Home » Eclipse Projects » JavaServer Faces » Exception with jsf login Tutorial
Exception with jsf login Tutorial [message #472969] Wed, 20 September 2006 12:24 Go to next message
Originally posted by: graham.raima.co.uk
Hi All,
I am getting an exception when I run the JSF login tutorial. I have
spent many many hours trying to figure this out,
any help gratefully received.
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
org.apache.jasper.JasperException
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:510)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:375)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil .java:243)
java.security.AccessController.doPrivileged(Native Method)
javax.security.auth.Subject.doAsPrivileged(Unknown Source)
org.apache.catalina.security.SecurityUtil.execute(SecurityUt il.java:275)
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:161)
com.sun.faces.context.ExternalContextImpl.dispatch(ExternalC ontextImpl.java:322)
com.sun.faces.application.ViewHandlerImpl.renderView(ViewHan dlerImpl.java:130)
com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderRe sponsePhase.java:87)
com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.ja va:200)
com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.j ava:117)
javax.faces.webapp.FacesServlet.service(FacesServlet.java:19 8)
root cause
javax.servlet.ServletException
org.apache.jasper.runtime.PageContextImpl.doHandlePageExcept ion(PageContextImpl.java:858)
org.apache.jasper.runtime.PageContextImpl.access$1100(PageCo ntextImpl.java:65)
org.apache.jasper.runtime.PageContextImpl$12.run(PageContext Impl.java:778)
org.apache.jasper.runtime.PageContextImpl.handlePageExceptio n(PageContextImpl.java:776)
org.apache.jsp.welcome_jsp._jspService(welcome_jsp.java:72)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:332)
root cause
java.lang.NoClassDefFoundError
org.apache.jasper.runtime.PageContextImpl.pushBody(PageConte xtImpl.java:722)
org.apache.jasper.runtime.PageContextImpl.pushBody(PageConte xtImpl.java:712)
org.apache.jsp.welcome_jsp._jspx_meth_f_view_0(welcome_jsp.j ava:90)
org.apache.jsp.welcome_jsp._jspService(welcome_jsp.java:63)
note The full stack trace of the root cause is available in the Apache
Tomcat/5.5.17 logs.
Re: Exception with jsf login Tutorial [message #472971 is a reply to message #472969] Wed, 20 September 2006 18:39 Go to previous messageGo to next message
Hi Graham,
The NoClassDefFoundError seems to imply that a needed class is not in the
Tomcat's runtime class path. Which implementation of the core and html (f
and h taglibs) are you using? Did you use the "deploy to web-inf" option
when you created the JSF library in the tool? Clicking this checkbox
ensures that your component libraries get deployed to Tomcat when you run
the app.
--Cam
Graham Watson wrote:
> Hi All,
Re: Exception with jsf login Tutorial [message #472972 is a reply to message #472971] Thu, 21 September 2006 05:40 Go to previous messageGo to next message
Thank you Cam for your reply, to answer your question
I am using Sun's 1.1_01 Final Release of jsf-1_1_01.zip
I did use the deploy to web-inf option.
Also here are the 'Configuration Details' from the About Eclipse SDK
Dialog
*** Date: Thu Sep 21 10:36:01 BST 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.buildId=M20060628-1325
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Usr\eclipse3.3\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
df4_7a8
-clean
-vm
C:\Program Files\Java\jre1.5.0_06\bin\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1158771972057
eclipse.vm=C:\Program Files\Java\jre1.5.0_06\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\Usr\eclipse3.3\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Usr\eclipse3.3\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_06\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_06\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_06
java.io.tmpdir=C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\
java.library.path=C:\Program
Files\Java\jre1.5.0_06\bin;.;C:\WINDOWS\system32;C:\WINDOWS; C:\Program
Files\Java\jre1.5.0_06\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\system32\wbem;c:\program
files\common files\watchguard\lib;c:\usr\binw;c:\usr\bin;;C:\Program
Files\STI\bin\pc-win95;C:\Program Files\Birdstep Technology\RDM Server
7.0\\bin
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Usr\eclipse3.3\eclipse\configuration\org .eclipse.osgi\bundles
osgi.clean=true
osgi.configuration.area=file:/C:/Usr/eclipse3.3/eclipse/conf iguration/
osgi.framework=file:/c:/Usr/eclipse3.3/eclipse/plugins/org.e clipse.osgi_3.2.0.v20060601.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.0.v20060601
osgi.install.area=file:/C:/Usr/eclipse3.3/eclipse/
osgi.instance.area=file:/C:/Usr/eclipse3.3/eclipse/workspace /
osgi.instance.area.default=file:/C:/Documents and
Settings/Administrator/workspace/
osgi.logfile=C:\Usr\eclipse3.3\eclipse\workspace\.metadata\. log
osgi.manifest.cache=C:\Usr\eclipse3.3\eclipse\configuration\ org.eclipse.osgi\manifests
osgi.nl=en_GB
osgi.os=win32
osgi.splashLocation=c:\Usr\eclipse3.3\eclipse\plugins\org.ec lipse.platform_3.2.0.v20060601\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Usr\eclipse3.3\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre1.5.0_06\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_06\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_06\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=GB
user.dir=C:\Usr\eclipse3.3\eclipse
user.home=C:\Documents and Settings\Administrator
user.language=en
user.name=Administrator
user.timezone=Europe/London
user.variant=
*** Features:
org.eclipse.emf (2.2.0.v200606271057) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.2.0.v200606271057) "Eclipse Modeling Framework (EMF)
Programmers Guide"
org.eclipse.emf.ecore.sdo (2.2.0.v200606271057) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.ecore.sdo.doc (2.2.0.v200606271057) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.2.0.v200606271057) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.source (2.2.0.v200606271057) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.2.0.v20060626) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.2.0.v20060626) "Graphical Editing Framework
Developer Resources"
org.eclipse.jdt (3.2.0.v20060609m-F7snq1fxia-Z4XP) "Eclipse Java Development
Tools"
org.eclipse.jdt.source (3.2.0.v20060609m-F7snq1fxia-Z4XP) "Eclipse Java
Development Tools SDK"
org.eclipse.jem (1.2.0.v20060530_RC2--ZasJzJJez) "Java EMF Model"
org.eclipse.jem.sdk (1.2.0.v20060530_RC2--FEM8P88GP) "Java EMF Model SDK"
org.eclipse.jem.source (1.2.0.v20060530_RC2--ZasJzJJez) "Java EMF Model
Source"
org.eclipse.jsf (0.5.0.v200608180819-fbN5nDdPh2hQ3Ac) "JavaServer Faces
Tooling"
org.eclipse.jst (1.5.0.v200606092300-kW-O_ysCRLJsxJt) "J2EE Standard Tools
(JST)"
org.eclipse.pde (3.2.0.v20060609m------6zXJJzJzJq) "Eclipse Plug-in
Development Environment"
org.eclipse.pde.source (3.2.0.v20060609m------6zXJJzJzJq) "Eclipse Plug-in
Development Environment Developer Resources"
org.eclipse.platform (3.2.0.v20060609m-AgOexn6hlEUsvBO) "Eclipse Platform"
org.eclipse.platform.source (3.2.0.v20060609m-AgOexn6hlEUsvBO) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.0.v20060609m-SVDNgVrNoh-MeGG) "Eclipse RCP"
org.eclipse.rcp.source (3.2.0.v20060609m-SVDNgVrNoh-MeGG) "Eclipse RCP
org.eclipse.sdk (3.2.0.v20060609m-GNq6oQq-7es-Y81) "Eclipse Project SDK"
