Home » Modeling » UML2 » AddVariableValueAction doubled in UML editor
AddVariableValueAction doubled in UML editor [message #475160] Wed, 22 August 2007 05:14 Go to next message
Hi All,
when I modify UMLArticle's code to create model like this:
Model model = UMLFactory.eINSTANCE.createModel();
model.setName("MyModel");
org.eclipse.uml2.uml.Class clazz = model.createOwnedClass("MyClass",
false);
Activity activity = (Activity) clazz.createOwnedBehavior(
"MyActivity", UMLPackage.Literals.ACTIVITY );
SequenceNode sequence = (SequenceNode) activity.createNode(
"MySequence", UMLPackage.Literals.SEQUENCE_NODE);
AddVariableValueAction addValue = (AddVariableValueAction)
sequence.createNode( "MyAction",
UMLPackage.Literals.ADD_VARIABLE_VALUE_ACTION);
so single AddVariableValueAction is created and I serialize it to uml
file and then open it in UML Editor I see the action doubled.
I checked that in the file it is serialized only once so it is
probably a problem of UML Editor.
Should I post it as a bug or maybe it is for some reason normal?
Krzysztof Kaczmarski
Re: AddVariableValueAction doubled in UML editor [message #475194 is a reply to message #475160] Wed, 22 August 2007 09:46 Go to previous message
Hi Krzysztof ,
You're right!
I can reproduce that simply by using the editor. Please log a bug and it
will be looked into.
( There might be some issue with the ExecutableNode and Node collections )
- James.
"Krzysztof Kaczmarski" <krzysztof_kaczmarski@o2.pl> wrote in message
news:fagup6$d5n$1@build.eclipse.org...
> Hi All,
> false);
> Regards,
Re: AddVariableValueAction doubled in UML editor [message #624468 is a reply to message #475160] Wed, 22 August 2007 09:46 Go to previous message
Hi Krzysztof ,
You're right!
- James.
> Hi All,
> false);
> Regards,
Previous Topic:java API which converts Ecore object model to UML model.
Next Topic:UML and multiple/diamond inheritance
Current Time: Sat Jul 26 22:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.24577 seconds
