Home » Modeling » UML2 » Modifying existing profile
Modifying existing profile [message #473218] |
Thu, 21 June 2007 04:25  |
Originally posted by: antti.evesti.vtt.fi
I have a problem with modifying UML profile in the programmatic way. I am
trying to add new stereotypes to the existing profile. The problem occurs
when I have added stereotypes from the original profile to the UML diagram,
then I modify the profile in the programmatic way. When I open the UML
diagram after profile modification, the earlier connected stereotypes are
absconded. So, I suppose that I define and save the modified profile in
wrong way because I can successfully perform this scenario by using Eclipses
UML editor, i.e. the tree structured view. I define and save profile using
the same methods that are published in the 'Introduction to UML2 profiles'
article.
I hope that someone can help me with this issue.
Antti
Re: Modifying existing profile [message #473225 is a reply to message #473218] |
Thu, 21 June 2007 09:45   |
Hi Antti,
If you can successfully use the editor to complete your task, you should be
able to do so programatically. The actions from the editor simply call the
API to accomplish its task.
Keep in mind that you need to call define() after modification to your
profile. That will create the proper Ecore representation. You might want
to double check the ecore representation after you call define ( it is kept
under an annotation at the root of the profile ). Also remember to reapply
your profile, stereotypes should then be automatically migrated.
If that still doesn't work, look at the actions and see what functions they
call. Try to duplicate those function calls in your code.
Failing that, please indicate what version of UML you are using, and
possibly send your profile and model so that we can see what is going on.
- James.
"Antti" <antti.evesti@vtt.fi> wrote in message
news:f5dcl6$e4n$1@build.eclipse.org...
diagram,
Eclipses
> article.
> Antti
Re: Modifying existing profile [message #473279 is a reply to message #473225] |
Mon, 25 June 2007 07:19   |
Thanks, that was a good hint. However, how can I check which methods were
called when I perform a task by using UML editor?
I tested my code snippet further and I believe that I save the profile in a
wrong way. Because when I just open a profile and then save it, I come up
against the same problem. I suppose that the used save method is proper, but
how about a method call?
Antti
String name = profile.getName();
URI Uri = URI.createURI("file:/" + profileFolder).appendSegment(name)
.appendFileExtension(UMLResource.PROFILE_FILE_EXTENSION);
save(profile, Uri);
protected static void save(org.eclipse.uml2.uml.Package package_, URI uri) {
Resource resource = RESOURCE_SET.createResource(uri);
resource.getContents().add(package_);
try {
resource.save(null);
} catch (IOException ioe) {
err(ioe.getMessage());
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:f5dvdr$mn4$2@build.eclipse.org...
> Hi Antti,
> be
> the
> want
> kept
> reapply
> they
> Regards,
> - James.
> diagram,
> Eclipses
>> using
>> profiles'
>> article.
>> Antti
Re: Modifying existing profile [message #473283 is a reply to message #473279] |
Mon, 25 June 2007 12:04   |
Hi Antti,
You can download all the code for those actions from cvs. Have a look at
org.eclipse.uml2.uml.editor.actions.
Also have a look at the thread entitled "how to save a model with applied
stereotypes and tag values" for ideas on saving applied steroetypes.
Also, you should look at the ecore representation after the define. If that
is intact, the profile should be good.
- James.
news:f5o8cd$q7q$1@build.eclipse.org...
a
but
> Antti
> save(profile, Uri);
> try {
> > Hi Antti,
> > be
> > the
> > want
> > kept
> > reapply
> > they
on.
> > Regards,
> > - James.
am
occurs
> > diagram,
are
> > Eclipses
> >> using
> >> profiles'
> >> article.
> >> Antti
Re: Modifying existing profile [message #473305 is a reply to message #473283] |
Tue, 26 June 2007 07:37   |
James thanks for your answers.
But I am still unable to save the profile in a suitable way. I checked my
save method and now it looks exactly same as in the "how to save a model
with applied stereotypes and tag values" thread. Therefore, I made a sample
code snippet, as simple as possible. This sample code comes up against same
problem. At first the code opens profile and immediately after that saves it
by using same URI. When I look my UML model that contains stereotypes from
"modified" profile these stereotypes are drown after code execution.
I compared contents of the profile files by using XML editor and I mentioned
that "xmi-id" tags was changed during program execution is this normal?