org.eclipse.wst (1.5.0.v200606092300-U4T922yjOWsGK5Y) "Web Standard Tools
(WST)"
org.eclipse.xsd (2.2.0.v200606271057) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.2.0.v200606271057) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.source (2.2.0.v200606271057) "XML Schema Infoset Model (XSD)
Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060518_RC1) "Event Model" [Resolved]
com.ibm.icu (3.4.4.1) "International Components for Unicode for Java
(ICU4J)" [Active]
com.ibm.icu.source (3.4.4.1) "International Components for Unicode for Java
(ICU4J) source plug-in" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.3.0.v200606181221) "Apache Axis 1.3.0" [Resolved]
org.apache.cactus (1.7.2.v200606181221) "Cactus Resource Plug-in" [Resolved]
org.apache.commons_logging (1.0.4.v200606131651) "Apache commons logging
Plug-in" [Resolved]
org.apache.jakarta_log4j (1.2.8.v200606131651) "Apache Jakarta log4j
Plug-in" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200606181221) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.0.v20060531) "Ant UI" [Resolved]
org.eclipse.compare (3.2.0.v20060605) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism"
[Active]
org.eclipse.core.expressions (3.2.0.v20060605-1400) "Expression Language"
[Active]
org.eclipse.core.filebuffers (3.2.0.v20060605-1400) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File System
for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.0.v20060603) "Core Resource Management"
[Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource
Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource Management
Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime
Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorization
Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.0.v20060603) "Eclipse
Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Active]
org.eclipse.debug.core (3.2.0.v20060605) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.0.v20060605) "Debug UI" [Active]
org.eclipse.draw2d (3.2.0.v20060626) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.2.0.v20060626) "Draw2D Documentation"
[Resolved]
[Resolved]
org.eclipse.emf.ant (2.2.0.v200606271057) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.cheatsheets (2.2.0.v200606271057) "EMF Cheat Sheets"
[Resolved]
org.eclipse.emf.codegen (2.2.0.v200606271057) "EMF Template Code Generator"
[Resolved]
org.eclipse.emf.codegen.ecore (2.2.0.v200606271057) "EMF Ecore Code
Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.2.0.v200606271057) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200606271057) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.0.v200606271057) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.0.v200606271057) "EMF Common UI" [Active]
org.eclipse.emf.commonj.sdo (2.1.0.v200606271057) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.0.v200606271057) "EMF Model Convert Support"
[Resolved]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore (2.2.0.v200606271057) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.0.v200606271057) "EMF Ecore Change Model"
[Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0.v200606271057) "EMF Ecore Change
Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200606271057) "EMF Ecore Edit Support"
[Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200606271057) "Sample Ecore Editor"
[Resolved]
(SDO)" [Resolved]
Objects (SDO) Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0.v200606271057) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0.v200606271057) "EMF Service Data
Objects (SDO) Editor" [Resolved]
Objects (SDO) Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.0.v200606271057) "EMF XMI" [Active]
org.eclipse.emf.edit (2.2.0.v200606271057) "EMF Edit" [Active]
org.eclipse.emf.edit.ui (2.2.0.v200606271057) "EMF Edit UI" [Active]
org.eclipse.emf.exporter (2.2.0.v200606271057) "EMF Model Export Support"
[Resolved]
org.eclipse.emf.importer (2.2.0.v200606271057) "EMF Model Import Support"
[Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200606271057) "EMF Ecore Importer"
[Resolved]
org.eclipse.emf.importer.java (2.2.0.v200606271057) "EMF Annotated Java
Importer" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200606271057) "EMF Rose Importer"
[Resolved]
org.eclipse.emf.mapping (2.2.0.v200606271057) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200606271057) "Ecore to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200606271057) "Ecore to
Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200606271057) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200606271057) "Ecore to XML
Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.0.v200606271057) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0.v200606271057) "XSD to Ecore
Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0.v200606271057) "XSD to Ecore
(EMF) Source" [Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.0.v20060601) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.2.0.v20060601) "Extension Registry Support"
[Active]
org.eclipse.equinox.servlet.api (1.0.0.v20060601) "Servlet API" [Resolved]
org.eclipse.gef (3.2.0.v20060626) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.2.0.v20060626) "Graphical Editing Framework
Documentation" [Resolved]
Developer Resources" [Resolved]
org.eclipse.help (3.2.0.v20060602) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server"
[Resolved]
org.eclipse.help.base (3.2.0.v20060601) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.0.v20060602) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.2.0.v20060605-1400) "Eclipse Java Development Tools"
[Resolved]
org.eclipse.jdt.apt.core (3.2.0.v20060602-1740) "Java Annotation Processing
Core" [Resolved]
org.eclipse.jdt.apt.ui (3.2.0.v20060602-1740) "Java Annotation Processing
UI" [Resolved]
org.eclipse.jdt.core (3.2.0.v_671) "Java Development Tools Core" [Active]
org.eclipse.jdt.core.manipulation (1.0.0.v20060605-1400) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.0.v20060605) "JDI Debug Model" [Active]
org.eclipse.jdt.debug.ui (3.2.0.v20060605) "JDI Debug UI" [Active]
org.eclipse.jdt.doc.isv (3.2.0.v20060605-1400) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java Development
User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.0.v20060605-1400) "Java Development Tools JUnit
support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.0.v20060605-1400) "Java Development Tools
JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.0.v20060605-1400) "Java Development
Tools JUnit4 runtime support" [Resolved]
org.eclipse.jdt.launching (3.2.0.v20060605) "Java Development Tools
Launching Support" [Active]
Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.0.v20060605-1400) "Java Development Tools UI"
[Active]
org.eclipse.jem (1.2.0.v20060530_RC2) "Java EMF Model" [Active]
org.eclipse.jem.beaninfo (1.2.0.v20060530_RC2) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060530_RC2) "Java EMF Model Proxy Support"
[Resolved]
org.eclipse.jem.sdk (1.2.0.v20060518_RC1) "Java EMF Model SDK" [Resolved]
Source" [Resolved]
org.eclipse.jem.ui (1.2.0.v20060518_RC1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.0.v20060530_RC2) "Java EMF Model Utilities"
[Active]
org.eclipse.jem.workbench (1.2.0.v20060530_RC2) "Java EMF Model Workbench
Support" [Active]
org.eclipse.jface (3.2.0.I20060605-1400) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding"
