Home » Modeling » UML2 » can't see connector
can't see connector [message #475153] Tue, 21 August 2007 11:48 Go to next message
Originally posted by: nickkirtley.gmail.com
hi,
I'm looking for connector in the uml diagram but I can't find it. Someone
know why? I see it in javadoc of uml2 so it should be there right?
thx for any help
Nick
Re: can't see connector [message #475156 is a reply to message #475153] Tue, 21 August 2007 13:13 Go to previous messageGo to next message
Hi Nick,
If you will create a Class then you'll find an option to create an owned
connector.
Bogdan
> thx for any help
> Nick
Re: can't see connector [message #475163 is a reply to message #475156] Wed, 22 August 2007 05:59 Go to previous messageGo to next message
hi,
thx for your reply.
I see the connector (i added a component and then it showed). I want to
connect two components with each other. But an owned connector is only for
one component isn't it? How I connect two components via a connector?
regards,
Nick
Re: can't see connector [message #475167 is a reply to message #475163] Wed, 22 August 2007 08:06 Go to previous messageGo to next message
Hi, Nick,
Connectors are owned by structured classifiers, so you must have a
structured classifier context in which to create your connector.
If you're looking to connect two components together, then you will need a
component (the context) that has two parts or roles (i.e., properties of
some flavour) that are typed by your respective components. Then, you can
connect these two parts and the context component will own the connector.
On either of your component parts, you can also choose to attach the
connector to a port on the part. In this case, the ConnectorEnd will
reference as its "role" the port owned by the component that is the type of
the part, and the ConnectorEnd should reference the part as its
"partWithPort".
HTH,
Christian
Nick Kirtley wrote:
> hi,
> thx for your reply.
> regards,
> Nick
Re: can't see connector [message #475181 is a reply to message #475167] Wed, 22 August 2007 09:20 Go to previous messageGo to next message
.... also, additional (similar) information was added to a post in the
uml2tools newsgroup entitled using "uml2tools" on June 11.
- James.
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:fah8sb$6pr$1@build.eclipse.org...
> Hi, Nick,
of
> "partWithPort".
> HTH,
> Christian
> Nick Kirtley wrote:
> > hi,
> > thx for your reply.
for
> > regards,
> > Nick
Re: can't see connector [message #475241 is a reply to message #475181] Mon, 27 August 2007 05:05 Go to previous messageGo to next message
Hi James and Christian,
This is what I want:
from the omg uml2 spec.
An assembly connector is a connector between two components that defines
that one component provides the services that
another component requires. An assembly connector is a connector that is
defined from a required interface or port to a
provided interface or port.
I want the connectors to be connected through the ports. As is described
above. So how do you mean that it can't be done James?
regards,
Nick
Re: can't see connector [message #475244 is a reply to message #475241] Mon, 27 August 2007 10:17 Go to previous messageGo to next message
Hi Nick,
That exact passage is a bit misleading in the spec.
Connectors connect "ConnectableElements". A component is not a connectable
element.
You can create connectors between parts/roles typed by components in the
context of some other structured classifier.
(That is also what Christian mentioned in his posting.)
All that I was getting at is that you cannot create connectors on component
diagrams between components. There would be no context and the connectors
would be between things that are not connectable elements.
The sentence from the spec "Assembly connector is a connector between two
components ... " is not entirely accurrate, however, all the diagrams in the
discussion ( fig 8.16 etc) show connectors between parts/roles within a
context.
- James.
"Nick Kirtley" <nickkirtley@gmail.com> wrote in message
news:18b9e1f88853b1ea4f338161b36e625c$1@www.eclipse.org...
> regards,
> Nick
Re: can't see connector [message #475246 is a reply to message #475244] Mon, 27 August 2007 10:58 Go to previous messageGo to next message
ok,
It was slightly inaccurate of me to say connector between two components.
I meant between ports/interfaces.
nick
Re: can't see connector [message #475247 is a reply to message #475246] Mon, 27 August 2007 15:21 Go to previous messageGo to next message
Hi Nick,
Just one small clarification, connectors only go between ports or
parts/roles, not interfaces ( including required/provided interfaces on
ports ). Connectors have this alternative ball/socket notation which might
lead you to believe that the end points are required/provided interfaces but
the endpoints are ports or roles.
