotations Plug-in" [Starting]
org.eclipse.jst.j2ee.infopop (1.0.203.v200706110217) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.1.104.v200709122200) "JCA Plug-in" [Starting]
org.eclipse.jst.j2ee.jca.ui (1.1.100.v200706071630) "WTP JCA UI Plug-in"
[Starting]
org.eclipse.jst.j2ee.navigator.ui (1.1.102.v200709122200) "J2EE Extensions
to Common Navigator" [Starting]
org.eclipse.jst.j2ee.ui (1.1.102.v200709122200) "WTP J2EE UI Plug-in"
[Starting]
org.eclipse.jst.j2ee.web (1.1.104.v200709122200) "Web Plug-in" [Starting]
org.eclipse.jst.j2ee.webservice (1.1.101.v200709122200) "Web Service
Plug-in" [Active]
org.eclipse.jst.j2ee.webservice.ui (1.1.102.v200709122200) "WTP Webservice
UI Plug-in" [Active]
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.2.v200706120315) "XDocletRuntime
Plug-in" [Starting]
org.eclipse.jst.jee (1.0.1.v200709251200) "JEE common Plug-in" [Starting]
org.eclipse.jst.jee.ejb (1.0.1.v200709251200) "JEE Ejb Plug-in" [Starting]
org.eclipse.jst.jee.ui (1.0.1.v200709122200) "Ui Plug-in" [Starting]
org.eclipse.jst.jee.web (1.0.1.v200709251200) "JEE Web Plug-in" [Starting]
org.eclipse.jst.jsf.common (1.0.1.v20070918) "JavaServer Faces Tools -
Common" [Starting]
org.eclipse.jst.jsf.common.ui (1.0.1.v20070912) "JavaServer Faces Tools -
Common UI" [Starting]
org.eclipse.jst.jsf.core (1.0.1.v20070921) "JavaServer Faces Tools - Core"
[Active]
org.eclipse.jst.jsf.doc.dev (1.0.1.v20070912) "JavaServer Faces Tools -
Developer Guide" [Resolved]
org.eclipse.jst.jsf.doc.user (1.0.1.v20070912) "JavaServer Faces Tools -
org.eclipse.jst.jsf.facesconfig (1.0.1.v20070912) "JavaServer Faces Tools -
FacesConfig Model" [Starting]
org.eclipse.jst.jsf.facesconfig.ui (1.0.1.v20070912) "JavaServer Faces
Tools - FacesConfig Editor" [Starting]
org.eclipse.jst.jsf.standard.tagsupport (1.0.1.v20070912) "JavaServer Faces
Tools - Taglibrary Metadata" [Starting]
org.eclipse.jst.jsf.ui (1.0.1.v20070912) "JavaServer Faces Tools - UI"
[Starting]
org.eclipse.jst.jsp.core (1.2.1.v200709181730) "Structured Source JSP Model"
[Starting]
org.eclipse.jst.jsp.ui (1.1.201.v200709061102) "SSE JSP Source Editor"
[Starting]
org.eclipse.jst.jsp.ui.infopop (1.0.3.v200706110217) "JSP tools infopops"
[Resolved]
org.eclipse.jst.pagedesigner (1.0.1.v20070912) "JavaServer Faces Tools - Web
Page Editor" [Starting]
org.eclipse.jst.pagedesigner.jsf.ui (1.0.1.v20070912) "JavaServer Faces
Tools - Pagedesigner UI" [Starting]
org.eclipse.jst.pagedesigner.jsp.core (1.0.1.v20070912) "JavaServer Faces
Tools - JSP Core Pagedesigner" [Starting]
Adapters Source" [Resolved]
Server UI Source" [Resolved]
org.eclipse.jst.server.core (1.0.205.v20070829b) "Java Server Support"
[Starting]
org.eclipse.jst.server.generic.core (1.0.205.v200709061325) "Generic Server
Plugin" [Starting]
org.eclipse.jst.server.generic.jboss (1.5.105.v200709061325) "JBoss Generic
server definitions" [Starting]
org.eclipse.jst.server.generic.jonas (1.5.105.v200709061325) "JOnAS Generic
Server definitions" [Starting]