[Resolved]
org.eclipse.jface.text (3.2.0.v20060605-1400) "JFace Text" [Resolved]
org.eclipse.jsf (0.5.0.v20060622) "JavaServer Faces Tooling" [Resolved]
org.eclipse.jsf (0.5.0.v200608180819) "JavaServer Faces Tooling" [Resolved]
org.eclipse.jst (1.0.1.v200605040115) "J2EE Standard Tools (JST)" [Resolved]
org.eclipse.jst.common.annotations.controller (1.1.0.v200606130315)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.1.0.v200606130315) "Annotation
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.1.0.v200606130315) "Annotations UI
Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.1.0.v200606130315) "Integration
Plug-in" [Resolved]
org.eclipse.jst.common.project.facet.core (1.1.0.v200606130315) "Project
Facet Core (Java Support)" [Resolved]
org.eclipse.jst.ejb.doc.user (1.0.201.v200605291441) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.1.0.v200606130315) "WTP EJB UI Plug-in" [Active]
org.eclipse.jst.j2ee (1.1.0.v200606222043) "J2EE Component" [Active]
org.eclipse.jst.j2ee.core (1.1.0.v200606130315) "J2EE Core Component"
[Active]
org.eclipse.jst.j2ee.doc.user (1.0.201.v200605152316) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.1.0.v200606152049) "EJB component Plug-in"
[Active]
org.eclipse.jst.j2ee.ejb.annotation.model (1.1.0.v200606212143) "EJB
Annotation Model Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.1.0.v200606130315) "EJB
Emitter Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.1.0.v200606212143) "EJB
Annotations Ui Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.1.0.v200606130315) "Xdoclet
Annotations Plug-in" [Resolved]
org.eclipse.jst.j2ee.infopop (1.0.201.v200605040115) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.1.0.v200606152049) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (1.1.0.v200606130315) "WTP JCA UI Plug-in"
[Resolved]
org.eclipse.jst.j2ee.navigator.ui (1.1.0.v200606130315) "J2EE Extensions to
Common Navigator" [Active]
org.eclipse.jst.j2ee.ui (1.1.0.v200606130315) "WTP J2EE UI Plug-in" [Active]
org.eclipse.jst.j2ee.web (1.1.0.v200606152049) "Web Plug-in" [Active]
org.eclipse.jst.j2ee.webservice (1.1.0.v200606130315) "Web Service Plug-in"
[Active]
org.eclipse.jst.j2ee.webservice.ui (1.1.0.v200606130315) "WTP Webservice UI
Plug-in" [Active]
org.eclipse.jst.j2ee.xdoclet.runtime (1.1.0.v200606130315) "XDocletRuntime
Plug-in" [Resolved]
org.eclipse.jst.jsf.contentassist (0.5.0.v20060622) "JSF Content-Assist
Plug-in" [Installed]
org.eclipse.jst.jsf.contentassist (0.5.0.v200608180819) "JSF Content-Assist
Plug-in" [Resolved]
org.eclipse.jst.jsf.contentmodel.annotations (0.5.0.v20060622) "JSF Content
Model Annotations Plug-in" [Installed]
org.eclipse.jst.jsf.contentmodel.annotations (0.5.0.v200608180819) "JSF
Content Model Annotations Plug-in" [Active]
org.eclipse.jst.jsf.context (0.5.0.v20060622) "JSF Context Plug-in"
[Resolved]
org.eclipse.jst.jsf.context (0.5.0.v200608180819) "JSF Context Plug-in"
[Active]
org.eclipse.jst.jsf.context.resolver (0.5.0.v20060622) "JSF Context Resolver
Plug-in" [Resolved]
org.eclipse.jst.jsf.context.resolver (0.5.0.v200608180819) "JSF Context
Resolver Plug-in" [Active]
org.eclipse.jst.jsf.context.resolver.structureddocument (0.5.0.v20060622)
"JSF Structured Document Context Resolver Plug-in" [Resolved]
(0.5.0.v200608180819) "JSF Structured Document Context Resolver Plug-in"
[Active]
org.eclipse.jst.jsf.context.structureddocument (0.5.0.v20060622) "JSF
Structured Document Context Plug-in" [Resolved]
org.eclipse.jst.jsf.context.structureddocument (0.5.0.v200608180819) "JSF
Structured Document Context Plug-in" [Active]
org.eclipse.jst.jsf.context.symbol (0.5.0.v20060622) "JSF Symbol Plug-in"
[Installed]
org.eclipse.jst.jsf.context.symbol (0.5.0.v200608180819) "JSF Symbol
Plug-in" [Active]
org.eclipse.jst.jsf.core (0.5.0.v20060622) "JSF Core Plug-in" [Installed]
org.eclipse.jst.jsf.core (0.5.0.v200608180819) "JSF Core Plug-in" [Active]
org.eclipse.jst.jsf.designtime (0.5.0.v20060622) "JSF Design Time
Application Manager Plug-in" [Installed]
org.eclipse.jst.jsf.designtime (0.5.0.v200608180819) "JSF Design Time
Application Manager Plug-in" [Active]
org.eclipse.jst.jsf.doc.dev (0.5.0.v20060622) "JSF Tooling Developer Guide
org.eclipse.jst.jsf.doc.dev (0.5.0.v200608180819) "JSF Tooling Developer
Guide Plug-in" [Resolved]
org.eclipse.jst.jsf.doc.user (0.5.0.v20060622) "JSF Tooling User Guide
org.eclipse.jst.jsf.doc.user (0.5.0.v200608180819) "JSF Tooling User Guide
Plug-in" [Resolved]
org.eclipse.jst.jsf.facesconfig (0.5.0.v20060622) "JSF FacesConfig Model
org.eclipse.jst.jsf.facesconfig (0.5.0.v200608180819) "JSF FacesConfig Model
Plug-in" [Resolved]
org.eclipse.jst.jsf.facesconfig.common (0.5.0.v20060622) "JSF FacesConfig
Common Plug-in" [Installed]
org.eclipse.jst.jsf.facesconfig.common (0.5.0.v200608180819) "JSF
FacesConfig Common Plug-in" [Resolved]
org.eclipse.jst.jsf.facesconfig.edit (0.5.0.v20060622) "JSF FacesConfig Edit
Support" [Installed]
org.eclipse.jst.jsf.facesconfig.edit (0.5.0.v200608180819) "JSF FacesConfig
org.eclipse.jst.jsf.facesconfig.ui (0.5.0.v20060622) "JSF FacesConfig Editor
org.eclipse.jst.jsf.facesconfig.ui (0.5.0.v200608180819) "JSF FacesConfig
Editor Plug-in" [Resolved]
org.eclipse.jst.jsf.metadataprocessors (0.5.0.v20060622) "JSF Metadata
Processors Plug-in" [Installed]
org.eclipse.jst.jsf.metadataprocessors (0.5.0.v200608180819) "JSF Metadata
Processors Plug-in" [Active]
org.eclipse.jst.jsf.taglibprocessing (0.5.0.v20060622) "JSF Standard Taglib
org.eclipse.jst.jsf.taglibprocessing (0.5.0.v200608180819) "JSF Standard
Taglib Plug-in" [Resolved]
org.eclipse.jst.jsf.ui (0.5.0.v20060622) "JSF UI Plug-in" [Installed]
org.eclipse.jst.jsf.ui (0.5.0.v200608180819) "JSF UI Plug-in" [Resolved]
org.eclipse.jst.jsf.validation.el (0.5.0.v20060622) "JSF Validation Plug-in"
[Installed]
org.eclipse.jst.jsf.validation.el (0.5.0.v200608180819) "JSF Validation
Plug-in" [Active]
org.eclipse.jst.jsp.core (1.1.0.v200606191945) "Structured Source JSP Model"
[Active]
org.eclipse.jst.jsp.ui (1.1.0.v200606191945) "SSE JSP Source Editor"
[Active]
org.eclipse.jst.jsp.ui.infopop (1.0.2.v200605040115) "JSP tools infopops"
[Resolved]
org.eclipse.jst.server.core (1.0.102.v200606130315) "Java Server Support"
[Active]
org.eclipse.jst.server.generic.core (1.0.100.v200606130315) "Generic Server
Plugin" [Active]
org.eclipse.jst.server.generic.jboss (1.5.0.v200606130315) "JBoss Generic
server definitions" [Resolved]
org.eclipse.jst.server.generic.jonas (1.5.0.v200606130315) "JOnAS Generic
Server definitions" [Resolved]
org.eclipse.jst.server.generic.oc4j (1.5.0.v200606130315) "Oracle OC4J
v10.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.100.v200606130315) "Generic Server
Plugin UI" [Resolved]
org.eclipse.jst.server.generic.weblogic (1.5.0.v200606130315) "Weblogic
generic server definitions" [Resolved]
org.eclipse.jst.server.installable (1.5.0.v200606130315) "Installable
servers" [Resolved]
org.eclipse.jst.server.tomcat.core (1.0.102.v200606130315) "Apache Tomcat
Support" [Active]
org.eclipse.jst.server.tomcat.ui (1.0.102.v200606130315) "Apache Tomcat UI
Support" [Resolved]
org.eclipse.jst.server.ui (1.0.102.v200606130315) "Java Server UI Support"
[Active]
org.eclipse.jst.server.ui.doc.user (1.0.1.v200605040115) "Server Tools
documentation for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.ui.infopop (1.0.2.v200605040115) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.100.v200606130315) "WebSphere
