Home » Modeling » UML2 Tools » Getting started
Getting started [message #473495] |
Wed, 26 March 2008 13:36  |
I am struggling at step on of using uml2tools. I downloaded and unpacked
Eclipse 3.4M5 for windows. I then started it up and acquired the UML
Tools 2 plugin via the Ganymede Discovery Site (I told the update manager
to download required plugins).
I restarted eclipse and see that the org.eclipse.uml2tools feature
(version 0.80) is listed when I do Help > About Eclipse SDK and click
Feature Details. I also did a Help > Software Updates > Manage
Configuration and verified the "UML2 Tools SDK (Incubation)" had a "this
feature is configured properly" status.
Unfortunately, when I try to add a diagram to the java project open in my
workspace (via File > New > Other) I don't see an "Other" folder that
contains reference to the "UML 2.1" diagram like I expect to see per the
Wiki.
Am I doing something wrong. I just want to make a test state diagram.
Also, I don't see any errors in the Eclipse error log.
Any help appreciated.
James
Re: Getting started [message #474218 is a reply to message #473506] |
Fri, 04 April 2008 08:31   |
Originally posted by: pdm.plextek.co.uk
Tatiana,
I cannot answer for James, but I too have this problem.
It doesn't matter if I use "CTRL-N" or "right-click, New, Other". I get
the same dialog and I cannot find a "UML 2.1 Diagrams" option. The
closest is "UML Model" under "Example EMF Model Creation Wizards", but
subsequent dialogs don't match thoose the Lars Vogel's tutorial.
I started with the "Eclipse IDE for C/C++ Developers" download (today, 4th
April 2008) and then added the UML2 Tools and its dependencies.
Thus I have:
Eclipse Platform Version: 3.3.2
UML2 Tools Version: 0.7.101
Peter
Tatiana Fesenko wrote:
> Hi James,
> Is the problem still actual?
> 'File > New > Other' is available by 'Ctrl+N' key binding, 'wizard' text
> editor allows us to find required wizard.
> So, try 'Ctrl+N' and then write down 'UMLClass' in the 'wizards' text
editor.
> Does it help?
> Good luck,
> Tatiana.
>> Hello,
>> unpacked Eclipse 3.4M5 for windows. I then started it up and acquired
>> the UML Tools 2 plugin via the Ganymede Discovery Site (I told the
>> update manager to download required plugins).
>> "this feature is configured properly" status.
>> my workspace (via File > New > Other) I don't see an "Other" folder
>> that contains reference to the "UML 2.1" diagram like I expect to see
>> per the Wiki.
>> James
Re: Getting started [message #474219 is a reply to message #474218] |
Fri, 04 April 2008 08:58   |
When will I learn to read the instructions carefully?
I just spotted that Lars recommends downloading the whole of the "Models
and Model Development" hierarchy. I tried at suddenly I get the "UML 2.1
Diagrams" option just where it should be. I guess the wizard is defined
in one of the other plugins.
Peter
Peter Massam wrote:
> Tatiana,
> Thus I have:
> Peter
>> Hi James,
> editor.
>> Does it help?
>> Good luck,
>> Tatiana.
>>> Hello,
>>> per the Wiki.
>>> James
Re: Getting started [message #474929 is a reply to message #474700] |
Wed, 23 July 2008 13:34   |
Hi Warren,
I guess, you used update site to install UML2Tools, didn't you? Sometimes
conflicts of plugin versions appears when using update site. Using zips (from
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools) usually
helps to install UML2Tools properly.
Did it help you?
Best wishes,
Tanya.
> It doesn't help. Seems to be outdated
> Lars Vogel wrote:
>> Hi James,
>> this might help: http://www.vogella.de/articles/UML/article.html
>> Best regards, Lars
>> "James Leone" <jleone@sjm.com> wrote in message
>> news:b20d341c497bdd4b3cab7cb216ffe4d0$1@www.eclipse.org...
>>> Hello,
>>> acquired the UML Tools 2 plugin via the Ganymede Discovery Site (I
>>> told the update manager to download required plugins).
