how can you write unit tests to see your dynamic content help has been processed [message #474116] |
Fri, 27 June 2008 11:13  |
One of our help plugins contains a lot of <include>.
Sometime the included documents (which are generated) have errors that
prevent the include to work.
I would like to write a junit test that launches all the help pages
which have includes and checks that they are processed succesfully.
I am happy for the unit test to just use the internal help view.
any ideas / starting points ?
Re: how can you write unit tests to see your dynamic content help has been processed [message #474127 is a reply to message #474126] |
Mon, 07 July 2008 12:26  |
Hi Quinn,
to use my approach you need to be able to write and run Eclipse Junit
tests.
There are plenty of learning resources on eclipse.org.
Quinn DuPont wrote:
> This is exactly the same funactionality that I need, however, I am not a
> Java developer. Would you be willing to share (in detail, for a
> non-developer) how this was accomplished?
> Quinn
> "Edoardo Comar" <ecomar@uk.ibm.com> wrote in message
> news:g4t6pm$5i0$1@build.eclipse.org...
>> Thanks, but for now
>> I solved the problem by launching a workbench test that
>> instead of parsing
>> InputStream istream = HelpSystem.getHelpContent(href);
>> which returns a fileinputstream without having processed the include
>> goes through the webapp that serves the help pages
>> URL helpUrl = BaseHelpSystem.resolve(href, false);
>> and from the url -> inputstream -> sax input source ...
>> does the test trick for me :-)
>> Chris Goldthorpe wrote:
>>> This ties in with an idea which I have been interested in which is to add
>>> some infrastructure in the help system for verifying content. Currently
>>> we have JUnit tests in org.eclipse.ua.tests which verify that each page
>>> in a TOC can be loaded. The class which does this is
>>> org.eclipse.ua.tests.help.toc.TocLinkChecker. It would be interesting to
>>> extend this to add more checks for each page such as checking for missing
>>> includes, images or broken interpage links. I don't have time to do this
>>> in the near future but if you would be interested in contributing the
>>> code to do the include checking I could give you pointers on how to go
>>> about it.
Re: how can you write unit tests to see your dynamic content help has been processed [message #618955 is a reply to message #474116] |
Thu, 03 July 2008 17:59  |
add some infrastructure in the help system for verifying content.
Currently we have JUnit tests in org.eclipse.ua.tests which verify that
each page in a TOC can be loaded. The class which does this is
missing includes, images or broken interpage links. I don't have time to
do this in the near future but if you would be interested in
contributing the code to do the include checking I could give you
pointers on how to go about it.
Re: how can you write unit tests to see your dynamic content help has been processed [message #618957 is a reply to message #474124] |
Mon, 07 July 2008 09:47  |
Thanks, but for now
instead of parsing
Re: how can you write unit tests to see your dynamic content help has been processed [message #618960 is a reply to message #474125] |
Mon, 07 July 2008 10:20  |
Quinn
> Thanks, but for now
> instead of parsing
>> about it.
Re: how can you write unit tests to see your dynamic content help has been processed [message #618962 is a reply to message #474126] |
Hi Quinn,
tests.
> Quinn
>> Thanks, but for now
>> instead of parsing
>>> about it.
FUDForum. Page generated in 0.30164 seconds
