Home » Eclipse Projects » Platform - User Assistance (UA) » Spuriour error message in nl tocs
Spuriour error message in nl tocs [message #474800] Tue, 18 November 2008 11:35 Go to next message
This is a multipart message in MIME format.
--=_alternative 005B27FF80257505_=
Content-Type: text/plain; charset="US-ASCII"
I am getting the following error mesage
File test2.html referenced by a topic doesn't exist
Both the test2.html and toc.xml file are both in the nl/fr folder in a
fragment project to hold the french translation of the help.
I have a toc extension declared in the plugin although it does not seem to
make any difference if I remove it (I can't find any documentation which
says if I need to re-define it in the fragment plugin.xml or not).
In fact I was just re-checking to make sure the primary true/fale does not
make any difference and now I have the error message twice in the error
list, cleaning the project does not remove any of the entries.
Any suggestions welcome, it is going to make keeping track of what is
translated tricky when it is reporting things that are done.
<?xml version="1.0" encoding="utf-8"?>
<?NLS TYPE="org.eclipse.help.toc"?>
<toc label="main" topic="test1.html">
<topic href="test2.html" label="New topic 2"/>
</toc>
C:\workspaces\swb\com.mitel.pricelist.help.fr\nl\fr>dir
Volume in drive C has no label.
Volume Serial Number is D83D-574C
Directory of C:\workspaces\swb\com.mitel.pricelist.help.fr\nl\fr
18/11/2008 16:23 <DIR> .
18/11/2008 16:23 <DIR> ..
07/05/2008 08:31 3,424 test1.html
07/05/2008 08:31 3,424 test2.html
18/11/2008 16:26 175 toc.xml
3 File(s) 7,023 bytes
2 Dir(s) 10,524,393,472 bytes free
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I am getting the following error mesage
</font>
<br>
<br><font size=2 face="sans-serif">File test2.html referenced by a topic
doesn't exist</font>
<br>
<br><font size=2 face="sans-serif">Both the test2.html and toc.xml file
are both in the nl/fr folder in a fragment project to hold the french translation
of the help.</font>
<br>
<br><font size=2 face="sans-serif">I have a toc extension declared in the
plugin although it does not seem to make any difference if I remove it
(I can't find any documentation which says if I need to re-define it in
the fragment plugin.xml or not).</font>
<br>
<br><font size=2 face="sans-serif">In fact I was just re-checking to make
sure the primary true/fale does not make any difference and now I have
the error message twice in the error list, cleaning the project does not
remove any of the entries.</font>
<br>
<br><font size=2 face="sans-serif">Any suggestions welcome, it is going
to make keeping track of what is translated tricky when it is reporting
things that are done.</font>
<br>
<br><font size=2 color=#808080 face="Courier New">&lt;?xml version=&quot;1.0&quot;
encoding=&quot;utf-8&quot;?&gt;</font>
<br><font size=2 color=#808080 face="Courier New">&lt;?NLS TYPE=&quot;org.eclipse.help.toc&quot;?&gt;</font >
<br><font size=2 color=#000080 face="Courier New">&lt;toc</font><font size=2 face="Courier New">
</font><font size=2 color=#000080 face="Courier New">label=</font><font size=2 color=#008000 face="Courier New">&quot;main&quot;</font><font size=2 face="Courier New">
</font><font size=2 color=#000080 face="Courier New">topic=</font><font size=2 color=#008000 face="Courier New">&quot;test1.html&quot;</font><font size=2 color=#000080 face="Courier New">&gt;</font>
<br><font size=2 face="Courier New">&nbsp; &nbsp;</font><font size=2 color=#000080 face="Courier New">&lt;topic</font><font size=2 face="Courier New">
</font><font size=2 color=#000080 face="Courier New">href=</font><font size=2 color=#008000 face="Courier New">&quot;test2.html&quot;</font><font size=2 face="Courier New">
</font><font size=2 color=#000080 face="Courier New">label=</font><font size=2 color=#008000 face="Courier New">&quot;New
topic 2&quot;</font><font size=2 color=#000080 face="Courier New">/&gt;</font>
<br><font size=2 color=#000080 face="Courier New">&lt;/toc&gt;</font>
<br>
<br>
<br><font size=2 face="sans-serif"> C:\workspaces\swb\com.mitel.pricelist.help.fr\nl\fr&gt;d ir </font>
<br><font size=2 face="sans-serif">&nbsp;Volume in drive C has no label.</font>
<br><font size=2 face="sans-serif">&nbsp;Volume Serial Number is D83D-574C</font>
<br>
<br><font size=2 face="sans-serif">&nbsp;Directory of C:\workspaces\swb\com.mitel.pricelist.help.fr\nl\fr</font>
<br>
<br><font size=2 face="sans-serif">18/11/2008 &nbsp;16:23 &nbsp; &nbsp;&lt;DIR&gt;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp;.</font>
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp;..</font>
<br><font size=2 face="sans-serif">07/05/2008 &nbsp;08:31 &nbsp; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; 3,424 test1.html</font>
&nbsp; &nbsp; &nbsp; &nbsp; 3,424 test2.html</font>
<br><font size=2 face="sans-serif">18/11/2008 &nbsp;16:26 &nbsp; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; 175 toc.xml</font>
<br><font size=2 face="sans-serif">&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;
&nbsp; &nbsp;3 File(s) &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;7,023 bytes</font>
&nbsp; &nbsp;2 Dir(s) &nbsp;10,524,393,472 bytes free</font>
<br>
--=_alternative 005B27FF80257505_=--
Re: Spuriour error message in nl tocs [message #474825 is a reply to message #474800] Wed, 19 November 2008 15:56 Go to previous message
This message shows up when the search index is built, which happens when
a search is performed or F1 is hit. What it indicates is that the toc
is referencing a file that doesn't exist. What I can't tell from the
description is whether it was trying to build the search index for "fr"
or for the default locale. It may be that there is an inconsistency in
the default locale.
> to make any difference if I remove it (I can't find any documentation
> which says if I need to re-define it in the fragment plugin.xml or not).
> not make any difference and now I have the error message twice in the
> error list, cleaning the project does not remove any of the entries.
> </toc>
Re: Spuriour error message in nl tocs [message #622208 is a reply to message #474800] Wed, 19 November 2008 15:56 Go to previous message
the default locale.
> </toc>
Previous Topic:Adding Help view to a perspective
Next Topic:How to remove the default icon of a <link> when contributing an Intro
Current Time: Fri Jul 18 17:07:14 EDT 2025
Powered by FUDForum. Page generated in 0.03540 seconds
