Home » Modeling » UML2 » How get actual class attributes from uml class
How get actual class attributes from uml class [message #473297] |
Tue, 26 June 2007 01:01  |
Hi All,
With the uml2 API I could not find a way to get actual class attributes
(except class properties for relationship ends).
We can use umlClass.getAttributes() method to get attributes related to a
class. But it returns relationship ends also as attributes. The
getAttributes() method returns list of properties.
So tried with property.isAttribute(p) method to check those properties for
class attributes. But it always returns false. Also I could not understand
why this isAttribute() method requires a parameter. Because we are always
invoking this isAttribute() for property so what is the meaning of passing
another property type parameter to it.
Thanks and Regards,
Re: How to get actual class attributes from uml class [message #473774 is a reply to message #473650] |
Fri, 06 July 2007 05:01   |
Hi Kenn,
Thanks for the reply.
But I can't understand the actual usage of isAttribute(Property) method.
- Lasith.
Kenn Hussey wrote:
> Lasith,
> There is currently no convenient method for obtaining the attributes which
> are not also association ends. Feel free to submit an enhancement request in
> Bugzilla.
> The isAttribute(Property) method requires an argument because the OCL query
> from which it is generated was poorly defined in the UML specification:
> [4] The query isAttribute() is true if the Property is defined as an
> attribute of some classifier
> context Property::isAttribute(p : Property) : Boolean
> post: result = Classifier.allInstances->exists(c|
> c.attribute->includes(p))
> We'll open an issue with the OMG.
> Kenn
> "lasith" <lasith100@yahoo.com> wrote in message
> news:b035f84b29a9c103e799adb34ebacf4a$1@www.eclipse.org...
>> James Bruck wrote:
>>> Hi uml user,
>>> I think Francis is right, his suggestion seems to be the only way to
>>> figure
>>> out what you want.
>>> There does seem to be something wrong with Property#isAttribute(p) ...
>>> I'll
>>> double check that one.
>>> - James.
>>> "uml user" <lasith100@yahoo.com> wrote in message
>>> news:6e5a64973b2c7e2443c1d3080ad6707c$1@www.eclipse.org...
>>>> Hi,
>>>> Thanks Francis,
>>>> But I think there must be a way to get those class attributes more
>>>> easily
>>>> (as you mentioned in your mail).
>>>> Regards.
>> Hi James,
>> Thanks for your reply,
>> If you find something other way please let me know.
>> Regards,
>> - Lasith
Re: How to get actual class attributes from uml class [message #473877 is a reply to message #473774] |
Fri, 06 July 2007 09:01  |
Lasith,
I'm not sure the method has any practical use either, but it's in the
specification, so we need to include it in the API. One thing the method
will tell you is whether the property is owned by a classifier (as opposed
to a property that has no owner, or is perhaps a qualifier for another
property).
Kenn
news:5cc34316f548e0958d58ffacd4852620$1@www.eclipse.org...
> Hi Kenn,
> Regards,
> - Lasith.
> Kenn Hussey wrote:
>> Lasith,
>> which are not also association ends. Feel free to submit an enhancement
>> request in Bugzilla.
>> query from which it is generated was poorly defined in the UML
>> specification:
>> Kenn
>>> James Bruck wrote:
>>>> Hi uml user,
>>>> figure
>>>> out what you want.
>>>> I'll
>>>> - James.
>>>>> Hi,
>>>>> Thanks Francis,
>>>>> easily
>>>>> Regards.
>>> Hi James,
>>> Regards,
>>> - Lasith
Re: How get actual class attributes from uml class [message #622568 is a reply to message #473297] |
Tue, 26 June 2007 04:58  |
Hi there,
You could use Property.getAssociation() != null, but this is, in my
opinion, not really an elegant solution. Ideally there should be some way
to get the list of attributes without inspecting each one of them. If
someone has a better idea, please post here. Thanks!
Francis
uml user wrote:
> Hi All,
> Thanks and Regards,
Re: How to get actual class attributes from uml class [message #622577 is a reply to message #473306] |
Tue, 26 June 2007 16:53  |
Hi uml user,
I think Francis is right, his suggestion seems to be the only way to figure
out what you want.
There does seem to be something wrong with Property#isAttribute(p) ... I'll
- James.
> Thanks Francis,
> But I think there must be a way to get those class attributes more easily
> Regards.
Re: How to get actual class attributes from uml class [message #622579 is a reply to message #473313] |
Wed, 27 June 2007 00:18  |
James Bruck wrote:
> Hi uml user,
> out what you want.
> - James.
>> Hi,
>> Thanks Francis,
>> Regards.
Hi James,
- Lasith
Re: How to get actual class attributes from uml class [message #622722 is a reply to message #473315] |
Wed, 04 July 2007 15:52  |
Lasith,
Bugzilla.
Kenn
> James Bruck wrote:
>> Hi uml user,
>> figure
>> out what you want.
>> I'll
>> - James.
>>> Hi,
>>> Thanks Francis,
>>> easily
>>> Regards.
> Hi James,
> Regards,
> - Lasith
Re: How to get actual class attributes from uml class [message #622847 is a reply to message #473650] |
Hi Kenn,
- Lasith.
Kenn Hussey wrote:
> Lasith,
> Bugzilla.
> Kenn
>> James Bruck wrote:
>>> Hi uml user,
>>> figure
>>> out what you want.
>>> I'll
>>> - James.
>>>> Hi,
>>>> Thanks Francis,
>>>> easily
>>>> Regards.
>> Hi James,
>> Regards,
>> - Lasith
Re: How to get actual class attributes from uml class [message #622854 is a reply to message #473774] |
Lasith,
property).
Kenn
> Hi Kenn,
> Regards,
> - Lasith.
> Kenn Hussey wrote:
>> Lasith,
>> specification:
>> Kenn
>>> James Bruck wrote:
>>>> Hi uml user,
>>>> figure
>>>> out what you want.
>>>> I'll
>>>> - James.
>>>>> Hi,
>>>>> Thanks Francis,
>>>>> easily
>>>>> Regards.
>>> Hi James,
>>> Regards,
>>> - Lasith
Current Time: Sat Jul 26 07:43:48 EDT 2025
Powered by FUDForum. Page generated in 0.12774 seconds