And connectors should not be drawn between ports on components on a
component diagram, just composite structure diagram ( because of the lack of
context ). Say you were able to draw a connector between ports on a
component diagram... who then owns the connector? It would be ambiguous.
Connectors really convey the notion that "In some particular context, these
roles are connected in this way", in some other context, the roles/ports
could be connected in some completly different way.
I don't mean to flog this point but just want to make sure that we are all
in agreement.
- James.
news:4525e0fec639d3829086c856ec22090f$1@www.eclipse.org...
> ok,
> nick
Re: can't see connector [message #475257 is a reply to message #475247] Tue, 28 August 2007 09:55 Go to previous messageGo to next message
Hi james, thx for that last post, I understand the connector/component
relationship a little better, but I don't think I understand it 100%
It's important I understand this correctly because it's an essential part
of my project.
Let me confirm this:
If I have two components in a component diagram I cannot connect them with
a connector because they have no context?
So even if I have two components: lets say user and billing.
A user uses services, lets say some digital services like renting movies
online. Billing keeps track of billing info. I want to connect these two
because obviously they have a relationship. Can I connect them in a
component diagram (with for ex. connectors that each have a port) or can I
NOT connect them and have to define some sort of context in a context
diagram?
If this example is no good then another example is welcome.
regards,
Nick
Re: can't see connector [message #475259 is a reply to message #475257] Tue, 28 August 2007 11:19 Go to previous messageGo to next message
Hi Nick,
Lets take a really silly example just to illustrate a point.
Say you have 3 classes ( or components ). Say, "Hero", "Villain" and
"Sidekick". In a class diagram ( or component diagram ) you could model
these classes (components).
In one context say "Action Movie" you could have some connection between
Hero and Villain, and another connection between Hero and Sidekick.
In another context, say "Romantic Comedy" you could have a connection
between "Hero" and "Sidekick", there would be no connection between "Hero"
and "Villain".
Imagine that you drew connectors between "Hero" and "Villain" in your class
( or component ) diagram. In effect you would be saying that regardless of
context you always have some connection between "Hero" and "Villain", but
this is not the case.
You would need to create some other structured classifier called "Action
Movie" and in that structured classifier, create a composite structure
diagram and show some role typed by hero, a role typed by villain and a role
typed by Sidekick with the connections between them.
For example, say you want to model the movie "Shrek" and assume it is of
type "Action Movie".
Shrek would be playing the role of Hero, donkey would be playing the role
of Sidekick and evil fairy godmother would be plaing the role of Villain and
since the movie Shrek is of type "Action Movie" there would be some
connection between the hero and villain and between hero and sidekick.
In the context of a particular "Romantic Comedy" shrek could be playing the
role of "Sidekick" and donkey could be playing the role of "Hero" and there
would be a relationship between them ( maybey the hero falls in love with
the sidekick ... kinda weird ).
The point here is that in your class/component diagram you model general
components that can be used in different contexts. You wouldn't want to
create connectors between Hero and Villain on your component diagram because
you have no idea what context's Hero and Villain will be used... they may or
may not be "connected".
Keep in mind that you can use Collaborations as context.
( There is no such thing as "context diagram" but rather "composite
structure diagram" )
Does that help?
- James.
news:0676bd910f2a09d4c960d350761df970$1@www.eclipse.org...
> of my project.
> diagram?
> regards,
> Nick
Re: can't see connector [message #475355 is a reply to message #475259] Wed, 29 August 2007 07:03 Go to previous messageGo to next message
Hi james,
I understand the concept now. But i'm having trouble implementing the
concept into uml2.
Could you explain step by step how to model the shrek example in the uml2
diagram?
thx
Re: can't see connector [message #475359 is a reply to message #475355] Wed, 29 August 2007 11:32 Go to previous messageGo to next message
In general ....
- Create a component call it C1 ( on a component diagram ).
- Create ports or required/provided interfaces on C1 or the ports as
required. ( there have been previous postings explaining this in detail ).
- Create another Component/Class/Collaboration call it C2.
- Create a property in C2 call it "foo" and set its type to C1.
- Create a composite structure diagram whose context is C2. you should see
foo:C1 with ports/required provided interfaces etc.
- Create connectors on the composite structure diagram between parts/roles.
I'm not sure if UML2Tools project supports composite structure diagrams at
this stage? You can create all of this using the opensource UML2
(tree-like) editor.
