content assist/validation for custom variableResolver and propertyResolver [message #473966] |
Mon, 12 March 2007 13:17  |
If a user adds a variableResolver or propertyResolver in the facesconfig
file, is it possible for him to provide the code for the content assist and
validation for his custom variableResolver and propertyResolver?
Or, how are going to support the content assist/validation for the custom
variableResolver/propertyResolver?
Thanks.
Re: content assist/validation for custom variableResolver and propertyResolver [message #474018 is a reply to message #473998] |
Wed, 28 March 2007 11:50   |
See an example in the following URL:
http://publib.boulder.ibm.com/infocenter/wsadhelp/v5r1m2/ind ex.jsp?topic=/com.ibm.etools.jsf.doc/topics/tjsflists.html
For an expression e.g., "selectitems.myBean.label.value.toArray", both
"label" and "value" are the properties of the bean "myBean". So to get the
symbols for "value" will need to know "myBean".
In Runtime, the property resolver will have a pointer to its base (parent)
property resolver.
Thanks.
- Xiaonan
"Cameron Bateman" <cameron.bateman@oracle.com> wrote in message
news:bc435ee829c68b0647e8ba4713f5c7c3$1@www.eclipse.org...
> It is possible, although I'm not sure ISymbol is the correct place to do
> it since this places the burden on all producers of symbols to have this
> information. Can you give a little more information about the specific
> use case so that I can form a canonical understanding of the use case?
> What is it about 'c' that knowing about b isn't enough? How does your
> runtime property resolver solve this?
> --Cam
> Xiaonan Jiang wrote:
>> Hi, Cameron,
>> For an expression e.g., "A.b.c", when generating the symbols for "c",
>> sometime we need to know the information in the symbol "A".
>> Is it possible to add an API getBase() for ISymbol interface?
>> Thanks.
>> - Xiaonan
>> news:f8234cde00320b9b243e8d0a2764b501$1@www.eclipse.org...
>>> It is in the built in help system if you the JSF feature installed.
>>> After unzipping the JSF build into Eclipse, try Help->Help Contents.
>>> --Cam
Re: content assist/validation for custom variableResolver and propertyResolver [message #608414 is a reply to message #473966] |
Mon, 12 March 2007 14:03  |
You can use the org.eclipse.jst.jsf.core.propertyresolver and
variableresolver extension points to register your own design time
overrides. You can then call
DesignTimeApplicationManager.setPropertyResolverProvider or
setVariableResolverProvider for a particular IProject where you want to
use this override.
You can find information on this in the JSF Developer Guide.
--Cam
> Thanks.
Re: content assist/validation for custom variableResolver and propertyResolver [message #608415 is a reply to message #473967] |
Tue, 13 March 2007 11:23  |
Could you give the link to the "JSF Developer Guide"?
Thanks.
news:0391faa8aad5041b3f051e39fb1a6b0c$1@www.eclipse.org...
> use this override.
> --Cam
>> and validation for his custom variableResolver and propertyResolver?
>> Thanks.
Re: content assist/validation for custom variableResolver and propertyResolver [message #608451 is a reply to message #473995] |
Tue, 27 March 2007 18:52  |
--Cam
> Hi, Cameron,
> Thanks.
> - Xiaonan
>> It is in the built in help system if you the JSF feature installed. After
>> --Cam
Re: content assist/validation for custom variableResolver and propertyResolver [message #608459 is a reply to message #473998] |
property resolver.
Thanks.
- Xiaonan
> --Cam
>> Hi, Cameron,
>> Thanks.
>> - Xiaonan
>>> --Cam
FUDForum. Page generated in 0.05546 seconds
