Home » Modeling » UML2 Tools » Generating editor with limited functionality
Generating editor with limited functionality [message #474413] Wed, 21 May 2008 05:38 Go to next message
Originally posted by: gingin4.gmail.com
for a project work I need to create an UML editor (probably only
implementing state machine diagrams) with limited functionality (I only
need a few tools, not the whole palette available when using the standard
UML2Tools editor).
Additionally, I want to implement some constraints to further limit or
check drawn diagrams. Finally, the diagram should be saved as a textual
UML2 representation to be used with other tools.
I tried different approaches (for example I tried using the GMF
tutorial/cheat sheet with the UML2.ecore and .genmodel files - waaaaay too
complex), but it seems that a light-weight extension with profiles would
be the best way. I found the slides and example from EclipseCon 2008
(#172), but I'm not sure on how to adapt those to my specific requirements.
It would be highly appreciated if somebody could point me into the right
direction, as I feel a bit lost at the moment. Some small steps on how to
start would be very helpful!
Best regards, Stefan
Re: Generating editor with limited functionality [message #474428 is a reply to message #474413] Tue, 03 June 2008 04:35 Go to previous messageGo to next message
Is there anybody who could give me a hint? It would be highly appreciated
as I'm still looking for a clue on how to solve my problem.
Re: Generating editor with limited functionality [message #474444 is a reply to message #474428] Sun, 15 June 2008 06:56 Go to previous messageGo to next message
Bumping one last time -- still hoping someone can give me some (any!)
advice.
If this isn't the right place to ask such a question, can somebody tell me
where it would be better suited?
BR, Stefan
Re: Generating editor with limited functionality [message #508593 is a reply to message #474444] Tue, 19 January 2010 09:59 Go to previous messageGo to next message
Hi!
it's been a long time since you've asked your question and i just found it as i'm looking to solve similar problem as the current UML2Tools state machine editor doesn't display transition labels properly and i wanted to restrict functionality too.
Did you find the solution? Or maybe someone else did?
Galina
Re: Generating editor with limited functionality [message #619841 is a reply to message #474413] Tue, 03 June 2008 04:35 Go to previous messageGo to next message
Re: Generating editor with limited functionality [message #619998 is a reply to message #474428] Sun, 15 June 2008 06:56 Go to previous messageGo to next message
advice.
BR, Stefan
Re: Generating editor with limited functionality [message #625429 is a reply to message #474444] Tue, 19 January 2010 09:59 Go to previous message
Hi!
Galina
Previous Topic:Can UML2Tool generate diagram from existing class file?
Next Topic:shape of a class
Current Time: Fri Jul 25 22:06:49 EDT 2025
Powered by FUDForum. Page generated in 0.24974 seconds
