Home » Modeling » UML2 » Migrating own Metamodel based on UML2.0.3
Migrating own Metamodel based on UML2.0.3 [message #474881] Mon, 06 August 2007 10:01 Go to next message
Hi all
Recently I developed a metamodel for a language which imported the
UML.merged.uml (V2.0.3) whith RSA. The exported .uml doesn't work anymore
with the genmodel from UML2.1
How can I handle this problem? Especially the RSA is not able to read the
new 2.1.0 UML.merged.uml. Is there a way to do this? How is the
UML.merged.uml in the UML2.1.x generated?
Thanks for any help
Andreas
Re: Migrating own Metamodel based on UML2.0.3 [message #474987 is a reply to message #474881] Tue, 07 August 2007 15:24 Go to previous messageGo to next message
Hi Andreas,
- For some background info on the metamodel changes you might want to have a
look at
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 1_Migration_Guide/guide.html
- The latest UML2 2.0.4 can open up the UML2 2.1 version as well as the
older format so you might want to try to move to the 2.0.4 .
- Let me know what version of RSA you are using and I should be able to give
you instructions on how to "teach" RSA to open up the model you have.
- By the way, UML.merged.uml is generated by doing a package merge on
UML.uml but I think taking this approach would be problematic.
- James.
"Andreas Morf" <andreas_morf@bluewin.ch> wrote in message
news:f979jd$2ae$1@build.eclipse.org...
> Hi all
> Thanks for any help
> Andreas
Re: Migrating own Metamodel based on UML2.0.3 [message #474992 is a reply to message #474987] Wed, 08 August 2007 08:11 Go to previous messageGo to next message
Hi James
Thanks for your answer!
A week ago, I updated my RSA to 7.0.3 - My workflow in the project is to
design my metamodel with RSA and export it as .uml continuing with Eclipse
genmodel.
Therefore I need to load the new (nsURI as 2.1.0) UML.merged.uml to RSA to
update my metamodel.
Can you provide me with instructions for RSA to load the model - I already
tried to load UML2 2.0.4 with the configuration manager but didn't work...
Andreas
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f9agtp$17a$2@build.eclipse.org...
> Hi Andreas,
> a
> look at
> give
> - James.
>> Hi all
>> Thanks for any help
>> Andreas
Re: Migrating own Metamodel based on UML2.0.3 [message #475002 is a reply to message #474992] Thu, 09 August 2007 15:25 Go to previous message
Hi Andreas,
Replacing plugins in RSA is a bit tricky. I'll send you some instructions
directly to your email :)
- James.
news:f9cbtu$2p6$1@build.eclipse.org...
> Hi James
> genmodel.
> Andreas
> > Hi Andreas,
have
> > a
> > look at
> > give
> > - James.
> >> Hi all
anymore
the
> >> Thanks for any help
> >> Andreas
Re: Migrating own Metamodel based on UML2.0.3 [message #624262 is a reply to message #474881] Tue, 07 August 2007 15:24 Go to previous message
Hi Andreas,
look at
- James.
> Hi all
> Thanks for any help
> Andreas
Re: Migrating own Metamodel based on UML2.0.3 [message #624362 is a reply to message #474987] Wed, 08 August 2007 08:11 Go to previous message
Hi James
genmodel.
Andreas
> Hi Andreas,
> a
> look at
> give
> - James.
>> Hi all
>> Thanks for any help
>> Andreas
Re: Migrating own Metamodel based on UML2.0.3 [message #624382 is a reply to message #474992] Thu, 09 August 2007 15:25 Go to previous message
Hi Andreas,
- James.
> Hi James
> genmodel.
> Andreas
> > Hi Andreas,
have
> > a
> > look at
> > give
> > - James.
> >> Hi all
anymore
the
> >> Thanks for any help
> >> Andreas
Previous Topic:wsdl2uml
Next Topic:RE: Activity Diagram
Current Time: Wed Jul 23 19:32:17 EDT 2025
Powered by FUDForum. Page generated in 0.05483 seconds
