Home » Modeling » UML2 Tools » Class Diagram Usability
Class Diagram Usability [message #474932] Thu, 24 July 2008 11:19 Go to next message
Hello UML2Tools team,
We're building a plug-in reusing your org.eclipse.uml2.diagram.clazz
component. We think it's pretty good, however we have some questions that
concern to its usability:
1. An average user creates a diagram with a few classes, and each one with
several properties. When he wants to specify the data type for each
property, he looks at the property view, goes to the Type entry, and then
is introduced to a gigantic combo box which shows all possible
metaclasses, eDataTypes, stereotypes, associations in the UML2 metamodel,
etc., and he just wants to declare a String or an integer. We'd like to
make things simpler by showing him only the primitive data types. Is there
anyway we can filter out this big list?
2. We're also working with profiles and stereotypes, and it turns out
incredibly cool that right-clicking an element shows us the "Apply
Stereotype" menu with all the appliable stereotypes for that element.
However, currently the diagram only shows the stereotypes for classes, but
not for properties or associations. Is there a reason why this isn't so?
Any possible way to fix it?
3. Also, when we apply an stereotype that has properties (aka "tagged
values"), these are not displayed in the properties window when the
stereotyped element is selected; this does show up in the UML2 tree
editor, but not in UML2Tools, so the user has to switch editors to edit
the properties of a stereotype application (from the .umlclass to .uml
file). Is there any way we can save this effort to the users?
Thanks a lot, keep doing a great job!
-Juan
Re: Class Diagram Usability [message #474935 is a reply to message #474932] Fri, 25 July 2008 14:52 Go to previous messageGo to next message
Hi Juan,
> that concern to its usability:
Thank you for (re)using our product. I hope, you'll like it.
> with several properties. When he wants to specify the data type for
> each property, he looks at the property view, goes to the Type entry,
> and then is introduced to a gigantic combo box which shows all
> possible metaclasses, eDataTypes, stereotypes, associations in the
> UML2 metamodel, etc., and he just wants to declare a String or an
> integer. We'd like to make things simpler by showing him only the
> primitive data types. Is there anyway we can filter out this big list?
a) The list is so huge because it shows Classes, DataTypes, etc not only
from the owning package, but also from all other loaded packages. UMLPrimitiveTypes
are imported by default, and therefore UMLPrimitiveTypes library is loaded.
You can remove the imports (expand secondary diagram node in the top-left
of the diagram, select all element imports, delete them), close diagram and
open it again. The type list will be significantly shorter.
b) In addition, UML2Tools provides TreeEditor to edit reference-based features
(type is a references-based one). TreeEditor is available by clicking '...'
button in the property sheet field.
c) If you are firm of purpose to leave only DataTypes, the following changes
will help you :
Take a look at org.eclipse.uml2.diagram.common.sheet.PropertySourceExtensio n
class. You'll need to change newPropertyDescriptor() method approximately
this way:
protected IPropertyDescriptor newPropertyDescriptor(IItemPropertyDescriptor
itemPropertyDescriptor) {
return new EMFCompositeSourcePropertyDescriptor(object, itemPropertyDescriptor,
getCategory()) {
protected CellEditor doCreateEditor(Composite composite) {
// copy default implementation
/changes appears here:
} else if (genericFeature instanceof EStructuralFeature) {
final EStructuralFeature feature = (EStructuralFeature) genericFeature;
// Here we set the type of elements that will be shown
final EClassifier eType;
if (UMLPackage.eINSTANCE.getTypedElement_Type().equals(feature) )
eType = UMLPackage.eINSTANCE.getDataType();
} else {
eType = feature.getEType();
// .. copy the code again or call super method
This is just a sketch, I hope it explained the idea of the changes.
> but not for properties or associations. Is there a reason why this
> isn't so? Any possible way to fix it?
You are correct, there is a bugzilla request #218191 '[ClassD] Missing stereotype
display' . It's still open.
There are no technical difficulties to repeat the functionality, that have
already been implemented for classes:
1) In classDiagram.gmfmap file add label for stereotype (you can take label
from Class mapping as a template) to all DataType, PrimitiveType and other
needed mappings
2) In UMLParserProvider#create...Parser() replace default parser with AppliedStereotypeParser.
> edit the properties of a stereotype application (from the .umlclass to
> .uml file). Is there any way we can save this effort to the users?
Tagged values have sophisticated presentation rules, that's why they are
not implemented now. If you impement the feature, that would be great!
Thanks the feedback!
Best wishes,
Tatiana.
Re: Class Diagram Usability [message #475297 is a reply to message #474935] Thu, 21 August 2008 12:28 Go to previous message
Hi Tatiana,
Thank you so much for your help! We're evaluating the effort required to
implement these features. If we do, we'd love to submit it as
contributions to the project :)
-Juan
Re: Class Diagram Usability [message #621746 is a reply to message #474932] Fri, 25 July 2008 14:52 Go to previous message
Hi Juan,
will help you :
this way:
getCategory()) {
} else {
needed mappings
Best wishes,
Tatiana.
Re: Class Diagram Usability [message #622609 is a reply to message #474935] Thu, 21 August 2008 12:28 Go to previous message
Hi Tatiana,
-Juan
Previous Topic:Re: Is it possible to create a Sequence Diagram with UML2Tool?
Next Topic:Creating State Charts
Current Time: Sat Jul 26 07:48:12 EDT 2025
Powered by FUDForum. Page generated in 1.27211 seconds
