Home » Modeling » UML2 Tools » profile from two meta-model
profile from two meta-model [message #473500] Fri, 28 March 2008 13:12 Go to next message
Originally posted by: kallelslim.yahoo.fr
Hi all,
Just I want to know if I can create a profile and a diagram editor from two
meta-model (UML meta-model and its extension).
Kallel
Re: profile from two meta-model [message #473502 is a reply to message #473500] Mon, 31 March 2008 09:51 Go to previous messageGo to next message
Hi Kallel,
You can do several things with prifiles ...
- It is possible to combine profiles, ie. apply several stereotypes from
different profiles to the same element.
- It is possible to extend UML, and then create a profile for that extended
metamodel.
- You can also create a profile for any metamodel, not just UML (for example
your own DSL).
....You can then create a diagram editor for that profile.
- James.
"kallel" <kallelslim@yahoo.fr> wrote in message
news:fsj8tq$4ac$1@build.eclipse.org...
> Hi all,
> two meta-model (UML meta-model and its extension).
> Regards,
> Kallel
Re: profile from two meta-model [message #473503 is a reply to message #473502] Mon, 31 March 2008 10:58 Go to previous messageGo to next message
Hi James,
Thank you for your response,
I extended UML by a new metamodel, can I create one editor diagram for
these two metamodel? and How?
Next, I plan to create a metamodel for these two metamodels and create then
the diagram editor.
Kallel
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fsqq9s$62f$3@build.eclipse.org...
> Hi Kallel,
> extended metamodel.
> example your own DSL).
> - James.
>> Hi all,
>> Regards,
>> Kallel
Re: profile from two meta-model [message #474221 is a reply to message #473503] Tue, 08 April 2008 11:24 Go to previous message
Hi Kallel,
Please see the posting entitled "Use profile UML" from 4/8/2008.
Also, this might help ...
https://eclipsecon.greenmeetingsystems.com/submissions/view/ 172
Add the following Update Site URL to your Update Manager:
http://download.eclipse.org/modeling/mdt/updates/EclipseCon2 008-UML-Tutorial/
The UML2Tools newsgroup might also offer some advice.
There are many different ways to create a diagram editor to do what you
want, you could use GMF tooling to auto generate code for you or you could
resort to using GEF etc.
- James.
news:fsqu6b$gih$1@build.eclipse.org...
> Hi James,
> then
> the diagram editor.
> Regards,
> Kallel
>> Hi Kallel,
>> extended metamodel.
>> - James.
>>> Hi all,
>>> Regards,
>>> Kallel
Re: profile from two meta-model [message #618653 is a reply to message #473500] Mon, 31 March 2008 09:51 Go to previous message
Hi Kallel,
metamodel.
your own DSL).
- James.
> Hi all,
> Regards,
> Kallel
Re: profile from two meta-model [message #618654 is a reply to message #473502] Mon, 31 March 2008 10:58 Go to previous message
Hi James,
the diagram editor.
Kallel
> Hi Kallel,
> extended metamodel.
> - James.
>> Hi all,
>> Regards,
>> Kallel
Re: profile from two meta-model [message #619658 is a reply to message #473503] Tue, 08 April 2008 11:24 Go to previous message
Hi Kallel,
- James.
> Hi James,
> then
> the diagram editor.
> Regards,
> Kallel
>> Hi Kallel,
>> extended metamodel.
>> - James.
>>> Hi all,
>>> Regards,
>>> Kallel
Previous Topic:Problem with associations between classes of different diagrams/packages
Next Topic:Adapting uml2tools uml gmf editor with heavyweight extension of Eclipse UML2
Current Time: Wed Jul 23 08:46:11 EDT 2025
Powered by FUDForum. Page generated in 0.26438 seconds