My code looks as follows:
Main-class:
import org.eclipse.emf.common.util.URI;
import org.eclipse.uml2.uml.Profile;
public class DebugClass extends UMLAssistanceClass{
private Profile profile = null;
private String name = "C:\\Documents and
Settings\\aeantti\\Desktop\\" +
"PoistaKunAddToimii\\Poisto.profile.uml";
private URI uri = URI.createURI("file:/" + name);
public DebugClass() {
open();
store();
private void open() {
profile = loadProfile(uri);
private void store() {
save2(profile, uri);
loadProfile and save2 methods from UMLAssistanceClass
protected static final ResourceSet RESOURCE_SET = new ResourceSetImpl();
protected static org.eclipse.uml2.uml.Profile loadProfile(URI uri) {
org.eclipse.uml2.uml.Profile profile_ = null;
try {
Resource resource = RESOURCE_SET.getResource(uri,
true);
profile_ = (org.eclipse.uml2.uml.Profile)
EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.Literals.PACKAGE);
} catch (WrappedException we) {
err(we.getMessage());
System.exit(1);
return profile_;
protected static void save2(org.eclipse.uml2.uml.Package package_, URI uri)
EList contents = resource.getContents();
contents.add(package_);
for (Iterator allContents = UMLUtil.getAllContents(package_,
true,
false); allContents.hasNext();) {
EObject eObject = (EObject) allContents.next();
if (eObject instanceof Element) {
contents.addAll(((Element)eObject).getStereotypeApplications ());
try {
System.out.println("SAVE2 is used");
Antti
news:f5op21$p45$2@build.eclipse.org...
> Hi Antti,
> that
> Cheers,
> - James.
> a
> but
>> Antti
>> save(profile, Uri);
>> uri)
>> try {
>> > Hi Antti,
>> > should
>> > be
>> > call
>> > the
>> > want
>> > kept
>> > reapply
>> > they
> on.
>> > Regards,
>> > - James.
> am
> occurs
>> > diagram,
> are
>> >> in
>> > Eclipses
>> >> using
>> >> profiles'
>> >> article.
>> >> Antti
Re: Modifying existing profile [message #473307 is a reply to message #473305] |
Tue, 26 June 2007 09:59   |
Hi Antti,
That save I mentioned in the "how to save a model with applied steroeotypes
...." was to save stereotype applications while saving the model to which
stereotypes were applied. That code is not required to simply save a
profile.
There should be nothing special to do when saving the modified profile.
You should be able to open the profile as you would any other model, add
stereotypes to it, then save the resource back out.
Are you able to programatically load a basic model with one package, add a
class then close and save? If you can do that you should be able to do the
same for the stereotype and profile.
There might be something else in your code causing the removal of the
steroetypes. Are you getting errors or exceptions?
- James.
news:f5qtp0$ood$1@build.eclipse.org...
sample
same
it
mentioned
> Main-class:
> open();
> store();
> try {
> true);
> System.exit(1);
> return profile_;
uri)
> true,
> try {
> Antti
> > Hi Antti,
at
applied
> > that
> > Cheers,
> > - James.
were
in
> > a
up
proper,
> > but
> >> Antti
> >> save(profile, Uri);
> >> uri)
> >> try {
> >> > Hi Antti,
> >> > should
> >> > be
> >> > call
> >> > the
your
might
> >> > want
is
> >> > kept
> >> > reapply
functions
> >> > they
> > on.
> >> > Regards,
> >> > - James.
I
> > am
> > occurs
> >> > diagram,
UML
stereotypes
> > are
> >> >> in
> >> > Eclipses
> >> >> using
> >> >> profiles'
> >> >> article.
> >> >> Antti
Re: Modifying existing profile [message #473312 is a reply to message #473307] |
Tue, 26 June 2007 12:51   |
.... If you are not removing the stereotypes explicitly, could it be that you
are adding them to some other container? That might cause EMF to remove
them from the initial container.
- James.
news:f5r63k$d13$2@build.eclipse.org...
> Hi Antti,
steroeotypes
> profile.
the
> - James.
my
> sample
> same
saves
> it
from
> mentioned
> > Main-class:
> > open();
> > store();
> > try {
> > true);
> > System.exit(1);
> > return profile_;
> uri)
> > true,
> > try {
> > Antti
> > > Hi Antti,
> at
> applied
If
> > > that
> > > Cheers,
> > > - James.
