Home » Eclipse Projects » JavaServer Faces » faces-config editor content not refreshed after project is deleted and then re-created
faces-config editor content not refreshed after project is deleted and then re-created [message #475184] Wed, 07 November 2007 09:40 Go to next message
I create a dynamic web project using JSF 1.1 configuration. Then I edit
faces-config.xml using the faces-config editor and add some entries (a
managed bean, for instance).
Then I delete the project (also deleting content).
Then I re-create the project with same name and configuration.
When I open the faces-config editor, the old entries are still visible
(the managed bean, in previous example). If I open the file with another
editor, it is empty (and correct). It's only the editor view which is
not correct.
Does anyone have the same problem ? Probably a bug isn't it?
Maxime
Re: faces-config editor content not refreshed after project is deleted and then re-created [message #475185 is a reply to message #475184] Wed, 07 November 2007 11:37 Go to previous message
Thanks Maxime. This does sound like a bug. Please add to bugzilla.
Gerry Kessler
WTP JSF Tools Team
Re: faces-config editor content not refreshed after project is deleted and then re-created [message #614476 is a reply to message #475184] Wed, 07 November 2007 11:37 Go to previous message
Gerry Kessler
WTP JSF Tools Team
Previous Topic:faces-config editor content not refreshed after project is deleted and then re-created
Next Topic:Unknown Tag
Current Time: Thu Oct 16 06:22:05 EDT 2025
Powered by FUDForum. Page generated in 0.03520 seconds
