Home » Modeling » UML2 » Is there a plug-in for reverse engineering a class diagram from .java files
Is there a plug-in for reverse engineering a class diagram from .java files [message #475223] Fri, 24 August 2007 12:08 Go to next message
Originally posted by: fberisha.uni-pr.edu
Could you please tell me if there is an _open_source_ plug-in that
imports .java files as a UML model.
I tried to check previous threads, and I noticed that there is such a
plug-in for Java jar files (Jar2UML), which makes me believe there is a
tool for reverse engineering a class diagram from .java source files
(which, of course, are not previously annotated for creating a model).
By searching Google I found that there are commercial plug-ins, even a
free EclipseUML by Omondo Corp., but it's not open source and requires
old versions of Eclipse, EMF and GEF.
Thank you in advance,
Faton Berisha
Re: Is there a plug-in for reverse engineering a class diagram from .java files [message #475230 is a reply to message #475223] Sun, 26 August 2007 05:56 Go to previous messageGo to next message
You can use the Java Extension of the Topcased UML Modeler
(http://gforge.enseeiht.fr/frs/?group_id=34).
It's easy to use : you just right-click on a Java Project and then you
have an action "UML Model from Java" that creates a .uml file.
David
Faton Bersha a écrit :
> Faton Berisha
Re: Is there a plug-in for reverse engineering a class diagram from .java files [message #475237 is a reply to message #475230] Sun, 26 August 2007 21:57 Go to previous message
David Sciamma wrote:
> Regards,
> David
Thank you very much, David.
I have installed and tried the extension; it seems to work fine.
Faton Berisha
Re: Is there a plug-in for reverse engineering a class diagram from .java files [message #624532 is a reply to message #475223] Sun, 26 August 2007 05:56 Go to previous message
David
> Faton Berisha
Re: Is there a plug-in for reverse engineering a class diagram from .java files [message #624535 is a reply to message #475230] Sun, 26 August 2007 21:57 Go to previous message
> Regards,
> David
Faton Berisha
Previous Topic:inStructuredNode reference
Next Topic:inStructuredNode reference
Current Time: Sun Jul 20 23:44:11 EDT 2025
Powered by FUDForum. Page generated in 1.44843 seconds
