Home » Modeling » UML2 » org.eclipse.emf.ecore.xmi.IllegalValueException
org.eclipse.emf.ecore.xmi.IllegalValueException [message #473435] Wed, 27 June 2007 10:40 Go to next message
I get this exception caught and printed when i load a uml componnt model:
org.eclipse.emf.ecore.xmi.IllegalValueException: Value 'null' is not
legal.
( file:///Users/andrewjackson/workspace/RDL_Project/model/Auct ionSystemArch/ArchCompDiargam.uml,
10, 21)
Below i provide my model, the code i use to load the model and i detail
what i observe when i debug the code.
Here is the offending component model (generated using Magic draw):
https://www.cs.tcd.ie/~ajackso/Archive.zip
It is loaded with the following code:
protected static void registerPathmaps(URI uri) {
URIConverter.URI_MAP.put(URI.createURI("pathmap://UML_LIBRARIES/"), uri
.appendSegment("libraries").appendSegment(""));
URIConverter.URI_MAP.put(URI.createURI("pathmap://UML_METAMODELS/"),
uri.appendSegment("metamodels").appendSegment(""));
URIConverter.URI_MAP.put(URI.createURI("pathmap://UML_PROFILES/"), uri
.appendSegment("profiles").appendSegment(""));
private FileManager() {
.createURI(" jar:file:/Users/andrewjackson/Desktop/cartona-eclipse/plugin s/org.eclipse.uml2.uml.resources_2.1.0.v200705171545.jar!/ "));
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(
UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
"xmi", new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI,
UMLPackage.eINSTANCE);
public org.eclipse.uml2.uml.Package load(URI uri) {
org.eclipse.uml2.uml.Package package_ = null;
try {
Resource resource = resourceSet.getResource(uri, true);
package_ = (org.eclipse.uml2.uml.Package) EcoreUtil
.getObjectByType(resource.getContents(),
UMLPackage.Literals.PACKAGE);
} catch (WrappedException we) { ....}
As far as i can see an exception is thrown at line 271 of the
ResourceSetImpl class and is caught resulting in the message show at the
start of this message. This message is the direct result of line 275 of
the ResourceSetImpl class.
Thanks in advance for your help,
Andrew
Re: org.eclipse.emf.ecore.xmi.IllegalValueException [message #473439 is a reply to message #473435] Wed, 27 June 2007 15:59 Go to previous messageGo to next message
Hi Andrew,
I just tried opening up your model with the UML editor and it opens fine
without error so the model itself seems ok.
You can narrow down the issue by removing the profile applications and
stereotype application from your model and then try opening the model with
your code. Does that work?
- James.
"Andrew Jackson" <Andrew.Jackson@cs.tcd.ie> wrote in message
news:524aebd61670d0149b73e163eb86717d$1@www.eclipse.org...
> legal.
rchCompDiargam.uml,
> 10, 21)
..createURI(" jar:file:/Users/andrewjackson/Desktop/cartona-eclipse/plugin s/or
g.eclipse.uml2.uml.resources_2.1.0.v200705171545.jar!/"));
> try {
> Andrew
Re: org.eclipse.emf.ecore.xmi.IllegalValueException [message #473444 is a reply to message #473439] Thu, 28 June 2007 04:38 Go to previous message
That worked! Thanks for your help.
Re: org.eclipse.emf.ecore.xmi.IllegalValueException [message #622600 is a reply to message #473435] Wed, 27 June 2007 15:59 Go to previous message
Hi Andrew,
- James.
> legal.
rchCompDiargam.uml,
> 10, 21)
> try {
> Andrew
Re: org.eclipse.emf.ecore.xmi.IllegalValueException [message #622657 is a reply to message #473439] Thu, 28 June 2007 04:38 Go to previous message
Previous Topic:TriggerListener for changing values of Element properties from Stereotype
Next Topic:Validation Problem
Current Time: Sun Jul 27 09:10:14 EDT 2025
Powered by FUDForum. Page generated in 0.04279 seconds