- James
news:a27247de9cdaab5c9ef38ea8d3dfc512$1@www.eclipse.org...
> Hi james,
> concept into uml2.
> diagram?
> thx
Re: can't see connector [message #475365 is a reply to message #475359] Thu, 30 August 2007 08:38 Go to previous messageGo to next message
Ok got it working up until creating the composite structure diagram.
You're right that it's not working in uml2 tools. How do I do it in the
uml2 diagram editor?
thx
Nick
Re: can't see connector [message #475366 is a reply to message #475365] Thu, 30 August 2007 08:42 Go to previous messageGo to next message
One more thing. Is this explained anywhere in the mdt uml2 documentation?
I haven't found it but if it does exist then it would save having to ask
you ;)
nick
Re: can't see connector [message #475367 is a reply to message #475366] Thu, 30 August 2007 09:26 Go to previous messageGo to next message
General explanations of UML, how it works, the various diagrams and
everything you ever wanted to know ( and more ) is explained in the
Superstructure specification for UML at omg.org. This document keeps
changing as changes are made to UML. MDT UML2 documentation focuses on the
API that is provided but not about how to use UML.
- James.
news:a804d6a73cff55a908cfac89302421c1$1@www.eclipse.org...
> you ;)
> nick
Re: can't see connector [message #475369 is a reply to message #475365] Thu, 30 August 2007 09:32 Go to previous messageGo to next message
UML2 project doesn't have a diagram editor, just a tree-like default EMF
editor.
You can create all the items mentioned by using context menus to create
various child items.
It's a pretty rough way to model UML and is intended to be an example editor
only. I would recommend using UML2Tools diagram editor or extending it
yourself to support Composite Structures or to use another commercial ( or
freebie ) product that does support composite structures.
- James.
news:fff3c4362540d4197d8e3722fa06fce9$1@www.eclipse.org...
> thx
> Nick
Re: can't see connector [message #475371 is a reply to message #475367] Thu, 30 August 2007 09:32 Go to previous messageGo to next message
ok and how do I do this in the uml2 diagram editor?
-Create a composite structure diagram whose context is C2. you should see
nick
Re: can't see connector [message #475372 is a reply to message #475369] Thu, 30 August 2007 09:44 Go to previous messageGo to next message
Hi james,
yeah but I only need it for very simple situations ( and later on more
complicated ones. but that can wait ), more proof of concept at the
moment. You said that it was possible in the uml2 tree editor(which is
what i meant when i said uml2 diagram editor) to create a composite
structure, yet I haven't found that option.
nick
Re: can't see connector [message #475376 is a reply to message #475372] Thu, 30 August 2007 10:20 Go to previous messageGo to next message
The suggestion of creating a composite structure diagram was if you were
using UML2Tools or a tool other than the default UML2 tree editor ( since
there are no diagrams in this perspective ). I was talking about how to do
such a thing in general terms.
You just...
Create a component C1.
Create a component C2
Create a property of C2 called foo.
type foo with C1.
- James.
news:a7d3d9f8941f745e6d14bf07eb5f29fa$1@www.eclipse.org...
> Hi james,
> nick
Re: can't see connector [message #475574 is a reply to message #475376] Fri, 31 August 2007 04:59 Go to previous messageGo to next message
Yes but now I haven't created a connector between c1 and c2. This should
be done in a composite structure right? How do I do this in the uml editor?
nick
Re: can't see connector [message #475583 is a reply to message #475574] Fri, 31 August 2007 12:51 Go to previous messageGo to next message
The connector would be created under the component C2 (i.e. in the context
of C2 ) between foo and another part typed by some other classifier in the
same way that every other relationship (or element) is created.
( Not directly between C1 and C2 as mentioned previously )
A composite structure diagram visually depicts the internal structure of
some structured classifier.
The uml editor lets you define semantically what that internal structure is.
The internal structure of C2 could have 2 parts ( ie. "foo" as mentioned
previously and some other part ) and the connector that you would create as
you would any other element.
- James.
news:7c922f789a069bdc8eb506251d854903$1@www.eclipse.org...
> editor?
