Home » Eclipse Projects » JavaServer Faces » Missing the Visual Page Designer Feature in WTP 2.0 - default configuration?
Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474291] Fri, 08 June 2007 05:57 Go to next message
Originally posted by: joachim.fischer.email.freenet.de
Hello Eclipse WTP Newsgroup,
excuse me, can you help me?
I look for help, because I can
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474293 is a reply to message #474291] Fri, 08 June 2007 06:55 Go to previous messageGo to next message
Hello I am again,
Now I found the right Editor "Visual Page Designer" for JSPs.
I was blind to read the newsgroup, but what can you say to the sometimes
"signed" Plugins.
Have to be all with a green check-symbol in Windows XP?
May be at my configuration are errors or whats the meaning of "signed"
"Fischer, Joachim" <joachim.fischer.email@freenet.de> schrieb im Newsbeitrag
news:f4ba27$2vs$1@build.eclipse.org...
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474294 is a reply to message #474291] Fri, 08 June 2007 06:57 Go to previous messageGo to next message
Hello I am again,
"signed" Plugins.
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474621 is a reply to message #474294] Fri, 08 June 2007 13:37 Go to previous messageGo to next message
> "signed" Plugins.
Where are you seeing this?
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474624 is a reply to message #474621] Fri, 08 June 2007 16:45 Go to previous messageGo to next message
Oh sorry, they are in "HELP" -> "About ECLIPSE SDK" -> "Plug-in Details",
in Eclipse 3.3RC1. There are the status of the Plug-Ins.
Now I tried Eclipse 3.3RC2 and there are some little crosses behind a medal.
Is that correct?
"Cameron Bateman" <cameron.bateman@oracle.com> schrieb im Newsbeitrag
news:64f285c03b7312f5df2a7343c4a66573$1@www.eclipse.org...
>> "signed" Plugins.
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474625 is a reply to message #474624] Fri, 08 June 2007 19:07 Go to previous messageGo to next message
> Is that correct?
I don't know if it is correct, I seem to have a lot of unsigned bundles
and don't have an problems. I would check to make sure that the versions
you are using are correct. The versions of the dependencies (GEF, EMF
etc.) that you listed do not appear to be line up with what is on the web
page link for RC2 that you posted.
If there are actual problems, you will see errors in Help->Software
Updates->Manage Configuration. Be sure to click the action button for
"Show disabled features".
--Cam
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #474626 is a reply to message #474625] Sat, 09 June 2007 03:33 Go to previous messageGo to next message
Hello Cameron,
thanks for your answers.
I have identified a problem with the
" org.eclipse.datatools.sqltools.sqleditor.attachProfileAction ".
I got the problem, when I tried to work through the Cheat Sheets for JPA
"Create a JPA"
in the first step:
Setup the Environment -> click to perform.
So the view in "Help -> About Eclipse -> Plugin Details" at the topic
Eclipse Data Tools Platform SQL Editor has a cross behind the medal :-(
>> Details",
>> medal. Is that correct?
> --Cam
What is "signed" plugin [message #474628 is a reply to message #474626] Sun, 10 June 2007 11:54 Go to previous message
"Signed" (i.e. "have digital signature intact") has nothing to do with
plugin stability, compatability or anything else. It is some kind of
plugin authorization mechanism for eclipse. If i understand it right,
eclipse.org should be organization that can add digital signature to
plugin. It tells eclipse (IDE this time) that plugin that name itself say
"org.apache.someplug" is really "org.apache.someplug" and not
"net.hacks.fraudplug".
The same way you can read letter from your friend that don't have his/her
signature. Without signature the letter can still be written by him/her,
but you cannot be 100% sure.
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #611595 is a reply to message #474291] Fri, 08 June 2007 06:55 Go to previous message
Hello I am again,
"signed" Plugins.
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #611598 is a reply to message #474291] Fri, 08 June 2007 06:57 Go to previous message
Hello I am again,
"signed" Plugins.
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #611829 is a reply to message #474294] Fri, 08 June 2007 13:37 Go to previous message
> "signed" Plugins.
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #611838 is a reply to message #474621] Fri, 08 June 2007 16:45 Go to previous message
Is that correct?
>> "signed" Plugins.
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #611841 is a reply to message #474624] Fri, 08 June 2007 19:07 Go to previous message
> Is that correct?
--Cam
Re: Missing the Visual Page Designer Feature in WTP 2.0 - default configuration? [message #611844 is a reply to message #474625] Sat, 09 June 2007 03:33 Go to previous message
Hello Cameron,
"Create a JPA"
in the first step:
>> Details",
> --Cam
What is "signed" plugin [message #611849 is a reply to message #474626] Sun, 10 June 2007 11:54 Go to previous message
Previous Topic:Eclipse 3.3RC2 WTP 2.0 RC2 - Data Source Explorer -
Next Topic:Firefox working, but not with IE
Current Time: Wed Jul 23 20:24:14 EDT 2025
Powered by FUDForum. Page generated in 0.04593 seconds
