Home » Modeling » UML2 » ecore model to uml model
ecore model to uml model [message #475183] Wed, 22 August 2007 09:20 Go to next message
Originally posted by: rmishra.tibco.com
Hi ,
I have Epackage corresponding to the ecore model ,now i want to convert
epackage to UML Model and serialize it .Can some body help me out ,if there
is any java API Which i can use --if there is ,then please let me know how
to use that---
Thanks and Regards
Raju Mishra
Re: ecore model to uml model [message #475187 is a reply to message #475183] Wed, 22 August 2007 09:25 Go to previous messageGo to next message
Raju,
Is there really a need to start a new thread given that the answer is in
the preceding thread? Given that the IDE has a working example of
this, setting a breakpoint and watching the behavior should be
sufficient for figuring out how to use this...
Raju Mishra wrote:
> Hi ,
> to use that---
> Thanks and Regards
> Raju Mishra
Re: ecore model to uml model [message #475189 is a reply to message #475187] Wed, 22 August 2007 09:35 Go to previous message
Sorry to ask the same question in different thread. I m really new to
eclipse and i have to deliver some thing so i wanted some easy way out .any
way i will put break point and see the behaviour----
thanks a lot--
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fahdgi$k8d$1@build.eclipse.org...
> Raju,
> the preceding thread? Given that the IDE has a working example of this,
> setting a breakpoint and watching the behavior should be sufficient for
> Raju Mishra wrote:
>> Hi ,
>> there
>> how
>> to use that---
>> Thanks and Regards
>> Raju Mishra
Re: ecore model to uml model [message #624465 is a reply to message #475183] Wed, 22 August 2007 09:25 Go to previous message
Raju,
Raju Mishra wrote:
> Hi ,
> to use that---
> Thanks and Regards
> Raju Mishra
Re: ecore model to uml model [message #624466 is a reply to message #475187] Wed, 22 August 2007 09:35 Go to previous message
thanks a lot--
> Raju,
> Raju Mishra wrote:
>> Hi ,
>> there
>> how
>> to use that---
>> Thanks and Regards
>> Raju Mishra
Previous Topic:ecore model to uml model
Next Topic:java API which converts Ecore object model to UML model.
Current Time: Fri Jul 25 23:43:47 EDT 2025
Powered by FUDForum. Page generated in 0.04970 seconds
