Home » Eclipse Projects » Platform - User Assistance (UA) » Re: eclipse help system
Re: eclipse help system [message #474555] Thu, 02 October 2008 11:27 Go to next message
Copying this to the eclipse.platform.ua newsgroup where questions about
Help usually go.
On 10/2/2008 8:23 AM, Giara wrote:
> hi,
> How can i manage eclipse help system to show only my own contents.
> thanks
> giara
Re: eclipse help system [message #474558 is a reply to message #474555] Mon, 06 October 2008 17:34 Go to previous messageGo to next message
I'm guessing that you have your own product based on Eclipse. There are
a couple of options:
1. Remove the plugins which contribute help to Eclipse from the eclipse
plugins directory. There 5 plugins all have a plugin name ending in .doc.
OR
2. Use the HELP_DATA customization. See
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/ua_help_setup_preferences.htm
and
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.isv/guide/ua_help_setup_help_data.htm
> Help usually go.
>> hi,
>> thanks
>> giara
Re: eclipse help system [message #474559 is a reply to message #474558] Tue, 07 October 2008 08:12 Go to previous messageGo to next message
Originally posted by: grazmadze.napr.gov.ge
Thank you very much Chris. I extracted the content of
org.eclipse.help.base jar file to change help_home.html.
Is it possible to override the default help_home.html
file without changing it?
> OR
> and
>> about Help usually go.
>>> hi,
>>> thanks
>>> giara
Re: eclipse help system [message #474600 is a reply to message #474559] Tue, 07 October 2008 12:33 Go to previous messageGo to next message
Yes, you can override it. Here's an example from the UA test suite of
how to customize various properties including help_home.
Scenario D: Customization
D1: Help preferences
Create a file plugin_customization.ini in the root of Eclipse
installation. Edit the file and paste the following key/values pairs:
org.eclipse.help/baseTOCS=/org.eclipse.platform.doc.isv/toc. xml,/org.eclipse.jdt.doc.isv/toc.xml
org.eclipse.help/ignoredTOCS=/org.eclipse.platform.doc.user/ toc.xml,/org.eclipse.jdt.doc.user/toc.xml,/org.eclipse.pde.d oc.user/toc.xml
org.eclipse.help/HELP_DATA=
org.eclipse.help.base/topic_css=/org.eclipse.ua.tests/non_ju nit/css/topic.css
org.eclipse.help.base/nav_css=/org.eclipse.ua.tests/non_juni t/css/nav.css
org.eclipse.help.base/narrow_css=/org.eclipse.ua.tests/non_j unit/css/narrow.css
org.eclipse.help.base/disabled_css=/org.eclipse.ua.tests/non _junit/css/disabled.css
org.eclipse.help.base/help_home=http://www.eclipse.org
org.eclipse.help.base/banner=/org.eclipse.help.webapp/advanc ed/banner.html
org.eclipse.help.base/banner_height=60
org.eclipse.help.base/linksView=false
org.eclipse.help.base/bookmarksView=false
org.eclipse.help.base/windowTitlePrefix=false
org.eclipse.help.base/advanced.toolbarBackground=green
org.eclipse.help.base/advanced.viewBackground=yellow
org.eclipse.help.base/advanced.toolbarFont=bold 1.0em sans-serif
org.eclipse.help.base/advanced.viewFont=italic 1.0em sans-serif
org.eclipse.help.base/showDisabledActivityTopics=never
org.eclipse.help.base/activeHelp=false
<!-- You can skip this step
Download the eclipse automated test framework and install into your
Eclipse installation.
Download the eclipse automated tests and copy the plugin
org.eclipse.ua.tests into your Eclipse plugins directory.
Launch Eclipse, pointing to the preferences customization, e.g. eclipse
-pluginCustomization plugin_customization.ini
From the workbench menu: Help->Help Contents. This should open the help
browser. Verify existence of banner frame above search toolbar.
The page displayed in the content frame should be eclipse.org page.
There should be only two Eclipse books displayed Plugin Developer Guide
and JDT Development Guide, in that order. Other Eclipse books should not
appear.
Search for "workbench". Verify there are no hits from Workbench User
Guide that is not present.
Verify there is only Contents, Index and Search tabs at the bottom of
navigation frame, other views (Links and Bookmarks) are not present.
Verify the browser title shows product name.
Re: eclipse help system [message #474601 is a reply to message #474600] Wed, 08 October 2008 08:16 Go to previous messageGo to next message
Hi Chris. I tried to use plugin_customization.ini with only line:
org.eclipse.help.base/help_home = /help/my_help_home.html
where 'help' is a folder in eclipse's plugins folder. I got
'The topic that you have requested is not available. The link may be
wrong, or you may not have the corresponding product feature installed.