org.eclipse.jst.server.generic.oc4j (1.5.105.v200709061325) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Starting]
org.eclipse.jst.server.generic.ui (1.0.205.v200709061325) "Generic Server
Plugin UI" [Starting]
org.eclipse.jst.server.installable (1.5.102.v20070608) "Installable server
adapters" [Resolved]
org.eclipse.jst.server.preview.adapter (1.0.1.v20070814b) "JEE Preview
Server Support" [Starting]
org.eclipse.jst.server.tomcat.core (1.1.1.v20070827) "Apache Tomcat Support"
[Starting]
org.eclipse.jst.server.tomcat.ui (1.1.0.v200705302225) "Apache Tomcat UI
Support" [Starting]
org.eclipse.jst.server.ui (1.0.203.v200705302225) "Java Server UI Support"
[Starting]
org.eclipse.jst.server.ui.doc.user (1.0.301.v200708161939) "Server Tools
documentation for J2EE Standard Tools" [Starting]
org.eclipse.jst.server.ui.infopop (1.0.3.v200706110217) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.201.v20070608) "WebSphere Generic
org.eclipse.jst.servlet.ui (1.1.102.v200709122200) "WTP Servlet UI Plug-in"
[Starting]
org.eclipse.jst.servlet.ui.infopop (1.0.202.v200706110217) "Servlet infopop"
[Starting]
org.eclipse.jst.standard.schemas (1.0.0.v200706221355) "JEE Related Schemas"
[Resolved]
Web UI Source" [Resolved]
(1.0.1.v200709110605-3-29oA55P5V8A) "Web Page Editor Source" [Resolved]
org.eclipse.jst.ws (1.0.204.v200707251745) "Web Services" [Starting]
org.eclipse.jst.ws.axis.consumption.core (1.0.204.v200708151945) "Web
service Axis Consumption Core" [Starting]
org.eclipse.jst.ws.axis.consumption.ui (1.0.203.v200708151945) "Webservice
Axis Consumption UI" [Starting]
org.eclipse.jst.ws.axis.creation.ui (1.0.205.v200708151945) "Webservice Axis
Creation UI" [Starting]
org.eclipse.jst.ws.axis.infopop (1.0.203.v200708222303) "Web services Axis
context sensitive help" [Starting]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.300.v200706111751) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.axis2.consumption.core (1.0.1.v200708241921) "Webservice
Axis2 Consumption Core Plug-in" [Starting]
org.eclipse.jst.ws.axis2.consumption.ui (1.0.1.v200709121418) "Webservice
Axis2 Consumption UI Plug-in" [Starting]
org.eclipse.jst.ws.axis2.core (1.0.1.v200709191532) "Webservice Axis2 Core
Plug-in" [Starting]
org.eclipse.jst.ws.axis2.creation.core (1.0.1.v200708241921) "Webservice
Axis2 Creation Core Plug-in" [Starting]
org.eclipse.jst.ws.axis2.creation.ui (1.0.1.v200708241921) "Webservice Axis2
Creation UI Plug-in" [Starting]
org.eclipse.jst.ws.axis2.ui (1.0.1.v200708282350) "Webservice Axis2 UI
Plug-in" [Starting]
org.eclipse.jst.ws.consumption (1.0.203.v200705311743) "Web Services
Consumption" [Starting]
org.eclipse.jst.ws.consumption.infopop (1.0.203.v200706110217) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.205.v200708202218) "Web Services
Consumption Graphical User Interface" [Starting]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.300.v200706111751) "Web
service consumption documentation" [Starting]
