Home » Modeling » UML2 Tools » Getting started
Getting started [message #473495] Wed, 26 March 2008 13:36 Go to next message
I am struggling at step on of using uml2tools. I downloaded and unpacked
Eclipse 3.4M5 for windows. I then started it up and acquired the UML
Tools 2 plugin via the Ganymede Discovery Site (I told the update manager
to download required plugins).
I restarted eclipse and see that the org.eclipse.uml2tools feature
(version 0.80) is listed when I do Help > About Eclipse SDK and click
Feature Details. I also did a Help > Software Updates > Manage
Configuration and verified the "UML2 Tools SDK (Incubation)" had a "this
feature is configured properly" status.
Unfortunately, when I try to add a diagram to the java project open in my
workspace (via File > New > Other) I don't see an "Other" folder that
contains reference to the "UML 2.1" diagram like I expect to see per the
Wiki.
Am I doing something wrong. I just want to make a test state diagram.
Also, I don't see any errors in the Eclipse error log.
Any help appreciated.
James
Re: Getting started [message #473496 is a reply to message #473495] Wed, 26 March 2008 15:39 Go to previous messageGo to next message
Hi James,
this might help: http://www.vogella.de/articles/UML/article.html
Best regards, Lars
"James Leone" <jleone@sjm.com> wrote in message
news:b20d341c497bdd4b3cab7cb216ffe4d0$1@www.eclipse.org...
> Hello,
> Wiki.
> James
Re: Getting started [message #473506 is a reply to message #473495] Wed, 02 April 2008 05:28 Go to previous messageGo to next message
Hi James,
Is the problem still actual?
'File > New > Other' is available by 'Ctrl+N' key binding, 'wizard' text
editor allows us to find required wizard.
So, try 'Ctrl+N' and then write down 'UMLClass' in the 'wizards' text editor.
Does it help?
Good luck,
Tatiana.
> Hello,
> unpacked Eclipse 3.4M5 for windows. I then started it up and acquired
> the UML Tools 2 plugin via the Ganymede Discovery Site (I told the
> update manager to download required plugins).
> "this feature is configured properly" status.
> my workspace (via File > New > Other) I don't see an "Other" folder
> that contains reference to the "UML 2.1" diagram like I expect to see
> per the Wiki.
> James
Re: Getting started [message #474218 is a reply to message #473506] Fri, 04 April 2008 08:31 Go to previous messageGo to next message
Originally posted by: pdm.plextek.co.uk
Tatiana,
I cannot answer for James, but I too have this problem.
It doesn't matter if I use "CTRL-N" or "right-click, New, Other". I get
the same dialog and I cannot find a "UML 2.1 Diagrams" option. The
closest is "UML Model" under "Example EMF Model Creation Wizards", but
subsequent dialogs don't match thoose the Lars Vogel's tutorial.
I started with the "Eclipse IDE for C/C++ Developers" download (today, 4th
April 2008) and then added the UML2 Tools and its dependencies.
Thus I have:
Eclipse Platform Version: 3.3.2
UML2 Tools Version: 0.7.101
Peter
Tatiana Fesenko wrote:
> Hi James,
editor.
> Does it help?
> Good luck,
> Tatiana.
>> Hello,
>> per the Wiki.
>> James
Re: Getting started [message #474219 is a reply to message #474218] Fri, 04 April 2008 08:58 Go to previous messageGo to next message
When will I learn to read the instructions carefully?
I just spotted that Lars recommends downloading the whole of the "Models
and Model Development" hierarchy. I tried at suddenly I get the "UML 2.1
Diagrams" option just where it should be. I guess the wizard is defined
in one of the other plugins.
Peter
Peter Massam wrote:
> Tatiana,
> Thus I have:
> Peter
>> Hi James,
> editor.
>> Does it help?
>> Good luck,
>> Tatiana.
>>> Hello,
>>> per the Wiki.
>>> James
Re: Getting started [message #474700 is a reply to message #473496] Wed, 23 July 2008 01:40 Go to previous messageGo to next message
It doesn't help. Seems to be outdated
Lars Vogel wrote:
> Hi James,
> Best regards, Lars
>> Hello,
>> Wiki.
>> James
Re: Getting started [message #474929 is a reply to message #474700] Wed, 23 July 2008 13:34 Go to previous messageGo to next message
Hi Warren,
I guess, you used update site to install UML2Tools, didn't you? Sometimes
conflicts of plugin versions appears when using update site. Using zips (from
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools) usually
helps to install UML2Tools properly.
Did it help you?
Best wishes,
Tanya.
> Lars Vogel wrote:
>> Hi James,
>> Best regards, Lars
>>> Hello,
>>> acquired the UML Tools 2 plugin via the Ganymede Discovery Site (I
>>> told the update manager to download required plugins).
>>> click Feature Details. I also did a Help > Software Updates >
>>> Manage Configuration and verified the "UML2 Tools SDK (Incubation)"
>>> had a "this feature is configured properly" status.
>>> in my workspace (via File > New > Other) I don't see an "Other"
>>> folder that contains reference to the "UML 2.1" diagram like I
>>> expect to see per the Wiki.
