Home » Modeling » UML2 » EMF.edit commands usage
| EMF.edit commands usage [message #473772] |
Thu, 05 July 2007 22:47  |
I have a few things not very clear about the edit commands.
I'm using an AdapterFactoryEditingDomain with commands in a
BasicCommandStack. I tested successfully the ChangeCommand (it modifies the
model and undo/redo works).
Is there a reason I should use SetCommand, or AddCommand or other commands?
I could make the same "set" and "add" with model changes inside a ChangeCommand.
What is the difference between the two approaches?
Bogdan Pistol,
| Re: EMF.edit commands usage [message #473875 is a reply to message #473772] |
Fri, 06 July 2007 07:58   |
Bogdan,
These are more EMF-specific questions that are best asked on the EMF
newsgroup, which I've added to the "to" list of the reply. The use of
specific commands like SetCommand and AddCommand allow the item
providers that create these commands to specialize the behavior. For
example, for an EObject X, when I set feature foo, I might want to also
update some other feature goo. By specializing createSetCommand in
XItemProvider, I could do that. The ChangeCommand is very handy if you
just want to do a bunch of direct model manipulations, or need to invoke
some utility methods that knows= nothing about commands, but still want
any changes being made to be undoable.
Bogdan Pistol wrote:
> Hello,
> Thanks
> Bogdan Pistol,
| Re: EMF.edit commands usage [message #473883 is a reply to message #473875] |
Fri, 06 July 2007 13:05  |
Thank you Ed
Bogdan,
On Fri, 06 Jul 2007 07:58:27 -0400, Ed Merks wrote:
> Bogdan,
>> Hello,
>> Thanks
>> Bogdan Pistol,
| Re: EMF.edit commands usage [message #622850 is a reply to message #473772] |
Bogdan,
> Hello,
> Thanks
> Bogdan Pistol,
| Re: EMF.edit commands usage [message #623293 is a reply to message #473875] |
Thank you Ed
Bogdan,
> Bogdan,
>> Hello,
>> Thanks
>> Bogdan Pistol,
Current Time: Wed Nov 05 09:37:31 EST 2025
Powered by FUDForum. Page generated in 0.04889 seconds