org.eclipse.jst.ws.creation.ejb.ui (1.0.100.v200706030600) "Web Services
Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.205.v200708151945) "Web Services
Creation Graphical User Interface" [Starting]
org.eclipse.jst.ws.doc.user (1.0.300.v200705302225) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.203.v200709190403) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.200.v200705311743) "Web Services
Universal Description Discovery and Integration Registry" [Starting]
org.eclipse.jst.ws.ui (1.0.202.v200708202218) "Web Services Graphical User
org.eclipse.ltk.core.refactoring (3.3.1.r331_v20070829) "Refactoring Core"
[Starting]
org.eclipse.ltk.ui.refactoring (3.3.1.r331_v20070829) "Refactoring UI"
[Starting]
org.eclipse.mylyn (2.1.0.v20070927-0900) "Mylyn" [Starting]
org.eclipse.mylyn.bugzilla.core (2.1.0.v20070927-0900) "Mylyn Bugzilla
Connector Core" [Active]
org.eclipse.mylyn.bugzilla.ide (2.1.0.v20070927-0900) "Mylyn Bugzilla
Connector IDE" [Active]
org.eclipse.mylyn.bugzilla.ui (2.1.0.v20070927-0900) "Mylyn Bugzilla
Connector UI" [Active]
org.eclipse.mylyn.compatibility (2.1.0.v20070927-0900) "Java 5 Compatibility
Checker" [Active]
org.eclipse.mylyn.context.core (2.1.0.v20070927-0900) "Mylyn Context Core"
[Active]
org.eclipse.mylyn.context.ui (2.1.0.v20070927-0900) "Mylyn Context UI"
[Active]
org.eclipse.mylyn.help.ui (2.1.0.v20070927-0900) "Mylyn Help" [Starting]
org.eclipse.mylyn.ide.ant (2.1.0.v20070927-0900) "Mylyn Ant UI Plug-in"
[Active]
org.eclipse.mylyn.ide.ui (2.1.0.v20070927-0900) "Mylyn IDE UI" [Active]
org.eclipse.mylyn.java.ui (2.1.0.v20070927-0900) "Mylyn Java" [Active]
org.eclipse.mylyn.monitor.core (2.1.0.v20070927-0900) "Mylyn Monitor Core"
[Resolved]
org.eclipse.mylyn.monitor.ui (2.1.0.v20070927-0900) "Mylyn Monitor UI"
[Active]
org.eclipse.mylyn.pde.ui (2.1.0.v20070927-0900) "Mylyn PDE UI Plug-in"
[Active]
org.eclipse.mylyn.resources.ui (2.1.0.v20070927-0900) "Mylyn Resources UI"
[Active]
org.eclipse.mylyn.tasks.core (2.1.0.v20070927-0900) "Mylyn Tasks Core"
[Active]
org.eclipse.mylyn.tasks.ui (2.1.0.v20070927-0900) "Mylyn Tasks UI" [Active]
org.eclipse.mylyn.team.cvs (2.1.0.v20070927-0900) "Mylyn Team CVS Plug-in"
[Resolved]
org.eclipse.mylyn.team.ui (2.1.0.v20070927-0900) "Mylyn Team UI" [Active]
org.eclipse.mylyn.web.core (2.1.0.v20070927-0900) "Mylyn Web Core Plug-in"
[Active]
org.eclipse.mylyn.web.ui (2.1.0.v20070927-0900) "Mylyn Web UI" [Starting]
org.eclipse.osgi (3.3.1.R33x_v20070828) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1 Services"
[Resolved]
org.eclipse.osgi.util (3.1.200.v20070605) "OSGi Release 4.0.1 Utility
Classes" [Resolved]
org.eclipse.pde (3.3.1.R33x_r20070920) "Eclipse Plug-in Development
Environment" [Active]
org.eclipse.pde.build (3.3.2.R331_v20071019) "Plug-in Development
Environment Build Support" [Starting]
org.eclipse.pde.core (3.3.1.v20070912-0800) "Plug-in Development Core"
[Active]
org.eclipse.pde.doc.user (3.3.0.v20070614-0800) "Eclipse Plug-in Development
User Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.3.0.v20070608-1300) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.3.0.v20070608-1300) "Plug-in Development
Environment Runtime" [Starting]
org.eclipse.pde.ui (3.3.1.v20070912-0800) "Plug-in Development UI" [Active]
org.eclipse.pde.ui.templates (3.3.0.v20070608-1300) "PDE Templates"
[Starting]
org.eclipse.platform (3.3.2.R33x_v20071022) "Eclipse Platform" [Starting]
org.eclipse.platform.doc.user (3.3.0.M20070913-1400) "Eclipse Workbench User
Guide" [Starting]
org.eclipse.rcp (3.2.0.v20070612) "Eclipse RCP" [Starting]
org.eclipse.search (3.3.1.r331_v20070831-0800) "Search Support" [Active]
org.eclipse.swt (3.3.2.v3347) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.3.2.v3347a) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.3.1.r33x_20070807) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.3.1.r33x_20070724) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.100.I20061208) "CVS SSH Core" [Starting]
org.eclipse.team.cvs.ssh2 (3.2.100.I20070604) "CVS SSH2" [Starting]
org.eclipse.team.cvs.ui (3.3.1.r33x_20070807) "CVS Team Provider UI"
[Active]
org.eclipse.team.ui (3.3.1.r33x_20070730) "Team Support UI" [Active]
org.eclipse.text (3.3.0.v20070606-0010) "Text" [Resolved]
org.eclipse.tomcat (4.1.230.v20070531) "Tomcat Wrapper" [Starting]
org.eclipse.ui (3.3.1.M20070910-0800b) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.100.v20070524A) "Browser Support" [Starting]
org.eclipse.ui.cheatsheets (3.3.0.v20070507) "Cheat Sheets" [Starting]
org.eclipse.ui.console (3.2.1.v20070824_r331) "Console" [Active]
org.eclipse.ui.editors (3.3.1.r331_v20070629) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.200.v20070416) "External Tools" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.3.1.M20070910-0800b) "Eclipse IDE UI" [Active]
org.eclipse.ui.ide.application (1.0.0.I20070530-0100) "Eclipse IDE UI
Application" [Resolved]
org.eclipse.ui.intro (3.2.101.v20070827_33x) "Welcome Framework" [Starting]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome"
[Starting]
org.eclipse.ui.navigator (3.3.2.M20071022-1600a) "Common Navigator View"
[Active]
org.eclipse.ui.navigator.resources (3.3.1.M20070831-2000) "Navigator
Workbench Components" [Active]
org.eclipse.ui.net (1.0.0.I20070516) "Internet Connection Management UI"
[Active]
org.eclipse.ui.presentations.r21 (3.2.100.I20070605-0010) "R21 Presentation
Plug-in" [Starting]
org.eclipse.ui.views (3.2.101.M20070910-0800b) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.1.M20070831-0800) "Tabbed
Properties View" [Starting]
org.eclipse.ui.win32 (3.2.100.I20070319-0010) "Eclipse UI Win32
Re: A quick question on the tutorial - New JSF Project Not displayed [message #475328 is a reply to message #475200] |
Mon, 19 November 2007 05:27  |
Sorry all,
Worked it out :-)
New Dynamic Web project.
I've just started my "reading english course"
"Stu" <evaandoli@dodo.com.au> wrote in message
news:fhrj5o$err$1@build.eclipse.org...
> Any clues?
