Home » Modeling » UML2 » How to retrieve reference data by giving a class
How to retrieve reference data by giving a class [message #474875] Thu, 02 August 2007 20:33 Go to next message
Hi All:
In UML model, by giving user defined DataType Class, is there a way to
know where the datatype class was referenced?
For example:
I have a defined dataype class: TypeA, and it was used in following class
in the model:
ClassA.attribute1::TypeA
ClassB.attribute2::TypeA
Is there a simple approach that I can retrieve the list of
ClassA.attribute1 and ClassB.attribute2 that TypeA was referenced?
Currently, I'm using emf.query to perform the check, but performance is
poor...
Thanks in advance.
JD
Re: How to retrieve reference data by giving a class [message #474879 is a reply to message #474875] Fri, 03 August 2007 07:47 Go to previous messageGo to next message
JD,
I think you can determine this efficiently from
CacheAdapter.INSTANCE.getInverseReferences but note that this will only
find references from models that are loaded into memory...
JD wrote:
> Hi All:
> to know where the datatype class was referenced?
> For example: I have a defined dataype class: TypeA, and it was used in
> following class in the model:
> is poor...
> Thanks in advance.
> JD
Re: How to retrieve reference data by giving a class [message #474985 is a reply to message #474879] Mon, 06 August 2007 15:24 Go to previous message
Thanks Ed. I'm keep leaning everyday!
Ed Merks wrote:
> JD,
> JD wrote:
>> Hi All:
>> is poor...
>> Thanks in advance.
>> JD
Re: How to retrieve reference data by giving a class [message #624255 is a reply to message #474875] Fri, 03 August 2007 07:47 Go to previous message
JD,
JD wrote:
> Hi All:
> is poor...
> Thanks in advance.
> JD
Re: How to retrieve reference data by giving a class [message #624260 is a reply to message #474879] Mon, 06 August 2007 15:24 Go to previous message
Ed Merks wrote:
> JD,
> JD wrote:
>> Hi All:
>> is poor...
>> Thanks in advance.
>> JD
Previous Topic:What the impact of changing applied UML profile
Next Topic:CacheAdapter Memory Leak
Current Time: Fri Jul 18 13:50:09 EDT 2025
Powered by FUDForum. Page generated in 0.07777 seconds
