Home » Modeling » UML2 » Interaction Messages
Interaction Messages [message #474393] Fri, 20 July 2007 10:19 Go to next message
I'm trying to understand how to form valid sequence diagrams for code
generation.
I read the previous message on messages with return value and local
variables but I still don't quite understand it.
My first question is, how to pass the below as arguments to a message.
As I understand it you can only create a ValueSpecification (and its
subclasses) as an argument to a message (with its signature as an
operation).
The specification says you can pass these as values to the message.
i) attributes of the sending lifeline.
ii) constants.
iii) symbolic values (which are wildcard values representing any legal
value).
iv) explicit parameters of the enclosing Interaction.
v) attributes of the class owning the Interaction.
For the first case, what exactly is an attribute of a sending lifeline
and how do you create and reference it as a ValueSpecification? How do I
reference as an argument an explicit parameter or an attribute of a
For return values, a previous post said to create an
InstanceSpecification that refers to a ValueSpecification (I am assuming
an InstanceValue here). The InstanceValue can then reference the
InstanceSpecification and you can set the name as the variablename and
the type as the type of the local variable. However, an
InstanceSpecification is not really local as it belongs to a package and
not an enclosing interaction or even the behaviourClassifier that the
interaction belongs to. So this looks like it is a global instance?
Also, how do you assign the return value to a class attribute that the
lifeline represents?
If someone has figured this out and can provide code I would really
appreciate it as I am finding it quite difficult to understand how these
are accomplished from both the specification and the uml2 api.
Andrew.
Re: Interaction Messages [message #474395 is a reply to message #474393] Fri, 20 July 2007 11:57 Go to previous messageGo to next message
Hi Andrew,
I'll work on a more detailed answer to this question but as a quick note I
wanted to mention that if you are hoping to do code generation from sequence
diagrams solely, I don't think that you will be successfull because of
issues with sequence diagrams ( I would encourage others to aggree/disagree
with me in this newsgroup ).
I think that ultimately you will be forced to use Activity diagrams to fully
express the details required to generate code. You can of course use a
combination of Sequence/Activity to express details for code generation (in
fact, I would think that Class/Structure/Activity/Statechart/Sequence would
all be required since each describe different aspects of code
Structure/Behavior).
It's been my experience that sequence diagrams are great for sketching but
sometimes lack ability to express minute details.
In this case, I don't think it's the UML API that is holding us back but
rather an interpretation of the spec. If we can figure this out from the
UML spec, implementing this with the UML API should be straight forward.
As I mentioned above, I will provide a more detailed answer as soon as I
work out all the details. In the meantime, I would suggest considering
Activity diagrams for code generation.
- James.
"Andrew Carton" <cartona@cs.tcd.ie> wrote in message
news:f7qg9i$qve$1@build.eclipse.org...
> generation.
> operation).
> ii) constants.
> value).
> Andrew.
Re: Interaction Messages [message #474507 is a reply to message #474395] Mon, 23 July 2007 11:40 Go to previous messageGo to next message
Hi James,
Thanks for answering. I understand that sequence diagrams are not
suitable to model the entire behaviour of a system, but I only hope to
generate code with the capabilities that they do offer. Any assistance
you could give on this I would greatly appreciate. I think you mentioned
in a previous post that there is a workaround by attaching expressions
to messages - and I am thinking of doing this - if there is no other way.
Andrew.
James Bruck wrote:
> Hi Andrew,
> - James.
>> generation.
>> operation).
>> ii) constants.
>> value).
>> Thanks,
>> Andrew.
Re: Interaction Messages [message #474509 is a reply to message #474507] Tue, 24 July 2007 07:00 Go to previous messageGo to next message
Hey,
If anyone else is looking at sequence diagrams, I have found some
unresolved issues at the OMG's UML2 RTF site relating to storing and
sending arguments with messages. The ones of particular interest:
http://www.omg.org/issues/uml2-rtf.open.html#Issue8785
http://www.omg.org/issues/uml2-rtf.open.html#Issue8786
http://www.omg.org/issues/uml2-rtf.open.html#Issue8787
http://www.omg.org/issues/uml2-rtf.open.html#Issue8788
http://www.omg.org/issues/uml2-rtf.open.html#Issue8899
http://www.omg.org/issues/uml2-rtf.open.html#Issue10591
http://www.omg.org/issues/uml2-rtf.open.html#Issue8761
I'm not sure how the OMG operates or if these will be resolved in the
UML 2.2 as there are no comments associated with them. If anyone has any
anything to add on this or has success using sequence diagrams, I'd
really be interested.
Andrew.
Ar 23/07/2007 16:40, Scríobh Andrew Carton:
> Hi James,
> Andrew.
> James Bruck wrote:
>> Hi Andrew,
>> note I
>> sequence
>> aggree/disagree
>> fully
>> generation (in
>> would
>> but
>> the
>> - James.
>>> generation.
>>> operation).
>>> ii) constants.
>>> value).
>>> Thanks,
>>> Andrew.
Re: Interaction Messages [message #474752 is a reply to message #474509] Tue, 31 July 2007 13:55 Go to previous message
Andrew,
We will try to push these issues with the OMG to see if they can't be
resolved in the UML 2.2 timeframe (which would line up with the UML2 2.2
release)...
Kenn
news:f84m3r$9dd$1@build.eclipse.org...
> Hey,
> I'm not sure how the OMG operates or if these will be resolved in the UML
> anything to add on this or has success using sequence diagrams, I'd really
> be interested.
> Regards,
> Andrew.
Re: Interaction Messages [message #623926 is a reply to message #474393] Fri, 20 July 2007 11:57 Go to previous message
Hi Andrew,
- James.
> generation.
> operation).
> ii) constants.
> value).
> Andrew.
Re: Interaction Messages [message #624043 is a reply to message #474395] Mon, 23 July 2007 11:40 Go to previous message
Hi James,
Andrew.
James Bruck wrote:
> Hi Andrew,
> - James.
>> generation.
>> operation).
>> ii) constants.
>> value).
>> Thanks,
>> Andrew.
Re: Interaction Messages [message #624045 is a reply to message #474507] Tue, 24 July 2007 07:00 Go to previous message
Hey,
Andrew.
> Hi James,
> Andrew.
> James Bruck wrote:
>> Hi Andrew,
>> note I
>> sequence
>> aggree/disagree
>> fully
>> generation (in
>> would
>> but
>> the
>> - James.
>>> generation.
>>> operation).
>>> ii) constants.
>>> value).
>>> Thanks,
>>> Andrew.
Re: Interaction Messages [message #624148 is a reply to message #474509] Tue, 31 July 2007 13:55 Go to previous message
Andrew,
release)...
Kenn
> Hey,
> be interested.
> Regards,
> Andrew.
Previous Topic:How to read uml model library from java code
Next Topic:UML2 Stereotype with extensible properties
Current Time: Sat Jul 19 03:04:14 EDT 2025
Powered by FUDForum. Page generated in 0.04393 seconds