> Stu
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -vm
> -Xms40m
> -Xmx512m
> eof=eof
> file.separator=\
> Systems\MPEG;c:\Program Files\Microsoft SQL
> Server\90\Tools\binn\;C:\Program Files\QuickTime\QTSystem\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> Plummer/workspace/
> osgi.nl=en_AU
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=AU
> user.language=en
> user.variant=
> *** Features:
> Client"
> Data Access"
> Guide"
> Data Tools Platform XML ODA Runtime Driver"
> Generator"
> Generation"
> Generation UI"
> Generator UI"
> Support"
> (SDO)"
> Modeling Framework (EMF) - org.eclipse.emf.mapping.ecore.editor"
> Source"
> Core Source"
> Adapters Source"
> Core Source"
> Server UI Source"
> Core Source"
> Web UI Source"
> Platform"
> RCP"
> Core Source"
> Common UI Source"
> "Web Standard Tools (WST)"
> Source"
> Server UI Source"
> Source"
> UI Source"
> Web Service UI Source"
> Core Source"
> XML UI Source"
> Java (ICU4J)" [Active]
> [Resolved]
> [Starting]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Mechanism" [Active]
> [Resolved]
> [Active]
> [Active]
> [Starting]
> [Active]
> Management" [Active]
> [Active]
> Resource Management Compatibility Fragment" [Resolved]
> Management Win32 Fragment" [Resolved]
> "Eclipse Registry Compatibility Fragment" [Resolved]
> Data Tools Platform Apache Derby Plug-in" [Starting]
> "Eclipse Data Tools Platform Generic DB UI Plug-in" [Starting]
> Plug-in" [Starting]
> Data Tools Platform Apache Derby UI Plug-in" [Starting]
> Access" [Starting]
> ODA Designer UI Framework Plug-in" [Starting]
> Data Tools Platform SQM Core Plug-in" [Starting]
> Data Tools Platform FE UI Plug-in" [Starting]
> "Eclipse Data Tools Platform Server UI Plug-in" [Starting]
> Platform Connectivity UI Plug-in" [Starting]
> Guide" [Starting]
> Tools Platform Enablement" [Starting]
> (1.0.0.200706071) "Eclipse Data Tools Platform DB2 UDB Database Definition
> Plug-in" [Starting]
> (1.0.0.200706071) "Eclipse Data Tools Platform Informix Database
> Tools Platform MySQL enablement plug-in" [Starting]
> Data Tools Platform XML ODA Designer" [Starting]
> [Starting]
> Sybase Enablement Plug-in" [Starting]
> Plug-in" [Starting]
> "Sybase ASA SQL Model" [Starting]
> [Starting]
> runtime" [Resolved]
> Data Tools Platform DBDefinition Model" [Starting]
> [Starting]
> Plugin" [Starting]
> [Starting]
> Data Tools Platform SQL Debugger Framework" [Starting]
> "Eclipse Data Tools Platform Lexer Plug-in" [Starting]
> "Eclipse Data Tools Platform SQL Query Parser Plugin" [Resolved]
> Tools Platform SQL Results View Plug-in" [Starting]
> Data Tools Platform SQL Tools Routine Editor Plug-in" [Starting]
> Data Tools Platform Sqlscrapbook Plug-in" [Starting]
> Draw2d" [Starting]
> [Starting]
> Generator" [Starting]
> Support" [Starting]
> Model" [Starting]
> [Starting]
> [Starting]
> (SDO)" [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> Mapping" [Starting]
> Mapping" [Starting]
> [Starting]
> Container" [Active]
> [Active]
> [Starting]
> Servlet" [Starting]
> Bundle" [Starting]
> [Resolved]
> "Equinox Launcher Win32 X86 Fragment" [Resolved]
> Mechanism" [Active]
> Support" [Active]
> [Starting]
> [Starting]
> [Starting]
> [Resolved]
> Apt" [Resolved]
> Support" [Resolved]
> [Active]
> [Starting]
> support" [Starting]
> Tools JUnit runtime support" [Resolved]
> [Active]
> [Starting]
> [Installed]
> [Active]
> [Installed]
> Support" [Starting]
> Core" [Starting]
> [Starting]
> DB UI" [Resolved]
> [Starting]
> Tools - Utility" [Resolved]
> [Resolved]
> Source" [Resolved]
> Plug-in" [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> "Xdoclet Annotations Plug-in" [Starting]
> [Resolved]
> [Starting]
> [Starting]
> Plug-in" [Active]
> Plug-in" [Starting]
> Common" [Starting]
> [Active]
> Tools - FacesConfig Model" [Starting]
> Faces Tools - Taglibrary Metadata" [Starting]
> [Starting]
> Model" [Starting]
> [Starting]
> [Resolved]
> Web Page Editor" [Starting]
> [Starting]
> Server Plugin" [Starting]
> Generic server definitions" [Starting]
> Generic Server definitions" [Starting]
> Support" [Starting]
> Support" [Starting]
> [Starting]
> Plug-in" [Starting]
> infopop" [Starting]
> Schemas" [Resolved]
> Axis Creation UI" [Starting]
> "Webservice Axis2 Consumption Core Plug-in" [Starting]
> Plug-in" [Starting]
> Axis2 Creation UI Plug-in" [Starting]
> Plug-in" [Starting]
> services UI" [Resolved]
> [Resolved]
> [Resolved]
> [Starting]
> [Starting]
> Compatibility Checker" [Active]
> [Active]
> [Active]
> [Active]
> [Resolved]
> org.eclipse.mylyn.monitor.ui (2.1.0.v20070927-0900) &qu
Re: A quick question on the tutorial - New JSF Project Not displayed [message #615708 is a reply to message #475200] |
Sorry all,
Worked it out :-)
> Any clues?