> nick
Re: can't see connector [message #475849 is a reply to message #475583] Mon, 10 September 2007 07:03 Go to previous messageGo to next message
hi,
this is what I've done:
created a component c1
created port named e
stereotyped e with a stereotype
created a component c2
created a port named c
stereotyped c with a stereotype
created a property (selected c2, New child->OwnedAttribute->Property)
called the property foo, typed it with c1
created a property
called the property bar, typed it with c2
created a connector
created 2 connector ends
added foo to one of the roles and bar as the other.
is this how I should correctly connect two components within a context?
I get an error when I validate the model:
Assembly connector 'connector' must only be defined from a role end
requiring an interface to a role end providing that interface.
what am I doing wrong?
thx
Nick
Re: can't see connector [message #475851 is a reply to message #475849] Mon, 10 September 2007 16:13 Go to previous messageGo to next message
To get rid of that warning, one of the parts at the end of the connector
should "provide" an interface and the part at the other end should "require"
that same interface.
Creating required and provided interfaces was already mentioned in previous
threads.
However, that particular constraint makes "sketcthing" composite structure
diagrams very difficult and leads to other issues with communication
diagrams so in my humble opinion you could almost place lesser importance on
this particular constraint .
An issue has been raised with this constraint at the OMG. But for the time
being, if you want to be "by the book" then you should create
required\provided interfaces as mentioned.
- James.
"nick kirtley" <nickkirtley@gmail.com> wrote in message
news:bd81ef459322fb066c333999cd1e633a$1@www.eclipse.org...
> hi,
> created a property
> created a connector
> thx
> Nick
Re: can't see connector [message #476440 is a reply to message #475851] Tue, 30 October 2007 06:12 Go to previous messageGo to next message
sorry to bring this up again ;)
From this thread I learnt how to make a connector between two components.
This works fine and validates properly.
One of the components owns the connector with the connector ends role set
as properties typed by the two components. However, in this case the
'receiving' component, or c2, doesn't contain any information about the
connector. If I have two components and a connector in between then surely
the 'receiving/other' end should have a reference to the connector as well?
regards,
nick
Re: can't see connector [message #476446 is a reply to message #476440] Wed, 31 October 2007 13:56 Go to previous messageGo to next message
Hi Nick,
A connector can be "typed" by an association which is a way of providing
information about how the components typing the role's being connected are
associated. However, connectors do not have to specify a type.
The ConnectableElement::getEnds() might also be of some use in determining
'other' ends given a particular role or part that is connected.
- James.
news:1a3766f6d9d7b8c804b4d6e000f02028$1@www.eclipse.org...
> well?
> regards,
> nick
Re: can't see connector [message #476447 is a reply to message #476446] Thu, 01 November 2007 05:44 Go to previous messageGo to next message
Could you explain what you mean by typing an association using an example
with uml tree editor.
Also , my point was that the calling side of the connector contains all of
the information regarding the connector. So if I can only view the
information contained within the receiving component, how then can I tell
if it has been connected. The ConnectableElement::getEnds() only works if
you have access to the connector itself, thus the calling end.
regards,
Nick
Re: can't see connector [message #476448 is a reply to message #476447] Thu, 01 November 2007 09:39 Go to previous message
1. Not sure what you mean about "calling side of connector".
2. Also not sure what you mean by "The ConnectableElement::getEnds() only
works if
you have access to the connector itself, thus the calling end." . A
role or part is a connectable element ( not a connector ). You can call
this method if you have anything the connector is connected to (connectors
are connected to connectable elements ), and not the connector itself.
3. Typing the connector with an association involves simply setting the
connectors type.
- James.
news:69251a5827fa183519ac04b214c9ad23$1@www.eclipse.org...
> Hi
> regards,
> Nick
Re: can't see connector [message #624455 is a reply to message #475153] Tue, 21 August 2007 13:13 Go to previous message
Hi Nick,
connector.
Bogdan
> thx for any help
> Nick
Re: can't see connector [message #624457 is a reply to message #475156] Wed, 22 August 2007 05:59 Go to previous message
hi,
thx for your reply.
regards,
Nick
Re: can't see connector [message #624458 is a reply to message #475163] Wed, 22 August 2007 08:06 Go to previous message
Hi, Nick,
"partWithPort".
HTH,
Christian
Nick Kirtley wrote:
> hi,
> thx for your reply.
> regards,
> Nick
Re: can't see connector [message #624463 is a reply to message #475167] Wed, 22 August 2007 09:20 Go to previous message
- James.