> were
profile
> in
> > > a
come
> up
> proper,
> > > but
> > >> Antti
> > >> save(profile, Uri);
> > >> uri)
> > >> try {
> > >> > Hi Antti,
> > >> > should
> > >> > be
> > >> > call
> > >> > the
> your
> might
> > >> > want
> is
> > >> > kept
to
> > >> > reapply
> functions
> > >> > they
and
going
> > > on.
> > >> > Regards,
> > >> > - James.
way.
> I
> > > am
> > > occurs
> > >> > diagram,
> UML
> stereotypes
> > > are
profile
> > >> >> in
using
> > >> > Eclipses
profile
> > >> >> using
> > >> >> profiles'
> > >> >> article.
> > >> >> Antti
Re: Modifying existing profile [message #473323 is a reply to message #473307] |
Wed, 27 June 2007 09:02   |
Hi James,
I tried to modify simple UML model with one package and everything goes
fine. I used methods introduced in the 'Getting started with UML2' article.
First I executed registerResourceFactories() and registerPathmaps(uri)
methods, then I loaded the model and added the class to the package found
from the model. I got package by using the getNestedPackage and add class by
using the createOwnedClass method. After all I saved the model by using the
same method that I have used all the time.
So, all of these goes fine, but when I use profile something odd hapens. Of
course I am able to add stereotype to the profile and then view the modified
profile by using Eclipse's editor, but models that tries to use that
modified profile are broken after modification.
Before modification model that uses profile looks somethin like this.
<Model> OwnComponentModel
<<req1>> <Component> Component A
+<Profile Application> ProfileName
and after modification stereotype from the component A is lost and model
looks like this. I emphasize that this happens only when I modify the
profile in a programmatic way.
<Model>OwnComponentModel
Req1
base_component='Nonsense String'
Antti
> Hi Antti,
> steroeotypes
> profile.
> the
> - James.
> sample
> same
> it
>> from
> mentioned
>> Main-class:
>> open();
>> store();
>> try {
>> true);
>> System.exit(1);
>> return profile_;
> uri)
>> true,
>> try {
>> Antti
>> > Hi Antti,
> at
> applied
>> > that
>> > Cheers,
>> > - James.
> were
> in
>> > a
> up
> proper,
>> > but
>> >> Antti
>> >> save(profile, Uri);
>> >> uri)
>> >> try {
>> >> > Hi Antti,
>> >> > should
>> >> > be
>> >> > call
>> >> > the
> your
> might
>> >> > want
> is
>> >> > kept
>> >> > reapply
> functions
>> >> > they
>> >> > going
>> > on.
>> >> > Regards,
>> >> > - James.
>> >> >> way.
> I
>> > am
>> > occurs
>> >> > diagram,
> UML
> stereotypes
>> > are
>> >> >> profile
>> >> >> in
>> >> > Eclipses
>> >> >> profile
>> >> >> using
>> >> >> profiles'
>> >> >> article.
>> >> >> Antti
Re: Modifying existing profile [message #473445 is a reply to message #473323] |
Thu, 28 June 2007 05:13   |
Hi James,
I just mentioned that when I add a class to the model in a programmatic way
the result file is different than if I add class by using the editor. So
(hopefully) I made mistake also when I add a class :-) When I use the editor
to adding a class earlier defined classes keep original xmi-ids but when I
made this in the programmatic way all xmi-ids are changed.
Therefore, my question is how this class addition should be done? Again I
suppose that createOwnedClass is the right method, but can I save the model
by usign the same method which was applicable when creating a new model
file?
Antti
news:f5tn5h$env$1@build.eclipse.org...
> Hi James,
> article. First I executed registerResourceFactories() and
> registerPathmaps(uri) methods, then I loaded the model and added the class
> to the package found from the model. I got package by using the
> getNestedPackage and add class by using the createOwnedClass method. After
> all I saved the model by using the same method that I have used all the
> time.
> Of course I am able to add stereotype to the profile and then view the
> modified profile by using Eclipse's editor, but models that tries to use
> that modified profile are broken after modification.
> Req1
> Antti
>> Hi Antti,
>> steroeotypes
>> profile.
>> a
>> the
>> - James.
