jface ui forms - FormDialog Class [message #473752] |
Sat, 17 May 2008 23:15  |
Originally posted by: southman.internode.on.net
Are there any code snippets for FormDialog Class
Having trouble adding content with createFormContent method appreciate
any working examples
Peter Snowball
Re: jface ui forms - FormDialog Class [message #473796 is a reply to message #473754] |
Tue, 20 May 2008 07:36  |
Examples however are very limited. Are any snippets showing override of
FormDialog methods createButtonBar and createDialogArea etc.
Peter Snowball
>> Thanks
>> Peter Snowball
> Yes, there is some example code in the CVS project
> org.eclipse.ui.forms.examples. To get a copy of this project into your
> workspace do the following:
> Help/Cheat Sheets...
> Open the cheat sheet Team/Check out a CVS project
> Follow the steps, when you get to the "Check out the project" step enter
> "org.eclipse.ui.forms.examples" as the project name.
Re: jface ui forms - FormDialog Class [message #614248 is a reply to message #473752] |
Mon, 19 May 2008 12:52  |
> Thanks
> Peter Snowball
Re: jface ui forms - FormDialog Class [message #614382 is a reply to message #473754] |
Peter Snowball
>> Thanks
>> Peter Snowball
FUDForum. Page generated in 0.72841 seconds
