tagged values are not shown in property editor [message #473643] |
Wed, 04 July 2007 03:11  |
Originally posted by: kl851754.inf.tu-dresden.de
Hi again,
I created a UML profile (.profile.uml) with several stereotypes and tagged
values. Then I applied the profile to a class diagram and a stereotype
(which had tagged values, called properties there) to a class. Everything
worked fine. The only problem is that I can't see my available tagged
values. I suppose they should appear in the property editor under
stereotype attributes. Am I correct? I also defined some default values to
check it but they are neither shown there.
The hierarchy in the profile is the following:
Profile
UML
Element Import stuff
Enumeration
Stereotype_A
Generalization
Property_1
Lieteral Integer 0
Property_2
Property base_class: class
Extension Class_Stereotype_A
Does anyone have an idea whether I could have done something wrong when
defining the profile or how I can let the tagged values appear?
Thanks for any help.
Katja
FUDForum. Page generated in 0.03655 seconds