org.eclipse.jst.servlet.ui (1.1.0.v200606130315) "WTP Servlet UI Plug-in"
[Active]
org.eclipse.jst.servlet.ui.infopop (1.0.201.v200606130315) "Servlet infopop"
[Resolved]
org.eclipse.jst.ws (1.0.101.v200606130315) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (1.0.101.v200606130315) "Web
service Axis Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (1.0.101.v200606130315) "Webservice
Axis Consumption UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (1.0.101.v200606130315) "Webservice Axis
Creation UI" [Resolved]
org.eclipse.jst.ws.axis.infopop (1.0.201.v200605152241) "Web services Axis
UI" [Resolved]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.201.v200605111705) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.101.v200606131923) "Web Services
Consumption" [Resolved]
org.eclipse.jst.ws.consumption.infopop (1.0.201.v200605152241) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.101.v200606130315) "Web Services
Consumption Graphical User Interface" [Resolved]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.201.v200605111705) "Web
service consumption documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200606130315) "Web Services
Creation EJB Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ui (1.0.101.v200606130315) "Web Services
Creation Graphical User Interface" [Resolved]
org.eclipse.jst.ws.doc.user (1.0.201.v200605111641) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.201.v200605162034) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.100.v200606130315) "Web Services
Universal Description Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (1.0.100.v200606130315) "Web Services Graphical User
org.eclipse.ltk.core.refactoring (3.2.0.v20060605-1400) "Refactoring Core"
[Active]
org.eclipse.ltk.ui.refactoring (3.2.0.v20060605-1400) "Refactoring UI"
[Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services"
[Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.0.v20060605) "Eclipse Plug-in Development Environment"
[Resolved]
org.eclipse.pde.build (3.2.0.v20060603) "Plug-in Development Environment
Build Support" [Resolved]
org.eclipse.pde.core (3.2.0.v20060605) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.2.0.v20060605) "Eclipse Plug-in Development User
Guide" [Resolved]
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in Test"
[Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development Environment
Runtime" [Resolved]
Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.0.v20060605) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.2.0.v20060601) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.0.v20060612-0900) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.0.v20060605) "Eclipse Workbench User
Guide" [Resolved]
Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.0.v20060609m-AgOexn6hlEUsvBO) "Eclipse Platform Plug-in Developer
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.2.0.v20060609m-SVDNgVrNoh-MeGG)
"Eclipse RCP Plug-in Developer Resources" [Resolved]
org.eclipse.sdk (3.2.0.v20060605) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.0.v20060605-1400) "Search Support" [Resolved]
org.eclipse.swt (3.2.0.v3232o) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.0.v3232m) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.2.0.I200606051140) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.0.M20060628) "CVS Team Provider Core"
[Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.0.I200606051140) "CVS Team Provider UI"
[Resolved]
org.eclipse.team.ui (3.2.0.I200606051140) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.0.I20060605-1400) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Active]
org.eclipse.ui.cheatsheets (3.2.0.v20060602) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.0.v20060605-1400) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.100.v20060605) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.2.0.I20060605-1400) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.0.v20060601) "Welcome Framework" [Resolved]
org.eclipse.ui.intro.universal (3.2.0.v20060602) "Universal Welcome"
[Resolved]
org.eclipse.ui.navigator (3.2.0.I20060605-1400) "Common Navigator View"
[Active]
org.eclipse.ui.navigator.resources (3.2.0.I20060605-1400) "Navigator
Workbench Components" [Active]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation
Plug-in" [Resolved]
org.eclipse.ui.views (3.2.0.I20060605-1400) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.0.I20060605-1400) "Tabbed
Properties View" [Resolved]
org.eclipse.ui.win32 (3.2.0.I20060605-1400) "Eclipse UI Win32 Enhancements"
[Resolved]
org.eclipse.ui.workbench (3.2.0.I20060605-1400) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench
Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor
Framework" [Active]
org.eclipse.update.configurator (3.2.0.v20060605) "Install/Update
Configurator" [Active]
org.eclipse.update.core (3.2.0.v20060605) "Install/Update Core" [Active]
org.eclipse.update.core.win32 (3.2.0.v20060605) "Install/Update Core for
Windows" [Resolved]
org.eclipse.update.scheduler (3.2.0.v20060605) "Automatic Updates Scheduler"
[Active]
org.eclipse.update.ui (3.2.0.v20060605) "Install/Update UI" [Resolved]
org.eclipse.wst (1.0.1.v200605040144) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.101.v200606130645) "Environment Command
Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.101.v200606130645) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.infopop (1.0.2.v200605070230) "Web services UI"
[Resolved]
org.eclipse.wst.command.env.ui (1.0.101.v200606130645) "Environment Command
Framework (GUI)" [Resolved]
org.eclipse.wst.common.core (1.1.0.v200606130645) "WST Common Core Plug-in"
[Resolved]
org.eclipse.wst.common.emf (1.1.0.v200606130645) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (1.1.0.v200606130645) "EMF
Workbench Edit Plug-in" [Active]
org.eclipse.wst.common.environment (1.0.100.v200606130645) "Enviornment
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.1.0.v200606130645) "Common Frameworks"
[Active]
org.eclipse.wst.common.frameworks.ui (1.1.0.v200606130645) "WTP UI Plug-in"
[Active]
org.eclipse.wst.common.infopop (1.0.1.v200605270041) "Common WST infopops"
[Resolved]
org.eclipse.wst.common.modulecore (1.1.0.v200606222043) "Modulecore Plug-in"
[Active]
org.eclipse.wst.common.project.facet.core (1.1.0.v200606130645) "Project
Facet Core" [Active]
org.eclipse.wst.common.project.facet.ui (1.1.0.v200606130645) "Project Facet
UI" [Active]
org.eclipse.wst.common.snippets (1.1.0.v200606141450) "Snippets View"
[Resolved]
org.eclipse.wst.common.ui (1.1.0.v200606142122) "Eclipse Base UI extensions"
[Resolved]
org.eclipse.wst.common.ui.properties (1.0.100.v200606130645) "Common
Properties UI" [Resolved]
org.eclipse.wst.common.uriresolver (1.1.0.v200606130645) "Common URI
Resolver Framework" [Active]
org.eclipse.wst.css.core (1.1.0.v200606141450) "Structured Source CSS Model"
[Active]
org.eclipse.wst.css.ui (1.0.100.v200606141450) "SSE CSS Source Editor"
[Active]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.1.v200605040131) "Data
org.eclipse.wst.datatools.data.ui.doc.user (1.0.1.v200605070230) "Data tools
data user interface documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.201.v200605070230) "Data
org.eclipse.wst.datatools.server.ui.doc.user (1.0.1.v200605070230) "Database
Explorer documentation" [Resolved]
org.eclipse.wst.doc.user (1.0.201.v200605181647) "Master User Doc TOC"