>>> my
>> sample
>> same
>>> saves
>> it
>>> from
>> mentioned
>>> Main-class:
>>> open();
>>> store();
>>> try {
>>> true);
>>> System.exit(1);
>>> return profile_;
>> uri)
>>> true,
>>> try {
>>> Antti
>>> > Hi Antti,
>> at
>> applied
>>> > If
>>> > that
>>> > Cheers,
>>> > - James.
>> were
>>> >> profile
>> in
>>> > a
>>> >> come
>> up
>> proper,
>>> > but
>>> >> Antti
>>> >> save(profile, Uri);
>>> >> uri)
>>> >> try {
>>> >> > Hi Antti,
>>> >> > should
>>> >> > be
>>> >> > call
>>> >> > the
>> your
>> might
>>> >> > want
>> is
>>> >> > kept
>>> >> > to
>>> >> > reapply
>> functions
>>> >> > they
>>> >> > and
>>> >> > going
>>> > on.
>>> >> > Regards,
>>> >> > - James.
>>> >> >> way.
>> I
>>> > am
>>> > occurs
>>> >> > diagram,
>> UML
>> stereotypes
>>> > are
>>> >> >> profile
>>> >> >> in
>>> >> >> using
>>> >> > Eclipses
>>> >> >> profile
>>> >> >> using
>>> >> >> profiles'
>>> >> >> article.
>>> >> >> Antti
Re: Modifying existing profile [message #473766 is a reply to message #473445] |
Thu, 05 July 2007 10:18   |
Antii,
It looks like the method you are using to save your model creates a new
resource before saving. If you are loading an existing model, then you don't
need (and probably don't want) to create a new resource - that's probably
why the identifiers are being changed each time you save your model.
When you say that the stereotype applications are lost, do you mean that
they are not accessible in memory after loading your model or that they are
missing in the serialization once you save your model? Are you sure that the
references to the profile are being successfully resolved when loading your
model? What result to you get when you call getAppliedStereotypes() on the
component in your model?
Kenn
news:f5vu2u$a7$1@build.eclipse.org...
> Hi James,
> way the result file is different than if I add class by using the editor.
> So (hopefully) I made mistake also when I add a class :-) When I use the
> editor to adding a class earlier defined classes keep original xmi-ids but
> when I made this in the programmatic way all xmi-ids are changed.
> model by usign the same method which was applicable when creating a new
> model file?
> Regards,
> Antti
>> Hi James,
>> class to the package found from the model. I got package by using the
>> After all I saved the model by using the same method that I have used all
>> the time.
>> Req1
>> Antti
>>> Hi Antti,
>>> steroeotypes
>>> profile.
>>> a
>>> the
>>> - James.
>>>> my
>>>> model
>>> sample
>>> same
>>>> saves
>>> it
>>>> from
>>> mentioned
>>>> Main-class:
>>>> open();
>>>> store();
>>>> ResourceSetImpl();
>>>> try {
>>>> true);
>>>> System.exit(1);
>>>> return profile_;
>>> uri)
>>>> true,
>>>> try {
>>>> Antti
>>>> > Hi Antti,
>>>> > look
>>> at
>>> applied
>>>> > If
>>>> > that
>>>> > Cheers,
>>>> > - James.
>>> were
>>>> >> profile
>>> in
>>>> > a
>>>> >> come
>>> up
>>> proper,
>>>> > but
>>>> >> Antti
>>>> >> save(profile, Uri);
>>>> >> URI
>>>> >> uri)
>>>> >> try {
>>>> >> > Hi Antti,
>>>> >> > should
>>>> >> > be
>>>> >> > simply
>>>> >> > call
>>>> >> > the
>>> your
>>> might
>>>> >> > want
>>>> >> > it
>>> is
>>>> >> > kept
>>>> >> > to
>>>> >> > reapply
>>> functions
>>>> >> > they
>>>> >> > and
>>>> >> > going
>>>> > on.
>>>> >> > Regards,
>>>> >> > - James.
>>>> >> >> way.
>>> I
>>>> > am
>>>> >> >> problem
>>>> > occurs
>>>> >> >> UML
>>>> >> > diagram,
>>>> >> >> the
>>> UML
>>> stereotypes
>>>> > are
>>>> >> >> profile
>>>> >> >> in
>>>> >> >> using
>>>> >> > Eclipses
>>>> >> >> profile
>>>> >> >> using
>>>> >> >> profiles'
>>>> >> >> article.
