JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #473665] |
Thu, 26 October 2006 11:16  |
I have used JSF 0.5.0 and WTP 1.5.0 pluginq in order to develop JSF web
apps.
Since upgrade of my Eclipse (3.2.0 -> 3.2.1, WTP 1.5.0 -> 1.5.1 and JSF
O.5.0 -> 0.5.1), JSF tags aren't anymore recognized in my apps.
I have tried to clean all projects, to launch Eclipse with -clean option ,
I have plenty of unknow tags warning in my JSF pages.
Content assist doesn't work anymore.
What can I do ? thanks for help.
Arnaud
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608342 is a reply to message #473666] |
Fri, 27 October 2006 04:42  |
new projects works perfectly
"Old" WTP 1.5.0 and JSF 0.5.0 created projects doesn't work anymore.
I tried without success to manually change properties setting in old
projects
Arnaud
Cameron Bateman a écrit :
> Are the projects showing problems ones that have been imported from
> existing or that you created new using the WTP 1.5.1 build?
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608348 is a reply to message #473667] |
Fri, 27 October 2006 05:29  |
projects
Arnaud
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608357 is a reply to message #473670] |
Mon, 30 October 2006 03:11  |
I have tried but it changes anything.
I have tried to clean and rebuild, to clean eclipse internet cache and
so on ..., without success.
Arnaud
> I think there may be an issue with the TLD loading. Can see what
> happens if you delete and re-add the module dependencies for the jars in
> one of your projects?
> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608359 is a reply to message #473673] |
Mon, 30 October 2006 05:18  |
I have solved the problem copying all .settings properties, .project and
..classpath of a new JSF project into an old JSF project. I have manually
changed param like project name when it was necessary, and now tags are
recognized.
Arnaud
> Arnaud
>> in one of your projects?
>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608367 is a reply to message #473699] |
Fri, 03 November 2006 16:25  |
Could you clarify? Are you saying that your problem went away in 1.5.2
builds? Or is there still a problem?
--Cam
amergey@sunopsis.com wrote:
> I 'have updated to WTP 1.5.2, removing/re-adding JSF libs dependency,
> JSF tags are recognized, something should be probably fixed in WTP.
> thanks
> Arnaud
>> Hmm.. that's not good. I try to follow that up with WTP.
>> --Cam
Re: JSF unknown tag since WTP 1.5.1 and JSF 0.5.1 upgrade [message #608371 is a reply to message #473700] |
Mon, 06 November 2006 03:44  |
Sorry for my poor english,
with WTP 1.5.2 the problem doesn't exist anymore.
Arnaud
> --Cam
>> Hi,
>> thanks
>> Arnaud
>>> --Cam
FUDForum. Page generated in 0.15773 seconds
