Internationalize RCP help [message #474909] |
Mon, 15 December 2008 08:41  |
Hello everybody,
is there a way to internationalize the RCP help when not run in
infocenter mode? (Eclipse 3.3.2 on Windows XP). I tried
org.eclipse.help.base/locales=de but this only seems to apply to
infocenter mode.
Kind regards
Bianca
Re: Internationalize RCP help [message #622693 is a reply to message #474909] |
Mon, 15 December 2008 15:43  |
An RCP can be internationalized, it works slightly different from the
infocenter. In either the creation of content is the same. First you set
up the documents for the default locale (for the Eclipse platform this
is english) and create nl directories for each other language supported
such as nl/de, nl/fr etc.
An infocenter will determine the local of the client either from the
lang parameter (help/index.jsp?lang=de will show the German version) or
from the locale in the request header. This way clients will see the
contents in the language which their browser is using.
An RCP or Eclipse application will get the locale from the system on
which it is running. What this means is that if my machine's OS has the
locale set to German and I am running an RCP with a help application the
pages will use the German locale even if the help system was accessed
from another system.
Does this answer your question?
Chris
Bianca wrote:
> Hello everybody,
> infocenter mode.
> Kind regards
> Bianca
Re: Internationalize RCP help [message #622697 is a reply to message #474910] |
Tue, 16 December 2008 04:46  |
Thank you Chris for your answer. It doesn't completely answer my
question though. I'm sorry if I was a little imprecise when I posted it.
What I don't understand is how to internationalize the tooltips etc. for
the help. For example it says "Show all topics" when I hover over the
appropriate button. And the search is also completely in English. I'd
like to be able to internationalize all the tooltips and the search in
the top of the window. Is there a way to do this? Maybe I'm missing
something...
Kind regards
Bianca
Re: Internationalize RCP help [message #622699 is a reply to message #474912] |
Tue, 16 December 2008 05:14  |
> something...
You need to add the BabelLanguagePack-eclipse for your language.
It can be found here:
http://download.eclipse.org/technology/babel/babel_language_ packs/
(I found this URL by chance!)
Patrick
FUDForum. Page generated in 0.04603 seconds
