Home » Modeling » UML2 Tools » Show entry/exit actions in state machine diagrams
Show entry/exit actions in state machine diagrams [message #474434] Tue, 10 June 2008 04:10 Go to next message
Originally posted by: peter.fouquet.logica.com
how can I show an entry action for my state in the state machine diagram.
I can see the action only in the property view.
Kind regards
Peter
Re: Show entry/exit actions in state machine diagrams [message #474435 is a reply to message #474434] Tue, 10 June 2008 05:34 Go to previous messageGo to next message
Hi Peter,
Entry/Exit behaviors _are_ displayed in State Machine diagram editor. For
example, '15.32.State with compartments' diagram contains 'Typing Password'
which has both entry and exit behaviors. This diagram is located in 'org.eclipse.uml2.diagram.examples.clazz'
plugin in 'diagram/06-04-02/State Machines' folder. Peter, are entry/exit
actions from this sample displayed correctly in your workspace?
However, it's not possible now to create entry/exit action directly in the
diagram editor, they should be created in uml editor.
Best wishes,
Tatiana.
> Hello,
> diagram.
> Kind regards
> Peter
Re: Show entry/exit actions in state machine diagrams [message #475953 is a reply to message #474435] Wed, 26 November 2008 14:23 Go to previous messageGo to next message
Originally posted by: regent.larcheveque.asc-csa.gc.ca
I have the same problem of Peter. I am using 0.9.0M3b to be sure to use
the latest & greatest features of UML2 Tools. Actually it is possible
to create and see entry/exit points in the State Diagram Editor. But
when you create a sub-machine state that refers to a state machine that
contains entry/exit points, the Diagram does not display the
sub-machine state entry/exit points. On the other side, the UML model
contains the proper information.
What do I do wrong? What should I do to be able to display sub-machine
state entry-exit points and make connection to those points from the
container state machine?
Thanks in advance.
Regent ;-)
Tatiana Fesenko wrote:
> Hi Peter,
> For example, '15.32.State with compartments' diagram contains 'Typing
> Password' which has both entry and exit behaviors. This diagram is
> located in 'org.eclipse.uml2.diagram.examples.clazz' plugin in
> 'diagram/06-04-02/State Machines' folder. Peter, are entry/exit actions
> from this sample displayed correctly in your workspace? However, it's
> not possible now to create entry/exit action directly in the diagram
> Best wishes,
> Tatiana.
>> Hello,
>> diagram.
>> Kind regards
>> Peter
Re: Show entry/exit actions in state machine diagrams [message #475961 is a reply to message #475953] Thu, 04 December 2008 09:23 Go to previous messageGo to next message
Hi Regent,
Original message from Peter was about entry/exit actions (not points).
If you want to display entry/exit point of StateMachine on submachine state,
you should use ConnectionPointReference (UML 2.1.2, Chapter 15.3.1).
ConnectionPointReference is implemented in frame of UML2Tools. You can
create it using "entry/exit point" button and apply it to submachine state,
then select corresponding entry/exit point in statemachine reference and
ConnectionPointReference will be created.
Sergey.
"Regent L'Archeveque" <regent.larcheveque@asc-csa.gc.ca> wrote in message
news:ggk7n4$9sn$1@build.eclipse.org...
>the latest & greatest features of UML2 Tools. Actually it is possible to
>create and see entry/exit points in the State Diagram Editor. But when you
>create a sub-machine state that refers to a state machine that contains
>entry/exit points, the Diagram does not display the sub-machine state
>entry/exit points. On the other side, the UML model contains the proper
>information.
> Thanks in advance.
> Regent ;-)
Re: Show entry/exit actions in state machine diagrams [message #475966 is a reply to message #475961] Fri, 05 December 2008 13:09 Go to previous message
Ooopps. You are right. Thanks for the answer. It works now.
Regent ;-)
Sergey Gribovsky wrote:
> Hi Regent,
> Best regards,
> Sergey.
>> information.
>> Thanks in advance.
>> Regent ;-)
Re: Show entry/exit actions in state machine diagrams [message #619980 is a reply to message #474434] Tue, 10 June 2008 05:34 Go to previous message
Hi Peter,
Best wishes,
Tatiana.
> Hello,
> diagram.
> Kind regards
> Peter
Re: Show entry/exit actions in state machine diagrams [message #623291 is a reply to message #474435] Wed, 26 November 2008 14:23 Go to previous message
Thanks in advance.
Regent ;-)
> Hi Peter,
> Best wishes,
> Tatiana.
>> Hello,
>> diagram.
>> Kind regards
>> Peter
Re: Show entry/exit actions in state machine diagrams [message #623357 is a reply to message #475953] Thu, 04 December 2008 09:23 Go to previous message
Hi Regent,
Sergey.
>information.
> Thanks in advance.
> Regent ;-)
Re: Show entry/exit actions in state machine diagrams [message #623362 is a reply to message #475961] Fri, 05 December 2008 13:09 Go to previous message
Regent ;-)
> Hi Regent,
> Best regards,
> Sergey.
>> information.
>> Thanks in advance.
>> Regent ;-)
Previous Topic:[ClassD] Is it possible to show...
Next Topic:'Subactivity' in an activity within an activity diagram
Current Time: Sat Jul 26 18:17:21 EDT 2025
Powered by FUDForum. Page generated in 0.06156 seconds