[Resolved]
org.eclipse.wst.dtd.core (1.1.0.v200606141450) "Structured Source DTD Core"
[Resolved]
org.eclipse.wst.dtd.ui (1.0.100.v200606141450) "SSE DTD Source Editor"
[Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200605040131) "DTD Editor infopops"
[Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.2.v200605040131) "DTD Editor
org.eclipse.wst.html.core (1.1.0.v200606141450) "Structured Source HTML
Model" [Active]
org.eclipse.wst.html.standard.dtds (1.0.0) "Known DTDs" [Resolved]
org.eclipse.wst.html.ui (1.0.100.v200606191945) "HTML UI Source Editor"
[Active]
org.eclipse.wst.html.ui.infopop (1.0.1.v200605040131) "HTML editor infopops"
[Resolved]
org.eclipse.wst.internet.cache (1.0.101.v200606130645) "Cache URI Resolver
Plug-in" [Resolved]
org.eclipse.wst.internet.monitor.core (1.0.102.v200606130645) "Monitor"
[Active]
org.eclipse.wst.internet.monitor.ui (1.0.102.v200606130645) "TCP/IP Monitor"
[Active]
org.eclipse.wst.internet.proxy (1.0.100.v200606130645) "Internet Proxy
Preferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200605070230) "Internet Proxy
Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.0.v200606141450) "Structured Source
JavaScript Model" [Active]
org.eclipse.wst.javascript.ui (1.0.0.v200606141450) "SSE JavaScript Source
Editor" [Active]
org.eclipse.wst.javascript.ui.infopop (1.0.1.v200605040131) "Javascript
infopop" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.101.v200606130645) "RDB
Connection.ui" [Resolved]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0.v200605040131) "New
Connection wizard infopops" [Resolved]
org.eclipse.wst.rdb.core (1.0.107.v200606221744) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.102.v200606130645) "Core UI plugin"
[Resolved]
org.eclipse.wst.rdb.data.core (1.0.104.v200606130645) "Data Core Plugin"
[Resolved]
org.eclipse.wst.rdb.data.ui (1.0.105.v200606130645) "Data UI Plugin"
[Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.102.v200606221744) "DB2
UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.103.v200606221744) "DB2 UDB
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.102.v200606221744) "DB2
UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.derby (1.0.102.v200606221744) "Derby
Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.generic.jdbc (1.0.101.v200605040131)
"DBDefinition Generic JDBC Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.102.v200605082300) "Informix
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.0.v200605040131) "DBDefinition
Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.101.v200605040131) "Oracle
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.102.v200605040131) "SQL
Server Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.103.v200606221744) "Sybase
org.eclipse.wst.rdb.derby (1.0.101.v200606130645) "RDB Derby Plug-in"
[Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.101.v200606130645) "RDB Derby Ui Plug-in"
[Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.101.v200606130645) "FE UI Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (1.0.101.v200606130645) "FE Ui Actions
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0.v200605040131) "Generate DDL wizard
org.eclipse.wst.rdb.models.dbdefinition (1.0.101.v200606130645)
"DBDefinition Model" [Resolved]
org.eclipse.wst.rdb.models.sql (1.0.102.v200606130645) "SQLModel Plug-in"
[Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.102.v200606130645) "SQLModel Edit
Plug-in" [Resolved]
org.eclipse.wst.rdb.mysql (1.0.101.v200606130645) "RDB Mysql Plug-in"
[Resolved]
org.eclipse.wst.rdb.outputview (1.0.104.v200606130645) "Data Output Plug-in"
[Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0.v200605040131) "Data Output
view infopops" [Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.102.v200606130645) "Server
Explorer Extensions Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.101.v200606130645) "Server Explorer
plugin" [Resolved]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0.v200605040131) "Server Explorer
org.eclipse.wst.rdb.sqleditor (1.0.103.v200606130645) "SQL Source Editor
Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0.v200605040131) "SQL infopops"
[Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.101.v200606130645) "Sqlscrapbook
Plug-in" [Resolved]
org.eclipse.wst.server.core (1.0.102.v200606130645) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.102.v200606130645) "Server UI" [Active]
org.eclipse.wst.server.ui.doc.user (1.0.2.v200605040131) "Server Tools
documentation for Web Standard Tools" [Resolved]
org.eclipse.wst.server.ui.infopop (1.0.2.v200605040131) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sqleditor.doc.user (1.0.0.v200605270041) "SQL Editor
org.eclipse.wst.sse.core (1.1.0.v200606141450) "Structured Text Model"
[Active]
org.eclipse.wst.sse.doc.user (1.0.201.v200605152316) "Structured text editor
and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.101.v200606191900) "Structured Source Editor"
[Active]
org.eclipse.wst.sse.ui.infopop (1.0.101.v200605040131) "SSE infopops"
[Resolved]
org.eclipse.wst.validation (1.1.0.v200606130645) "Validation Framework"
[Active]
org.eclipse.wst.validation.infopop (1.0.201.v200606130645) "WST validation
infopop plug-in" [Resolved]
org.eclipse.wst.validation.ui (1.1.0.v200606130645) "Validation Framework
UI" [Resolved]
org.eclipse.wst.web (1.1.0.v200606222043) "Simple Web Plug-in" [Active]
org.eclipse.wst.web.ui (1.1.0.v200606161959) "Simple Web UI Plug-in"
[Active]
org.eclipse.wst.web.ui.infopop (1.0.201.v200605070230) "Static Web infopop"
[Resolved]
org.eclipse.wst.webtools.doc.user (1.0.201.v200605181650) "Web tools
org.eclipse.wst.ws (1.0.100.v200606130645) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (1.0.101.v200606130645) "Web Services Explorer"
[Resolved]
org.eclipse.wst.ws.infopop (1.0.201.v200605152241) "Web Services UI"
[Resolved]
org.eclipse.wst.ws.parser (1.0.100.v200606130645) "Web Services Description
Parser" [Resolved]
org.eclipse.wst.ws.ui (1.0.100.v200606130645) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (1.0.100.v200606130645) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (1.1.0.v200606142122) "WSDL UI" [Resolved]
org.eclipse.wst.wsdl.ui.doc.user (1.0.201.v200605111623) "WSDL Editor
org.eclipse.wst.wsdl.validation (1.1.0.v200606130645) "WSDL Validator"
[Resolved]
org.eclipse.wst.wsi (1.0.101.v200606130645) "WSI Conformance Tools"
[Resolved]
org.eclipse.wst.wsi.ui (1.0.0.v200606130645) "Soap Monitor" [Resolved]
org.eclipse.wst.wsi.ui.doc.user (1.0.201.v200605111705) "WS-I Validation
org.eclipse.wst.xml.core (1.1.0.v200606142000) "Structured Source XML Model"
[Active]
org.eclipse.wst.xml.ui (1.0.100.v200606141450) "XML UI Plugin" [Active]
org.eclipse.wst.xml.ui.infopop (1.0.1.v200605040131) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.201.v200605040131) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.1.0.v200606130645) "XSD Core Plugin" [Resolved]
org.eclipse.wst.xsd.ui (1.1.0.v200606142122) "XML Schema Editor" [Resolved]
org.eclipse.wst.xsdeditor.doc.user (1.0.201.v200605181657) "XML schema
editor" [Resolved]
[Resolved]
org.eclipse.xsd.cheatsheets (2.2.0.v200606271057) "XML Schema Infoset Model
(XSD) Cheat Sheets" [Resolved]
org.eclipse.xsd.ecore.exporter (2.2.0.v200606271057) "XML Schema Exporter
for EMF" [Resolved]
org.eclipse.xsd.ecore.importer (2.2.0.v200606271057) "XML Schema Importer
