Home » Modeling » UML2 Tools » Transform Class Diagram to SQL ?
Transform Class Diagram to SQL ? [message #474938] |
Mon, 28 July 2008 04:19  |
I would like to know is UML2 Tools is the right tool to desing a
database. I would like to draw my tables and the relations between them
using a graphical editor and then generate the SQL code from it.
Is this possible with UML2 Tools or am I on the wrong way ?
Tex
Re: Transform Class Diagram to SQL ? [message #474939 is a reply to message #474938] |
Mon, 28 July 2008 07:31   |
Tex-Twil a écrit :
> Hello,
> Tex
Hi Tex-Twil,
UML isn't the right notation for database modeling, except uml profile
from Rational Rose. But currently, I advice you Clay Database Modeling
(http://www.azzurri.jp/en/clay/index.html), a plugin to add to eclipse
(works with Ganymede), the only drawback is her license, it's not free,
but you can use it to design database and you have reverse engineering
existing database.
Re: Transform Class Diagram to SQL ? [message #474940 is a reply to message #474939] |
Mon, 28 July 2008 07:55   |
Esteban Dugueperoux wrote:
> Tex-Twil a écrit :
>> Hello,
>> Thanks,
>> Tex
> Hi Tex-Twil,
> existing database.
ok thanks but it doesn't seem to be supported on Linux. Are there any
other plugins for a database design on Linux ?
Tex
Re: Transform Class Diagram to SQL ? [message #475266 is a reply to message #474940] |
Mon, 28 July 2008 08:03   |
>> Tex-Twil a écrit :
>>> Hello,
>>> Thanks,
>>> Tex
>> Hi Tex-Twil,
>> existing database.
> Regards,
> Tex
On MacOS X it works, then it should works on Linux. How do you have
installed this plugin by zip file or by update site?
What is the errors if you have it?
Regards.
Re: Transform Class Diagram to SQL ? [message #475267 is a reply to message #475266] |
Mon, 28 July 2008 08:10  |
>>> Tex-Twil a écrit :
>>>> Hello,
>>>> Thanks,
>>>> Tex
>>> Hi Tex-Twil,
>>> existing database.
>> Regards,
>> Tex
> Regards.
Sorry,
I saw just "WinXP" on the home page so I thought Linux wont be
supported. I've just tried on Linux and it works. Thanks !
Tex
Re: Transform Class Diagram to SQL ? [message #621775 is a reply to message #474938] |
Tex-Twil a écrit :
> Hello,
> Tex
Hi Tex-Twil,
existing database.
Re: Transform Class Diagram to SQL ? [message #621776 is a reply to message #474939] |
> Tex-Twil a écrit :
>> Hello,
>> Thanks,
>> Tex
> Hi Tex-Twil,
> existing database.
Tex
Re: Transform Class Diagram to SQL ? [message #621778 is a reply to message #474940] |
>> Tex-Twil a écrit :
>>> Hello,
>>> Thanks,
>>> Tex
>> Hi Tex-Twil,
>> existing database.
> Regards,
> Tex
Regards.
Re: Transform Class Diagram to SQL ? [message #621779 is a reply to message #475266] |
>>> Tex-Twil a écrit :
>>>> Hello,
>>>> Thanks,
>>>> Tex
>>> Hi Tex-Twil,
>>> existing database.
>> Regards,
>> Tex
> Regards.
Sorry,
Tex
Current Time: Sat Jul 26 10:28:28 EDT 2025
Powered by FUDForum. Page generated in 0.08647 seconds