>>> click Feature Details. I also did a Help > Software Updates >
>>> Manage Configuration and verified the "UML2 Tools SDK (Incubation)"
>>> had a "this feature is configured properly" status.
>>> in my workspace (via File > New > Other) I don't see an "Other"
>>> folder that contains reference to the "UML 2.1" diagram like I
>>> expect to see per the Wiki.
>>> diagram.
>>> James
Re: Getting started [message #475293 is a reply to message #475286] |
Thu, 14 August 2008 08:04  |
Hi Steffan,
Sorry for the inconvenience. I corrected the wiki and submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=244146
'Ganymede update site: Move uml2tools feature to the modeling category'.
Thanks you for noticing the problem.
Best wishes,
Tanya.
> I think the information on the wiki is incorrect.
> The name of the feature to download is "UML2 Diagramming", not
> "UML2Tools". After installing this single feature, the "UML 2.1
> Diagrams" node appears (with 8 diagram types) in the "New..." wizard.
> It is not necessary to install the SDK!
> This is listed in the "Software Updates... -> Available Software" tab
> rather unhelpfully under the "Ganymede -> Uncategorized" node! No
> wonder people are having trouble finding it...
> Cheers,
> Steffan
Re: Getting started [message #618647 is a reply to message #473495] |
Wed, 26 March 2008 15:39  |
Hi James,
Best regards, Lars
> Hello,
> Wiki.
> James
Re: Getting started [message #619646 is a reply to message #473495] |
Wed, 02 April 2008 05:28  |
Hi James,
So, try 'Ctrl+N' and then write down 'UMLClass' in the 'wizards' text editor.
Does it help?
Good luck,
Tatiana.
> Hello,
> per the Wiki.
> James
Re: Getting started [message #619655 is a reply to message #473506] |
Tatiana,
Thus I have:
Peter
> Hi James,
editor.
> Does it help?
> Good luck,
> Tatiana.
>> Hello,
>> per the Wiki.
>> James
Re: Getting started [message #619656 is a reply to message #474218] |
Peter
Peter Massam wrote:
> Tatiana,
> Thus I have:
> Peter
>> Hi James,
> editor.
>> Does it help?
>> Good luck,
>> Tatiana.
>>> Hello,
>>> per the Wiki.
>>> James
Re: Getting started [message #621714 is a reply to message #473496] |
Wed, 23 July 2008 01:40  |
Lars Vogel wrote:
> Hi James,
> Best regards, Lars
>> Hello,
>> Wiki.
>> James
Re: Getting started [message #621734 is a reply to message #474700] |
Hi Warren,
Did it help you?
Best wishes,
Tanya.
> Lars Vogel wrote:
>> Hi James,
>> Best regards, Lars
>>> Hello,
>>> diagram.
>>> James
Re: Getting started [message #621744 is a reply to message #474219] |
Thu, 24 July 2008 17:21  |
hi,
yes I seems that it is necessary to add the following additional plugins
from the "Models and Model Develpment" category:
- EMF - Eclipse Modeling Framework Runtime and Tools
- Graphical Modeling Framework Runtime
- UML2 Diagram Search Feature
- UML2 Search
I did not understand the new Update Manager in Ganymede.
I run into problems more than once :-(
ralph
Re: Getting started [message #621786 is a reply to message #474934] |
Tue, 05 August 2008 04:56  |
Hey there, am having the same problem.
It seems like you've found the solution, but I can't find those particular
files you listed. Can you please provide a link to the download page?
Ralph Soika wrote:
> hi,
> - UML2 Search
> ralph
Re: Getting started [message #622594 is a reply to message #473495] |
Fri, 08 August 2008 05:47  |
"UML2Tools". After installing this single feature, the "UML 2.1 Diagrams"
node appears (with 8 diagram types) in the "New..." wizard. It is not
rather unhelpfully under the "Ganymede -> Uncategorized" node! No wonder
Steffan
Re: Getting started [message #622605 is a reply to message #475286] |
Hi Steffan,
Best wishes,
Tanya.
> Cheers,
> Steffan
Current Time: Sat Jul 26 08:44:09 EDT 2025
Powered by FUDForum. Page generated in 0.15463 seconds
