Home » Modeling » UML2 » reuse the primitiveTypes package
reuse the primitiveTypes package [message #474273] Wed, 18 July 2007 06:23 Go to next message
I notice in the InfrastructureLibrary that the Abstractions, Constructs,
and Basics packages import the primitiveTypes package, while in the
superstructure, the kernel package merge the primitiveTypes package.
I know that the package import allows visibility for the package
elements and the package merge allows extending its features. But, I
didn't get it clear for why the Abstraction and the Constructs import
the primitiveTypes package while the kernel package merge it?
Also, in which case, I can import the primitiveTypes package and in
which case I should merge it while building a new metamodel?
Thanks in advance,
Manar
Re: reuse the primitiveTypes package [message #474387 is a reply to message #474273] Thu, 19 July 2007 10:02 Go to previous messageGo to next message
Hi Manar,
I spoke to Kenn about this so I'll try to regurgitate some of that
conversation.
The primitive types package is considered a building block and not a
language unit with its own namespace. If you want to create your own DSL
and use primitive types as defined in the primitve types package you should
merge it in.
Other packages like 'Constructs' import the primitiveTypes package because
'Constructs' also is not a language unit with its own namespace. Those
elements that want to use 'Constructs' as part of the definition of a
language (ie a DSL) (defining its own namesapce) would have to merge
PrimitiveTypes.
A quick search of open issues turned up these two.
http://www.omg.org/issues/uml2-rtf.open.html#Issue9878
http://www.omg.org/issues/uml2-rtf.open.html#Issue9180
Hope that helps.
- James.
"Manar El-Kady" <manar.elkady@gmail.com> wrote in message
news:f7kpnr$j2q$1@build.eclipse.org...
> Thanks in advance,
> Manar
Re: reuse the primitiveTypes package [message #474397 is a reply to message #474387] Sat, 21 July 2007 02:30 Go to previous message
Really, it helps me. Thanks for you and Kenn for this detailed reply.
Manar
James Bruck wrote:
> Hi Manar,
> conversation.
> merge it in.
> PrimitiveTypes.
> Hope that helps.
> - James.
>> Hi,
>> Thanks in advance,
>> Manar
Re: reuse the primitiveTypes package [message #623906 is a reply to message #474273] Thu, 19 July 2007 10:02 Go to previous message
Hi Manar,
conversation.
merge it in.
PrimitiveTypes.
Hope that helps.
- James.
> Thanks in advance,
> Manar
Re: reuse the primitiveTypes package [message #623932 is a reply to message #474387] Sat, 21 July 2007 02:30 Go to previous message
Manar
James Bruck wrote:
> Hi Manar,
> conversation.
> merge it in.
> PrimitiveTypes.
> Hope that helps.
> - James.
>> Hi,
>> Thanks in advance,
>> Manar
Previous Topic:Package merge question
Next Topic:Package merge question
Current Time: Sun Jul 27 04:07:59 EDT 2025
Powered by FUDForum. Page generated in 0.03859 seconds