This online help only includes documentation for features that are
installed.'
Can't I use simple file instead of a valid URL?
We are going to use only eclipse help system. We started with this article
http://www-128.ibm.com/developerworks/opensource/library/os- echelp/index.html
Thanks.
> appear.
Re: eclipse help system [message #474602 is a reply to message #474601] Wed, 08 October 2008 17:57 Go to previous messageGo to next message
If you do something like this
org.eclipse.help.base/help_home = /<plugin_name>/<path_within_plugin>
it should work for you.
> installed.'
> Thanks.
Re: eclipse help system [message #474603 is a reply to message #474602] Thu, 09 October 2008 08:22 Go to previous messageGo to next message
Hi Chris,
unfortunately it does not work for me. I got the same warning.
Here is directory hierarchy and files I referred
c:\
---- eclipse
|----- plugins
|----- org.eclipse.help.base_3.3.1.v20070813_33x
|----- doc
help_home.html
org.eclipse.help.base_3.3.1.v20070813_33x.jar
plugin_customization.ini file content is
org.eclipse.help.base/help_home=/org.eclipse.help.base_3.3.1 .v20070813_33x/doc/help_home.html
If I write path with some backslash e.g.
org.eclipse.help.base/help_home=\help
I get
HTTP ERROR: 404
ProxyServlet: /help/topichelp
RequestURI=/help/topichelp
Powered by Jetty://
If I keep empty right side of '=', I get empty welcome page without
content and any warning.
And with any valid URL I get web page content.
Thank you for time and attention.
Re: eclipse help system [message #474606 is a reply to message #474603] Thu, 09 October 2008 15:59 Go to previous messageGo to next message
Try
org.eclipse.help.base/help_home=/org.eclipse.help.base/doc/h elp_home.html
instead of
help uses the id of the plugin, not the name of the folder or jar file
where it lives.
Giara wrote:
> Hi Chris,
> c:\
> ---- eclipse
> |----- plugins
> |----- doc
> help_home.html
> I get
> HTTP ERROR: 404
> Powered by Jetty://
Re: eclipse help system [message #474612 is a reply to message #474606] Mon, 13 October 2008 08:00 Go to previous messageGo to next message
Sorry, found the problem. It was a plug-in manifest issue. Thanks Chris.
> Try
> instead of
> where it lives.
Re: eclipse help system [message #474613 is a reply to message #474606] Mon, 13 October 2008 08:56 Go to previous message
Hi Chris, I forgot to mention that a plug-in manifest issue was the last
one and before I corrected plugin's id. Thank you again.
> Try
> instead of
> where it lives.
Re: eclipse help system [message #619909 is a reply to message #474555] Mon, 06 October 2008 17:34 Go to previous message
OR
and
> Help usually go.
>> hi,
>> thanks
>> giara
Re: eclipse help system [message #619911 is a reply to message #474558] Tue, 07 October 2008 08:12 Go to previous message
> OR
> and
>>> hi,
>>> thanks
>>> giara
Re: eclipse help system [message #620066 is a reply to message #474559] Tue, 07 October 2008 12:33 Go to previous message
appear.
Re: eclipse help system [message #620067 is a reply to message #474600] Wed, 08 October 2008 08:16 Go to previous message
installed.'
Thanks.
> appear.
Re: eclipse help system [message #620068 is a reply to message #474601] Wed, 08 October 2008 17:57 Go to previous message
> installed.'
> Thanks.
Re: eclipse help system [message #620069 is a reply to message #474602] Thu, 09 October 2008 08:22 Go to previous message
Hi Chris,
c:\
---- eclipse
|----- plugins
|----- doc
help_home.html
I get
HTTP ERROR: 404
Powered by Jetty://
Re: eclipse help system [message #620072 is a reply to message #474603] Thu, 09 October 2008 15:59 Go to previous message
Try
instead of
where it lives.
Giara wrote:
> Hi Chris,
> c:\
> ---- eclipse
> |----- plugins
> |----- doc
> help_home.html
> I get
> HTTP ERROR: 404
> Powered by Jetty://
Re: eclipse help system [message #620081 is a reply to message #474606] Mon, 13 October 2008 08:00 Go to previous message
> Try
> instead of
> where it lives.
Re: eclipse help system [message #620083 is a reply to message #474606] Mon, 13 October 2008 08:56 Go to previous message
> Try
> instead of
> where it lives.
Previous Topic:Where to include cheatsheets?
Next Topic:Idiots guide to adding Contextual Help
Current Time: Sat Jul 26 13:21:07 EDT 2025
Powered by FUDForum. Page generated in 0.08568 seconds