for EMF" [Resolved]
org.eclipse.xsd.edit (2.2.0.v200606271057) "XML Schema Edit Framework"
[Resolved]
org.eclipse.xsd.editor (2.2.0.v200606271057) "XML Schema Editor" [Resolved]
Source" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.junit4 (4.1.0) "JUnit Testing Framework Version 4" [Resolved]
org.uddi4j (2.0.4.v200606181221) "UDDI4J 2.0.4" [Resolved]
org.wsdl4j (1.4.0.v200606181221) "WSDL4J 1.4" [Resolved]
system.bundle (3.2.0.v20060601) "OSGi System Bundle" [Active]
*** User Preferences:
#Thu Sep 21 10:36:01 BST 2006
/instance/org.eclipse.wst.server.core/module-start-timeout=3 00000
@org.eclipse.debug.ui=3.2.0.v20060605
@org.eclipse.wst.internet.cache=1.0.101.v200606130645
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
/instance/org.eclipse.ui.editors/org.eclipse.jst.jsp.core.js psource.source.internal.delegateSaveAs=true
@org.eclipse.ui.ide=3.2.0.I20060605-1400
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1158326399515 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1158250684156" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_06" path\="C\:\\Program Files\\Java\\jre1.5.0_06"/>\r\n<vm
id\="1158326399453" javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"
name\="j2re1.4.1_02" path\="C\:\\Program Files\\Java\\j2re1.4.1_02"/>\r\n<vm
id\="1158326399468" javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"
name\="j2re1.4.2_05" path\="C\:\\Program Files\\Java\\j2re1.4.2_05"/>\r\n<vm
id\="1158326399484" javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"
name\="j2re1.4.2_06" path\="C\:\\Program Files\\Java\\j2re1.4.2_06"/>\r\n<vm
id\="1158326399500" javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api/"
name\="j2re1.4.2_08" path\="C\:\\Program Files\\Java\\j2re1.4.2_08"/>\r\n<vm
id\="1158326399515" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jdk1.5.0_08" path\="C\:\\Program Files\\Java\\jdk1.5.0_08"/>\r\n<vm
id\="1158326399531" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_02" path\="C\:\\Program Files\\Java\\jre1.5.0_02"/>\r\n<vm
id\="1158326399546" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_04" path\="C\:\\Program Files\\Java\\jre1.5.0_04"/>\r\n<vm
id\="1158326399562" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_08" path\="C\:\\Program
Files\\Java\\jre1.5.0_08"/>\r\n</vmType>\r\n</vmSettings >\r\n
@org.eclipse.pde.core=3.2.0.v20060605
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_DEFAULT_ENVIRONMENTS_XML= <?xml
version\="1.0"
encoding\="UTF-8"?>\r\n<defaultEnvironments>\r\n<defaultEnvironment
environmentId\="J2SE-1.5"
vmId\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1158250684156 "/>\r\n</defaultEnvironments>\r\n
/project/JSFTutorial/org.eclipse.jst.common.project.facet.co re/classpath.helper/org.eclipse.jst.server.core.container\:\ :org.eclipse.jst.server.tomcat.runtimeTarget\:\:Apache\
Tomcat\ v5.5/owners=jst.web\:2.3
/project/MyWebProject/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.compliance=1.4
/project/MyWebProject/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.codegen.targetPlatform=1.2
/instance/org.eclipse.jst.server.tomcat.core/locationorg.ecl ipse.jst.server.tomcat.runtime.55=C\:/Program
Files/Apache Software Foundation/Tomcat 5.5
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.jst.jsp.core/jspIndexState=1
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/project/MyWebProject/org.eclipse.ltk.core.refactoring/org.e clipse.ltk.core.refactoring.enable.project.refactoring.histo ry=false
@org.eclipse.jdt.ui=3.2.0.v20060605-1400
/project/JSFTutorial/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.problem.enumIdentifier=warning
/instance/org.eclipse.core.resources/version=1
@org.eclipse.core.resources=3.2.0.v20060603
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=28
/instance/org.eclipse.help.ui/browser.x=0
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.pde.core/platform_path=C\:\\Usr\\eclip se3.3\\eclipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/project/JSFTutorial/org.eclipse.wst.validation/USER_PREFERE NCE=overrideGlobalPreferencesfalse
@org.eclipse.gef=3.2.0.v20060626
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/instance/org.eclipse.wst.internet.cache//http\://developers .sun.com/license/berkeley_license.html=1
file_export_version=3.0
@org.eclipse.jdt.launching=3.2.0.v20060605
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.help.ui/browser.h=740
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.wst.server.core/runtimes=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<runtimes>\r\n<runtime id\="Apache Tomcat v5.5"
location\="C\:/Program Files/Apache Software Foundation/Tomcat 5.5"
name\="Apache Tomcat v5.5"
runtime-type-id\="org.eclipse.jst.server.tomcat.runtime.55" timestamp\="2"
vm-install-id\="1158250684156"
vm-install-type-id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType "/>\r\n</runtimes>\r\n
/instance/org.eclipse.wst.internet.monitor.core/monitors=<?xml
version\="1.0" encoding\="UTF-8"?>\r\n<monitors>\r\n<monitor
local-port\="14603" remote-host\="localhost" remote-port\="8080"
timeout\="0" type-id\="HTTP"/>\r\n<monitor local-port\="14200"
remote-host\="localhost" remote-port\="8080" timeout\="0"
type-id\="HTTP"/>\r\n</monitors>\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_SRC_HOME=C\:/Usr/eclipse3.3/eclipse/plugins/ org.eclipse.jdt.source_3.2.0.v20060609m-F7snq1fxia-Z4XP/src/ org.junit_3.8.1
/project/MyWebProject/org.eclipse.jdt.core/org.eclipse.jdt.c ore.compiler.source=1.3
@org.eclipse.wst.sse.ui=1.0.101.v200606191900
/project/JSFTutorial/org.eclipse.jst.common.project.facet.co re/classpath.helper/org.eclipse.jdt.launching.JRE_CONTAINER\ :\:org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType \:\:jre1.5.0_06/owners=jst.java\:1.4
/instance/org.eclipse.ui.ide/platformState=1158771972966
/instance/org.eclipse.wst.sse.core/task-tag-projects-already -scanned=MyWebProject,Servers,JSFTutorial
/project/JSFTutorial/org.eclipse.jdt.core/org.eclipse.jdt.co re.compiler.codegen.targetPlatform=1.2
/project/JSFTutorial/org.eclipse.wst.validation/USER_BUILD_P REFERENCE=enabledBuildValidatorListorg.eclipse.wst.xml.core. internal.validation.eclipse.Validator;org.eclipse.jst.jsp.co re.internal.validation.JSPDirectiveValidator;org.eclipse.wst .html.internal.validation.HTMLValidator;org.eclipse.jst.j2ee .internal.web.validation.UIWarValidator;org.eclipse.jst.jsp. core.internal.validation.JSPELValidator;org.eclipse.wst.xsd. core.internal.validation.eclipse.XSDDelegatingValidator;org. eclipse.jst.jsp.core.internal.validation.JSPJavaValidator;or g.eclipse.jst.jsf.validation.internal.JSPSemanticsValidator; org.eclipse.wst.wsdl.validation.internal.eclipse.WSDLDelegat ingValidator;org.eclipse.wst.dtd.core.internal.validation.ec lipse.Validator;org.eclipse.wst.wsi.ui.internal.WSIMessageVa lidator;
/project/MyWebProject/org.eclipse.jst.common.project.facet.c ore/classpath.helper/org.eclipse.jdt.launching.JRE_CONTAINER \:\:org.eclipse.jdt.internal.debug.ui.launcher.StandardVMTyp e\:\:j2sdk1.4.2_08/owners=jst.java\:1.4
@org.eclipse.wst.server.core=1.0.102.v200606130645
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=
Re: Exception with jsf login Tutorial [message #473456 is a reply to message #472972] Thu, 21 September 2006 13:19 Go to previous messageGo to next message
Hmm.. What JSP page in the tutorial are you trying to run when you get
this? Can you post the markup and the steps to reproduce?