> Hi, Nick,
of
> "partWithPort".
> HTH,
> Christian
> Nick Kirtley wrote:
> > hi,
> > thx for your reply.
for
> > regards,
> > Nick
Re: can't see connector [message #624542 is a reply to message #475181] Mon, 27 August 2007 05:05 Go to previous message
regards,
Nick
Re: can't see connector [message #624544 is a reply to message #475241] Mon, 27 August 2007 10:17 Go to previous message
Hi Nick,
element.
context.
- James.
> regards,
> Nick
Re: can't see connector [message #624545 is a reply to message #475244] Mon, 27 August 2007 10:58 Go to previous message
ok,
nick
Re: can't see connector [message #624546 is a reply to message #475246] Mon, 27 August 2007 15:21 Go to previous message
Hi Nick,
in agreement.
- James.
> ok,
> nick
Re: can't see connector [message #624550 is a reply to message #475247] Tue, 28 August 2007 09:55 Go to previous message
of my project.
diagram?
regards,
Nick
Re: can't see connector [message #624551 is a reply to message #475257] Tue, 28 August 2007 11:19 Go to previous message
Hi Nick,
and "Villain".
Does that help?
- James.
> of my project.
> diagram?
> regards,
> Nick
Re: can't see connector [message #624573 is a reply to message #475259] Wed, 29 August 2007 07:03 Go to previous message
Hi james,
concept into uml2.
diagram?
thx
Re: can't see connector [message #624576 is a reply to message #475355] Wed, 29 August 2007 11:32 Go to previous message
In general ....
(tree-like) editor.
- James
> Hi james,
> concept into uml2.
> diagram?
> thx
Re: can't see connector [message #624582 is a reply to message #475359] Thu, 30 August 2007 08:38 Go to previous message
thx
Nick
Re: can't see connector [message #624584 is a reply to message #475365] Thu, 30 August 2007 08:42 Go to previous message
you ;)
nick
Re: can't see connector [message #624586 is a reply to message #475366] Thu, 30 August 2007 09:26 Go to previous message
- James.
> you ;)
> nick
Re: can't see connector [message #624588 is a reply to message #475365] Thu, 30 August 2007 09:32 Go to previous message
editor.
- James.
> thx
> Nick
Re: can't see connector [message #624590 is a reply to message #475367] Thu, 30 August 2007 09:32 Go to previous message
nick
Re: can't see connector [message #624591 is a reply to message #475369] Thu, 30 August 2007 09:44 Go to previous message
Hi james,
nick
Re: can't see connector [message #624593 is a reply to message #475372] Thu, 30 August 2007 10:20 Go to previous message
You just...
type foo with C1.
- James.
> Hi james,
> nick
Re: can't see connector [message #624601 is a reply to message #475376] Fri, 31 August 2007 04:59 Go to previous message
nick
Re: can't see connector [message #624610 is a reply to message #475574] Fri, 31 August 2007 12:51 Go to previous message
- James.
> editor?
> nick
Re: can't see connector [message #624740 is a reply to message #475583] Mon, 10 September 2007 07:03 Go to previous message
hi,
created a property
created a connector
thx
Nick
Re: can't see connector [message #624742 is a reply to message #475849] Mon, 10 September 2007 16:13 Go to previous message
threads.
- James.
> hi,
> created a property
> created a connector
> thx
> Nick
Re: can't see connector [message #625343 is a reply to message #475851] Tue, 30 October 2007 06:12 Go to previous message
regards,
nick
Re: can't see connector [message #625349 is a reply to message #476440] Wed, 31 October 2007 13:56 Go to previous message
Hi Nick,
- James.
> well?
> regards,
> nick
Re: can't see connector [message #625350 is a reply to message #476446] Thu, 01 November 2007 05:44 Go to previous message
regards,
Nick
Re: can't see connector [message #625351 is a reply to message #476447] Thu, 01 November 2007 09:39 Go to previous message
works if
connectors type.
- James.
> Hi
> regards,
> Nick
Previous Topic:UML 2.2
Next Topic:[Announce] MDT UML2 2.2.0 I200711021052 is available
Current Time: Sun Jul 27 18:55:45 EDT 2025
Powered by FUDForum. Page generated in 0.33205 seconds
