Home » Modeling » UML2 » Validation Problem
Validation Problem [message #473446] Thu, 28 June 2007 06:50 Go to next message
Originally posted by: antti.evesti.vtt.fi
When I validate an ecore profile which I get after profile definition I get
'Validation Problems' warning that says 'Reason: Diagnosis of
<<Package>><Profile> Ecore Profile', and details view shows 'Not all the
members of namespace <Profile> Ecore Profile are distinguishable within it.'
If I validate my profile validation ends succesfully.
This doesn't cause any further problems, but it would be nice to know if I
have constructed my profile in a wrong way.
Antti
Re: Validation Problem [message #473448 is a reply to message #473446] Thu, 28 June 2007 09:24 Go to previous messageGo to next message
Hi Antti,
Are there any obvious items with the same name within your profile? If
not, would it be possible to post your profile.
Not all the validation rules have been implemented in UML.
EMF validation rules are different so you might get a UML model that passes
UML validation but the resulting .ecore representation having warnings or
errors.
- James
"Antti Evesti" <antti.evesti@vtt.fi> wrote in message
news:f603pr$3mi$1@build.eclipse.org...
get
it.'
> Antti
Re: Validation Problem [message #473454 is a reply to message #473448] Fri, 29 June 2007 01:58 Go to previous messageGo to next message
Hi James,
I noticed this issue with many profiles as well as this simple profile that
contains only one stereotype applicable to component element.
Below is the content of the profile, I used filename SampleToNews.uml while
constructing this profile. I suppose it is illegal to attach files to this
newsgroup.
Antti
<uml:Profile xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML"
xmi:id="_ETNtoCYEEdyaa53nuWYv-g" name="sampleProfile"
metaclassReference="_KoWqwCYEEdyaa53nuWYv-g">
<eAnnotations xmi:id="_TndTwSYEEdyaa53nuWYv-g"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_TndTwiYEEdyaa53nuWYv-g"
nsURI="http:///schemas/sampleProfile/_TndTwCYEEdyaa53nuWYv-g/0"
nsPrefix="sampleProfile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_TndTwyYEEdyaa53nuWYv-g"
name="sampleStereotype">
<eAnnotations xmi:id="_TndTxCYEEdyaa53nuWYv-g"
references="_MDOtUCYEEdyaa53nuWYv-g"/>
<eStructuralFeatures xmi:type="ecore:EReference"
xmi:id="_TndTxSYEEdyaa53nuWYv-g" name="base_Component" ordered="false"
lowerBound="1">
<eType xmi:type="ecore:EClass"
href="http://www.eclipse.org/uml2/2.0.0/UML#//Component"/>
</eStructuralFeatures>
</eClassifiers>
</contents>
</eAnnotations>
<elementImport xmi:id="_KoWqwCYEEdyaa53nuWYv-g">
<importedElement xmi:type="uml:Class"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Component"/>
</elementImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_MDOtUCYEEdyaa53nuWYv-g"
<ownedAttribute xmi:id="_RBYCUiYEEdyaa53nuWYv-g" name="base_Component"
association="_RBYCUCYEEdyaa53nuWYv-g">
<type xmi:type="uml:Class"
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_RBYCUCYEEdyaa53nuWYv-g"
name="Component_sampleStereotype" memberEnd="_RBYCUSYEEdyaa53nuWYv-g
_RBYCUiYEEdyaa53nuWYv-g">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_RBYCUSYEEdyaa53nuWYv-g"
name="extension_sampleStereotype" type="_MDOtUCYEEdyaa53nuWYv-g"
aggregation="composite" association="_RBYCUCYEEdyaa53nuWYv-g"/>
</packagedElement>
</uml:Profile>
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f60cqt$pm9$2@build.eclipse.org...
> Hi Antti,
> passes
> errors.
> - James
>> Hi,
> get
> it.'
>> I
>> Antti
Re: Validation Problem [message #473756 is a reply to message #473446] Wed, 04 July 2007 16:57 Go to previous messageGo to next message
Antti,
You can safely ignore this warning. It's complaining about the fact that the
Ecore profile imports type named 'String' and 'Boolean' but also imports the
UML metamodel package which in turn contains types named 'String' and
'Boolean'.
Kenn
> get 'Validation Problems' warning that says 'Reason: Diagnosis of
> it.'
> Antti
Re: Validation Problem [message #473939 is a reply to message #473756] Tue, 10 July 2007 08:39 Go to previous message
Thanks Kenn,
This relieve me of.
Antti
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f6h1j3$qs1$1@build.eclipse.org...
> Antti,
> the Ecore profile imports type named 'String' and 'Boolean' but also
> imports the UML metamodel package which in turn contains types named
> 'String' and 'Boolean'.
> Kenn
>> Hi,
>> it.'
>> I have constructed my profile in a wrong way.
>> Antti
Re: Validation Problem [message #622661 is a reply to message #473446] Thu, 28 June 2007 09:24 Go to previous message
Hi Antti,
errors.
- James
get
it.'
> Antti
Re: Validation Problem [message #622667 is a reply to message #473448] Fri, 29 June 2007 01:58 Go to previous message
Hi James,
newsgroup.
Antti
lowerBound="1">
</eClassifiers>
</contents>
</eAnnotations>
</elementImport>
</ownedAttribute>
</packagedElement>
</packagedElement>
</uml:Profile>
> Hi Antti,
> passes
> errors.
> - James
>> Hi,
> get
> it.'
>> I
>> Antti
Re: Validation Problem [message #622728 is a reply to message #473446] Wed, 04 July 2007 16:57 Go to previous message
Antti,
'Boolean'.
Kenn
> it.'
> Antti
Re: Validation Problem [message #623315 is a reply to message #473756] Tue, 10 July 2007 08:39 Go to previous message
Thanks Kenn,
This relieve me of.
Antti
> Antti,
> Kenn
>> Hi,
>> it.'
>> Antti
Previous Topic:Load and parse UML file
Next Topic:Modifying existing profile
Current Time: Wed Jul 23 20:21:08 EDT 2025
Powered by FUDForum. Page generated in 0.27486 seconds