--Cam
Re: Exception with jsf login Tutorial [message #473457 is a reply to message #473456] Thu, 21 September 2006 14:01 Go to previous messageGo to next message
Hi Cam,
yeah its the login -> welcome tutorial
login.jsp has
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
pageEncoding="ISO-8859-1"%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<%@ taglib uri="http://java.sun.com/jsf/core" prefix="f"%>
<%@ taglib uri="http://java.sun.com/jsf/html" prefix="h"%>
<html>
<f:view>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<title>Login</title>
<f:loadBundle basename="com.tutorial.messages" var="msg"/>
</head>
<body>
<h:form>
<h:messages layout="table"></h:messages>
<h:panelGrid columns="2">
<h:outputLabel rendered="true" value="#{msg.name}"></h:outputLabel>
<h:inputText value="#{loginBean.name}" tabindex="0"></h:inputText>
<h:outputLabel rendered="true" value="#{msg.password}"></h:outputLabel>
<h:inputSecret value="#{loginBean.password.convertedID}">
<f:converter converterId="javax.faces.Long"/>
<f:validator validatorId="com.tutorial.validatePassword"/>
</h:inputSecret>
</h:panelGrid>
<h:commandButton action="login" value="#{msg.login}"></h:commandButton >
</h:form>
</body>
</f:view>
</html>
welcome.jsp has
<html>
<f:view>
<head>
<title>Welcome</title>
</head>
<body>
<h:form>
<h:outputLabel value="#{msg.welcome} #{loginBean.name}"></h:outputLabel>
</h:form>
</body>
</f:view>
</html>
faces-config has
<!DOCTYPE faces-config PUBLIC
"-//Sun Microsystems, Inc.//DTD JavaServer Faces Config 1.1//EN"
"http://java.sun.com/dtd/web-facesconfig_1_1.dtd">
<faces-config>
<application>
<message-bundle>
com.tutorial.messages</message-bundle>
</application>
<managed-bean>
<managed-bean-name>
loginBean</managed-bean-name>
<managed-bean-class>
com.tutorial.LoginBean</managed-bean-class>
<managed-bean-scope>
session</managed-bean-scope>
</managed-bean>
<navigation-rule>
<display-name>
login</display-name>
<from-view-id>
/login.jsp</from-view-id>
<navigation-case>
<from-outcome>
login</from-outcome>
<to-view-id>
/welcome.jsp</to-view-id>
</navigation-case>
</navigation-rule>
<validator>
<display-name>
Validate Password</display-name>
<validator-id>
com.tutorial.validatePassword</validator-id>
<validator-class>
com.tutorial.validatePassword</validator-class>
</validator>
</faces-config>
When Tomcat 5.5.17 starts it outputs to console this
1-Sep-2006 18:49:48 org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFO: The Apache Tomcat Native library which allows optimal performance in
production environments was not found on the java.library.path: C:\Program
7.0\\bin
21-Sep-2006 18:49:48 org.apache.coyote.http11.Http11BaseProtocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
21-Sep-2006 18:49:48 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1047 ms
21-Sep-2006 18:49:49 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
21-Sep-2006 18:49:49 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.5.17
21-Sep-2006 18:49:49 org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
21-Sep-2006 18:49:50 org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
21-Sep-2006 18:49:51 org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
21-Sep-2006 18:49:51 org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/63 config=null
21-Sep-2006 18:49:51 org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
21-Sep-2006 18:49:51 org.apache.catalina.startup.Catalina start
INFO: Server startup in 2547 ms
When I run login.jsp I get this
HTTP Status 500 -
message
exception
org.apache.jasper.JasperException: javax.servlet.jsp.JspException:
javax.faces.FacesException: java.util.MissingResourceException: Can't find
bundle for base name com.tutorial.messages, locale en_GB
root cause
javax.servlet.ServletException: javax.servlet.jsp.JspException:
org.apache.jasper.runtime.PageContextImpl.doHandlePageExcept ion(PageContextImpl.java:854)
org.apache.jasper.runtime.PageContextImpl.handlePageExceptio n(PageContextImpl.java:791)
org.apache.jsp.login_jsp._jspService(login_jsp.java:100)
root cause
javax.faces.el.EvaluationException: javax.faces.FacesException:
java.util.MissingResourceException: Can't find bundle for base name
com.sun.faces.el.ValueBindingImpl.getValue(ValueBindingImpl. java:206)
com.sun.faces.el.ValueBindingImpl.getValue(ValueBindingImpl. java:154)
javax.faces.component.UIOutput.getValue(UIOutput.java:147)
com.sun.faces.renderkit.html_basic.HtmlBasicInputRenderer.ge tValue(HtmlBasicInputRenderer.java:82)
com.sun.faces.renderkit.html_basic.HtmlBasicRenderer.getCurr entValue(HtmlBasicRenderer.java:191)
com.sun.faces.renderkit.html_basic.HtmlBasicRenderer.encodeE nd(HtmlBasicRenderer.java:169)
javax.faces.component.UIComponentBase.encodeEnd(UIComponentB ase.java:720)
com.sun.faces.renderkit.html_basic.HtmlBasicRenderer.encodeR ecursive(HtmlBasicRenderer.java:443)
com.sun.faces.renderkit.html_basic.GridRenderer.encodeChildr en(GridRenderer.java:233)
javax.faces.component.UIComponentBase.encodeChildren(UICompo nentBase.java:701)
javax.faces.webapp.UIComponentTag.encodeChildren(UIComponent Tag.java:607)
javax.faces.webapp.UIComponentTag.doEndTag(UIComponentTag.ja va:544)
com.sun.faces.taglib.html_basic.PanelGridTag.doEndTag(PanelG ridTag.java:460)
org.apache.jsp.login_jsp._jspx_meth_h_panelGrid_0(login_jsp. java:228)
org.apache.jsp.login_jsp._jspx_meth_h_form_0(login_jsp.java: 162)
org.apache.jsp.login_jsp._jspx_meth_f_view_0(login_jsp.java: 126)
org.apache.jsp.login_jsp._jspService(login_jsp.java:87)
Tomcat/5.5.17 logs.
Many thanks for your time in looking at this for me.
Very much appreciated.
Graham
"Cameron Bateman" <cameron.bateman@oracle.com> wrote in message
news:9573acf943810302f7a8988d8085e1e1$1@www.eclipse.org...
> --Cam
Re: Exception with jsf login Tutorial [message #473458 is a reply to message #473457] Thu, 21 September 2006 15:03 Go to previous messageGo to next message
This appears to be a different error. Before, it appeared that something
was missing from Tomcat's classpath. The fact that you are getting this
new error implies you have somehow solved this error...
If you look at the output, you will notice that your locale is set for
en_GB. This means that your f:loadBundle tag will search your classpath
for com/tutorial/messages_en_GB.properties. We probably should update our
tutorial to account for non-US users, although I find it strange that the
bundle loader didn't default to messages.properties which is where it
should go if the localized file is not present. Do you have a
messages.properties in your com.tutorial package? If so, try copying it
in the same location but rename to messages_en_GB.properties and see if
the error goes away.
--Cam
> root cause
Re: Exception with jsf login Tutorial [message #473460 is a reply to message #473458] Fri, 22 September 2006 06:41 Go to previous messageGo to next message
Originally posted by: graham.raima.co.uk
Hi Cameron,
Yes I do have a messages.properties in my com.tutorial package, I tried
copying it to messages_en_GB.properties but it would throw the following
I noticed that in the faces-config there is an locale-config section, I
added en_GB locale to list and checked the checkbox but same error. If I
remove all refs to the messages and the loadbundle, it works, but I am
seeing some perculiar results. When I add items to the form, save and then
Run On Server, the resulting html page contains half of the previous version
of the page and help of the new page, even though the edit boxes and labels
I am seeing are no longer in the source jsp file that I am running.
Many thanks for your time.
Graham
news:6af325b0efd264e55f826d4356235f8f$1@www.eclipse.org...