> Stu
> win32
> -ws
> win32
> -arch
> x86
> -showsplash
> -launcher
> -name
> Eclipse
> --launcher.library
> -startup
> -vm
> -Xms40m
> -Xmx512m
> eof=eof
> file.separator=\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> Plummer/workspace/
> osgi.nl=en_AU
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=AU
> user.language=en
> user.variant=
> *** Features:
> Client"
> Data Access"
> Guide"
> Generator"
> Generation"
> Generation UI"
> Generator UI"
> Support"
> (SDO)"
> Source"
> Core Source"
> Adapters Source"
> Core Source"
> Server UI Source"
> Core Source"
> Web UI Source"
> Platform"
> RCP"
> Core Source"
> Common UI Source"
> Source"
> Server UI Source"
> Source"
> UI Source"
> Core Source"
> XML UI Source"
> [Resolved]
> [Starting]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Mechanism" [Active]
> [Resolved]
> [Active]
> [Active]
> [Starting]
> [Active]
> [Active]
> Plug-in" [Starting]
> Access" [Starting]
> Guide" [Starting]
> Plug-in" [Starting]
> [Starting]
> Plug-in" [Starting]
> [Starting]
> runtime" [Resolved]
> [Starting]
> Plugin" [Starting]
> [Starting]
> Draw2d" [Starting]
> [Starting]
> Support" [Starting]
> Model" [Starting]
> [Starting]
> [Starting]
> (SDO)" [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> Mapping" [Starting]
> Mapping" [Starting]
> [Starting]
> Container" [Active]
> [Active]
> [Starting]
> Servlet" [Starting]
> Bundle" [Starting]
> [Resolved]
> Mechanism" [Active]
> Support" [Active]
> [Starting]
> [Starting]
> [Starting]
> [Resolved]
> Apt" [Resolved]
> Support" [Resolved]
> [Active]
> [Starting]
> support" [Starting]
> [Active]
> [Starting]
> [Installed]
> [Active]
> [Installed]
> Support" [Starting]
> Core" [Starting]
> [Starting]
> DB UI" [Resolved]
> [Starting]
> [Resolved]
> Source" [Resolved]
> Plug-in" [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Starting]
> [Resolved]
> [Starting]
> [Starting]
> Plug-in" [Active]
> Plug-in" [Starting]
> Common" [Starting]
> [Active]
> [Starting]
> Model" [Starting]
> [Starting]
> [Resolved]
> [Starting]
> Support" [Starting]
> Support" [Starting]
> [Starting]
> Plug-in" [Starting]
> infopop" [Starting]
> Schemas" [Resolved]
> Plug-in" [Starting]
> Plug-in" [Starting]
> [Resolved]
> [Resolved]
> [Starting]
> [Starting]
> [Active]
> [Active]
> [Active]
> [Resolved]
Current Time: Wed Jul 23 05:45:34 EDT 2025
Powered by FUDForum. Page generated in 0.10968 seconds