>>> diagram.
>>> James
Re: Getting started [message #474934 is a reply to message #474219] Thu, 24 July 2008 17:21 Go to previous messageGo to next message
hi,
yes I seems that it is necessary to add the following additional plugins
from the "Models and Model Develpment" category:
- EMF - Eclipse Modeling Framework Runtime and Tools
- Graphical Modeling Framework Runtime
- UML2 Diagram Search Feature
- UML2 Search
I did not understand the new Update Manager in Ganymede.
I run into problems more than once :-(
ralph
Re: Getting started [message #475274 is a reply to message #474934] Tue, 05 August 2008 04:56 Go to previous messageGo to next message
Hey there, am having the same problem.
It seems like you've found the solution, but I can't find those particular
files you listed. Can you please provide a link to the download page?
Ralph Soika wrote:
> hi,
> - UML2 Search
> ralph
Re: Getting started [message #475275 is a reply to message #475274] Tue, 05 August 2008 05:02 Go to previous messageGo to next message
I found this answer on this newsgroup:
http://www.eclipse.org/newsportal/article.php?id=805&gro up=eclipse.modeling.mdt.uml2tools#805
And it seems to answer my question.. though it's a large download so I
can't actually test whether it works just yet :)
Re: Getting started [message #475286 is a reply to message #473495] Fri, 08 August 2008 05:47 Go to previous messageGo to next message
I think the information on the wiki is incorrect.
The name of the feature to download is "UML2 Diagramming", not
"UML2Tools". After installing this single feature, the "UML 2.1 Diagrams"
node appears (with 8 diagram types) in the "New..." wizard. It is not
necessary to install the SDK!
This is listed in the "Software Updates... -> Available Software" tab
rather unhelpfully under the "Ganymede -> Uncategorized" node! No wonder
people are having trouble finding it...
Steffan
Re: Getting started [message #475293 is a reply to message #475286] Thu, 14 August 2008 08:04 Go to previous message
Hi Steffan,
Sorry for the inconvenience. I corrected the wiki and submitted https://bugs.eclipse.org/bugs/show_bug.cgi?id=244146
'Ganymede update site: Move uml2tools feature to the modeling category'.
Thanks you for noticing the problem.
Best wishes,
Tanya.
> Diagrams" node appears (with 8 diagram types) in the "New..." wizard.
> It is not necessary to install the SDK!
> wonder people are having trouble finding it...
> Cheers,
> Steffan
Re: Getting started [message #618647 is a reply to message #473495] Wed, 26 March 2008 15:39 Go to previous message
Hi James,
Best regards, Lars
> Hello,
> Wiki.
> James
Re: Getting started [message #619646 is a reply to message #473495] Wed, 02 April 2008 05:28 Go to previous message
Hi James,
Does it help?
Good luck,
Tatiana.
> Hello,
> per the Wiki.
> James
Re: Getting started [message #619655 is a reply to message #473506] Fri, 04 April 2008 08:31 Go to previous message
Tatiana,
Thus I have:
Peter
> Hi James,
editor.
> Does it help?
> Good luck,
> Tatiana.
>> Hello,
>> per the Wiki.
>> James
Re: Getting started [message #619656 is a reply to message #474218] Fri, 04 April 2008 08:58 Go to previous message
Peter
Peter Massam wrote:
> Tatiana,
> Thus I have:
> Peter
>> Hi James,
> editor.
>> Does it help?
>> Good luck,
>> Tatiana.
>>> Hello,
>>> per the Wiki.
>>> James
Re: Getting started [message #621714 is a reply to message #473496] Wed, 23 July 2008 01:40 Go to previous message
Lars Vogel wrote:
> Hi James,
> Best regards, Lars
>> Hello,
>> Wiki.
>> James
Re: Getting started [message #621734 is a reply to message #474700] Wed, 23 July 2008 13:34 Go to previous message
Hi Warren,
Did it help you?
Best wishes,
Tanya.
> Lars Vogel wrote:
>> Hi James,
>> Best regards, Lars
>>> Hello,
>>> diagram.
>>> James
Re: Getting started [message #621744 is a reply to message #474219] Thu, 24 July 2008 17:21 Go to previous message
hi,
- UML2 Search
ralph
Re: Getting started [message #621786 is a reply to message #474934] Tue, 05 August 2008 04:56 Go to previous message
Ralph Soika wrote:
> hi,
> - UML2 Search
> ralph
Re: Getting started [message #621787 is a reply to message #475274] Tue, 05 August 2008 05:02 Go to previous message
Re: Getting started [message #622594 is a reply to message #473495] Fri, 08 August 2008 05:47 Go to previous message
Steffan
Re: Getting started [message #622605 is a reply to message #475286] Thu, 14 August 2008 08:04 Go to previous message
Hi Steffan,
Best wishes,
Tanya.
> Cheers,
> Steffan
Previous Topic:Interface viewmap of Component Diagram
Next Topic:Extending UML2Tools diagram editor user interface
Current Time: Wed Jul 23 04:05:18 EDT 2025
Powered by FUDForum. Page generated in 0.47198 seconds
