Home » Eclipse Projects » JavaServer Faces » Faces Config editor
Faces Config editor [message #474957] Sun, 05 August 2007 03:55 Go to next message
Can I disable Faces Config Editor and use the plain xml editor with its
tree view?
kuvera
Re: Faces Config editor [message #474960 is a reply to message #474957] Mon, 06 August 2007 13:02 Go to previous messageGo to next message
I'm not sure about disabling, but by using the "Open with" context menu,
you could choose the XML editor.
Why not simply switch to Source view within the Faces Config Editor?
Gerry Kessler
WTP JSF Tools Team
Re: Faces Config editor [message #474961 is a reply to message #474957] Mon, 06 August 2007 14:08 Go to previous message
If you want to make the XML editor default for all such files you can go
to Windows->Preferences->General->Editors->File Associations and select
"*.xml" in the top list, "XML Editor" in the bottom list and select the
Make Default button. This makes the standard XML editor the default one
that is opened on a faces-config.xml file when you double click it in the
Navigator.
Note however, that for all XML files that have different associated
editors, you will now need to right-click on the file navigator if you
want to get a different editor.
--Cam
Re: Faces Config editor [message #613269 is a reply to message #474957] Mon, 06 August 2007 13:02 Go to previous message
Gerry Kessler
WTP JSF Tools Team
Re: Faces Config editor [message #613271 is a reply to message #474957] Mon, 06 August 2007 14:08 Go to previous message
Navigator.
--Cam
Previous Topic:Customizing palette in WPE
Next Topic:open up faces-config.xml throws exception
Current Time: Sat Jul 26 01:16:43 EDT 2025
Powered by FUDForum. Page generated in 0.04320 seconds
