Home » Eclipse Projects » JavaServer Faces » Servlet FacesServlet Exception
Servlet FacesServlet Exception [message #474946] Wed, 25 July 2007 19:51 Go to next message
Originally posted by: somecsian.yahoo.com
Hi all,
I am using Eclipse Europa to develop JSF app. by jsf1.2 implementation on
Tomcat server 6.0.
I tried to run the JSFTutorial app. which in Eclipse help. I followed all
instructions But Servlet FacesServlet is not availble Exception was thrwon.
If any one faced this problem before please, give me the solution.
Re: Servlet FacesServlet Exception [message #474947 is a reply to message #474946] Wed, 25 July 2007 19:56 Go to previous messageGo to next message
I was asked from Raghu in wtp-jsf-dev mailing list
" Are you getting this error when you select 'Run on Server.'on the
login.jsp page as described in the section, Testing the JSF JSP Page? "
Yes this error occurs in this case.
Re: Servlet FacesServlet Exception [message #474950 is a reply to message #474947] Tue, 31 July 2007 00:35 Go to previous messageGo to next message
Can you provide more information? What was the exception?
--Cam
Re: Servlet FacesServlet Exception [message #474956 is a reply to message #474950] Sat, 04 August 2007 14:36 Go to previous messageGo to next message
When i was starting the server before running the app. the server would
start But, Exceptions That i writed in the end of message is thrown.
When I was running the app. This error appeared
HTTP Status 404 - Servlet Faces Servlet is not available
type Status report
message Servlet Faces Servlet is not available
description The requested resource (Servlet Faces Servlet is not
available) is not available.
org.apache.catalina.loader.StandardClassLoader@110d81b
javax.faces.webapp.FacesServlet
java.lang.ClassNotFoundException: javax.faces.webapp.FacesServlet
at org.apache.catalina.loader.WebappClassLoader.loadClass
(WebappClassLoader.java:1358)
(WebappClassLoader.java:1204)
at org.apache.catalina.core.StandardWrapper.loadServlet
(StandardWrapper.java:1083)
(StandardWrapper.java:981)
at org.apache.catalina.core.StandardContext.loadOnStartup
(StandardContext.java:4042)
at org.apache.catalina.core.StandardContext.start
(StandardContext.java:4348)
at org.apache.catalina.core.ContainerBase.start
(ContainerBase.java:1045)
at org.apache.catalina.core.StandardHost.start
(StandardHost.java:719)
at org.apache.catalina.core.StandardEngine.start
(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start
(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start
(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start
(Catalina.java:566)
at sun.reflect.NativeMethodAccessorImpl.invoke0
(Native Method)
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
04/08/2007 09:12:45 م org.apache.catalina.core.StandardContext
loadOnStartup
SEVERE: Servlet /JSFTutorial threw load() exception
(Catalina.java:566)
(Native Method)
Re: Servlet FacesServlet Exception [message #475003 is a reply to message #474956] Mon, 06 August 2007 14:15 Go to previous messageGo to next message
It appears that the jars for the JSF runtime are not being deployed to the
server. How have you included the runtime jars in the project? If you
have used a JSF library, try right-clicking on the project and go to
project properties. Go to J2EE Module Dependencies in the properties
dialog. Make sure the the check box for your JSF library (or for the
runtime jars if you added them to the project in a different way) are
selected (checked). This ensures they will be deployed with the
application.
Also, the Tomcat server adapter is sometimes fussy. From the Servers
view, right click on the Tomcat server instance and select "Clean"
followed by "Clean Tomcat Working Directory". Then redeploy.
--Cam
Re: Servlet FacesServlet Exception [message #475009 is a reply to message #475003] Tue, 07 August 2007 16:37 Go to previous message
Thanks very much, Now i can go on JSF.
Re: Servlet FacesServlet Exception [message #613248 is a reply to message #474946] Wed, 25 July 2007 19:56 Go to previous message
Re: Servlet FacesServlet Exception [message #613253 is a reply to message #474947] Tue, 31 July 2007 00:35 Go to previous message
--Cam
Re: Servlet FacesServlet Exception [message #613263 is a reply to message #474950] Sat, 04 August 2007 14:36 Go to previous message
type Status report
(Catalina.java:566)
(Native Method)
loadOnStartup
(Catalina.java:566)
(Native Method)
Re: Servlet FacesServlet Exception [message #613861 is a reply to message #474956] Mon, 06 August 2007 14:15 Go to previous message
application.
--Cam
Re: Servlet FacesServlet Exception [message #613867 is a reply to message #475003] Tue, 07 August 2007 16:37 Go to previous message
Previous Topic:open up faces-config.xml throws exception
Next Topic:open up faces-config.xml throws exception
Current Time: Sat Jul 26 02:46:32 EDT 2025
Powered by FUDForum. Page generated in 0.06539 seconds