> --Cam
>> find bundle for base name com.tutorial.messages, locale en_GB
>> root cause
Re: Exception with jsf login Tutorial [message #473465 is a reply to message #473460] Tue, 26 September 2006 16:59 Go to previous messageGo to next message
Strange. If you want to attach a zip of your project to a bugzilla bug, I
can try to take a look.
--Cam
> Hi Cameron,
> Regards
> Graham
Re: Exception with jsf login Tutorial [message #473471 is a reply to message #473465] Tue, 03 October 2006 13:08 Go to previous message
Thanks, Cameron,
I started my installtion again from scratch and now it working ok.
case closed.
news:11196e29c989f34375b3aedbe4c13b09$1@www.eclipse.org...
> --Cam
>> Hi Cameron,
>> then Run On Server, the resulting html page contains half of the previous
>> version of the page and help of the new page, even though the edit boxes
>> and labels I am seeing are no longer in the source jsp file that I am
>> running.
>> Regards
>> Graham
Re: Exception with jsf login Tutorial [message #607639 is a reply to message #472969] Wed, 20 September 2006 18:39 Go to previous message
Hi Graham,
the app.
--Cam
> Hi All,
> I am getting an exception when I run the JSF login tutorial. I have
> spent many many hours trying to figure this out,
> any help gratefully received.
Re: Exception with jsf login Tutorial [message #607644 is a reply to message #472971] Thu, 21 September 2006 05:40 Go to previous message
Dialog
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
df4_7a8
-clean
-vm
-Xmx256m
-jar
eof=eof
file.separator=\
7.0\\bin
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.clean=true
osgi.nl=en_GB
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.cpu.isalist=
sun.desktop=windows
user.country=GB
user.language=en
user.variant=
*** Features:
Programmers Guide"
(SDO)"
(EMF) Source"
Resources"
Tools"
Source"
Tooling"
(JST)"
(WST)"
Programmers Guide"
Source"
(ICU4J)" [Active]
Plug-in" [Resolved]
Plug-in" [Resolved]
[Active]
[Active]
[Active]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
(SDO)" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Mapping" [Resolved]
Mapping" [Resolved]
Mapping" [Resolved]
[Active]
Mechanism" [Active]
[Active]
[Resolved]
[Resolved]
Core" [Resolved]
UI" [Resolved]
support" [Resolved]
[Active]
[Resolved]
Source" [Resolved]
[Active]
Support" [Active]
[Resolved]
Plug-in" [Resolved]
Plug-in" [Resolved]
[Active]
[Active]
[Resolved]
[Resolved]
[Active]
Plug-in" [Active]
Plug-in" [Resolved]
Plug-in" [Resolved]
[Resolved]
[Active]
Plug-in" [Resolved]
[Active]
[Installed]
Plug-in" [Active]
Plug-in" [Resolved]
Plug-in" [Resolved]
[Installed]
Plug-in" [Active]
[Active]
[Active]
[Resolved]
[Active]
Plugin" [Active]
servers" [Resolved]
Support" [Active]
Support" [Resolved]
[Active]
[Active]
[Resolved]
UI" [Resolved]
UI" [Resolved]
[Resolved]
[Resolved]
[Active]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Guide" [Resolved]
[Resolved]
Runtime" [Resolved]
Guide" [Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Active]
Plug-in" [Resolved]
[Resolved]
Framework" [Active]
Windows" [Resolved]
[Active]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Active]
[Active]
[Resolved]
[Active]
UI" [Active]
[Resolved]
[Resolved]
[Active]
[Active]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Model" [Active]
[Active]
[Resolved]
Plug-in" [Resolved]
[Active]
[Active]
Editor" [Active]
infopop" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
plugin" [Resolved]
Plugin" [Resolved]
[Resolved]
Plug-in" [Resolved]
[Active]
[Active]
[Resolved]
[Active]
UI" [Resolved]
[Active]
[Resolved]
[Resolved]
[Resolved]
Parser" [Resolved]
[Resolved]
[Resolved]
[Active]
[Resolved]
[Resolved]
editor" [Resolved]
[Resolved]
for EMF" [Resolved]
for EMF" [Resolved]
[Resolved]
Source" [Resolved]
version\="1.0"
Re: Exception with jsf login Tutorial [message #607979 is a reply to message #472972] Thu, 21 September 2006 13:19 Go to previous message
--Cam
Re: Exception with jsf login Tutorial [message #607983 is a reply to message #473456] Thu, 21 September 2006 14:01 Go to previous message
Hi Cam,
login.jsp has
<html>
<f:view>
<head>
</head>
<body>
<h:form>
</h:inputSecret>
</h:panelGrid>
</h:form>
</body>
</f:view>
</html>
welcome.jsp has
<html>
<f:view>
<head>
</head>
<body>
<h:form>
</h:form>
</body>
</f:view>
</html>
faces-config has
<faces-config>
<application>
<message-bundle>
</application>
<managed-bean>
<managed-bean-name>
</managed-bean>
<navigation-rule>
<display-name>
<from-view-id>
<navigation-case>
<from-outcome>
<to-view-id>
</navigation-case>
</navigation-rule>
<validator>
<display-name>
<validator-id>
<validator-class>
</validator>
</faces-config>
lifecycleEvent
Files\Java\jre1.5.0_06\bin;.;C:\WINDOWS\system32;C:\WINDOWS; C:\Program
Files\Java\jre1.5.0_06\bin;C:\WINDOWS\system32;C:\WINDOWS;C: \WINDOWS\system32\wbem;c:\program
files\common files\watchguard\lib;c:\usr\binw;c:\usr\bin;;C:\Program
Files\STI\bin\pc-win95;C:\Program Files\Birdstep Technology\RDM Server
7.0\\bin
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
org.apache.jasper.servlet.JspServletWrapper.handleJspExcepti on(JspServletWrapper.java:510)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:375)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
com.sun.faces.context.ExternalContextImpl.dispatch(ExternalC ontextImpl.java:322)
com.sun.faces.application.ViewHandlerImpl.renderView(ViewHan dlerImpl.java:130)
com.sun.faces.lifecycle.RenderResponsePhase.execute(RenderRe sponsePhase.java:87)
com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.ja va:200)
com.sun.faces.lifecycle.LifecycleImpl.render(LifecycleImpl.j ava:117)
javax.faces.webapp.FacesServlet.service(FacesServlet.java:19 8)
root cause
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:332)
root cause
note The full stack trace of the root cause is available in the Apache
Tomcat/5.5.17 logs.
Graham
> --Cam
Re: Exception with jsf login Tutorial [message #607984 is a reply to message #473457] Thu, 21 September 2006 15:03 Go to previous message
--Cam
> root cause
Re: Exception with jsf login Tutorial [message #607988 is a reply to message #473458] Fri, 22 September 2006 06:41 Go to previous message
Hi Cameron,
Graham
> --Cam
>> root cause
Re: Exception with jsf login Tutorial [message #608002 is a reply to message #473460] Tue, 26 September 2006 16:59 Go to previous message
--Cam
Graham Watson wrote:
> Hi Cameron,
> Regards
> Graham
Re: Exception with jsf login Tutorial [message #608014 is a reply to message #473465] Tue, 03 October 2006 13:08 Go to previous message
Thanks, Cameron,
case closed.
> --Cam
>> Hi Cameron,
>> running.
>> Regards
>> Graham
Previous Topic:JSF Tools project montly status meeting minutes: September 11, 2006
Next Topic:Is the 1.5.1 release of the JSF platform going to be available from the update site?
Current Time: Wed Jul 23 11:36:05 EDT 2025
Powered by FUDForum. Page generated in 0.61880 seconds
