XMI Import/Export [message #474683] |
Mon, 14 July 2008 03:46  |
I'm new to eclipse uml2tools. Today I installed uml tools using the update
manager. Now I'm able to create UML diagrams. However I don't find any
option to import the xmi file or export the diagram as xmi. Please let me
know how to import and export xmi using uml tools.
Thanks and Regards,
Hari
Re: XMI Import/Export [message #474688 is a reply to message #474687] |
Tue, 15 July 2008 02:15  |
Dave Carlson wrote:
> The .uml file does use an Eclipse specific URI and maybe several minor
> extensions beyond the OMG standard XMI. To get an OMG standard XMI file:
> * open your .uml model using the sample UML editor (Open With > UML Model
> Editor)
> * File > Save As.. and enter a file name with .xmi file extension
> As Rafael said, other tool compliance varies. Note that this XMI file is
> for XMI version 2.1 and UML version 2.1.1 (the latest versions of each)
> Regards,
> Dave Carlson
Thank you Dave!!
Re: XMI Import/Export [message #621261 is a reply to message #474683] |
Mon, 14 July 2008 04:23  |
The model file (extension *.uml2) is already persisted in XMI. Try
opening it with a text editor and inspect the XML markup. Whether other
tools that also "speak" XMI will be able to read this file, is a very
different matter.
For tools that are known to be compatible with Eclipse UML2, take a look at:
http://wiki.eclipse.org/MDT-UML2-Tool-Compatibility
Rafael
Hari wrote:
> update manager. Now I'm able to create UML diagrams. However I don't
> find any option to import the xmi file or export the diagram as xmi.
> Please let me know how to import and export xmi using uml tools.
> Thanks and Regards,
> Hari
Re: XMI Import/Export [message #621266 is a reply to message #474684] |
Mon, 14 July 2008 19:18  |
Editor)
Dave Carlson
"Rafael Chaves" <rafael@abstratt.com> wrote in message
news:g5f2e0$kq0$1@build.eclipse.org...
> The model file (extension *.uml2) is already persisted in XMI. Try opening
> it with a text editor and inspect the XML markup. Whether other tools that
> also "speak" XMI will be able to read this file, is a very different
> matter.
> at:
> Cheers,
> Rafael
> Hari wrote:
>> Hi,
>> update manager. Now I'm able to create UML diagrams. However I don't find
>> any option to import the xmi file or export the diagram as xmi. Please
>> Thanks and Regards,
>> Hari
Re: XMI Import/Export [message #621267 is a reply to message #474687] |
> Editor)
> Regards,
> Dave Carlson
Thank you Dave!!
FUDForum. Page generated in 0.06185 seconds