>>>> >> >> Antti
Re: Modifying existing profile [message #473940 is a reply to message #473766] |
Tue, 10 July 2007 08:55  |
Hi Kenn,
I think that creating resource was the problem. Below is the save method
that I used earlier and the new update method that works fine. So earlier I
get resource as follows:
But now, I get it as follows:
Resource resource = RESOURCE_SET.getResource(uri, true)
I suppose this is a legal way to implement this task. Thank you very much
for your hints.
Antti
try {
protected static void update(org.eclipse.uml2.uml.Package p, URI uri) {
Resource resource = RESOURCE_SET.getResource(uri, true);
resource.getContents().add(p);
try {
System.out.println("Update");
resource.save(OPTION_SAVE_ONLY_IF_CHANGED);
} catch(IOException ioe) {
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f6iuj1$3sd$1@build.eclipse.org...
> Antii,
> don't need (and probably don't want) to create a new resource - that's
> probably why the identifiers are being changed each time you save your
> model.
> are missing in the serialization once you save your model? Are you sure
> that the references to the profile are being successfully resolved when
> loading your model? What result to you get when you call
> getAppliedStereotypes() on the component in your model?
> Kenn
>> Hi James,
>> but when I made this in the programmatic way all xmi-ids are changed.
>> model file?
>> Regards,
>> Antti
>>> Hi James,
>>> all the time.
>>> Req1
>>> Antti
>>>> Hi Antti,
>>>> steroeotypes
>>>> which
>>>> profile.
>>>> add
>>>> add a
>>>> do the
>>>> - James.
>>>>> my
>>>>> model
>>>> sample
>>>> same
>>>>> saves
>>>> it
>>>>> from
>>>> mentioned
>>>>> normal?
>>>>> Main-class:
>>>>> open();
>>>>> store();
>>>>> ResourceSetImpl();
>>>>> try {
>>>>> Resource resource =
>>>>> true);
>>>>> System.exit(1);
>>>>> return profile_;
>>>> uri)
>>>>> true,
>>>>> try {
>>>>> Antti
>>>>> > Hi Antti,
>>>>> > look
>>>> at
>>>> applied
>>>>> > If
>>>>> > that
>>>>> > Cheers,
>>>>> > - James.
>>>>> >> methods
>>>> were
>>>>> >> profile
>>>> in
>>>>> > a
>>>>> >> come
>>>> up
>>>> proper,
>>>>> > but
>>>>> >> Antti
>>>>> >> save(profile, Uri);
>>>>> >> URI
>>>>> >> uri)
>>>>> >> try {
>>>>> >> > Hi Antti,
>>>>> >> > should
>>>>> >> > be
>>>>> >> > simply
>>>>> >> > call
>>>>> >> > the
>>>> your
>>>> might
>>>>> >> > want
>>>>> >> > ( it
>>>> is
>>>>> >> > kept
>>>>> >> > to
>>>>> >> > reapply
>>>> functions
>>>>> >> > they
>>>>> >> > and
>>>>> >> > going
>>>>> > on.
>>>>> >> > Regards,
>>>>> >> > - James.
>>>>> >> >> way.
>>>> I
>>>>> > am
>>>>> >> >> problem
>>>>> > occurs
>>>>> >> >> UML
>>>>> >> > diagram,
>>>>> >> >> the
>>>> UML
>>>> stereotypes
>>>>> > are
>>>>> >> >> profile
>>>>> >> >> in
>>>>> >> >> using
>>>>> >> > Eclipses
>>>>> >> >> profile
>>>>> >> >> using
>>>>> >> >> profiles'
>>>>> >> >> article.
>>>>> >> >> Antti
Re: Modifying existing profile [message #621866 is a reply to message #473218] |
Hi Antti,
- James.
diagram,
Eclipses
> article.
> Antti
Re: Modifying existing profile [message #622554 is a reply to message #473225] |
Antti
save(profile, Uri);
try {
> Hi Antti,
> be
> the
> want
> kept
> reapply
> they
> Regards,
> - James.
> diagram,
> Eclipses
>> using
>> profiles'
>> article.
>> Antti
Re: Modifying existing profile [message #622558 is a reply to message #473279] |
Hi Antti,
- James.
a
but
> Antti
> save(profile, Uri);
> try {
> > Hi Antti,
> > be
> > the
> > want
> > kept
> > reapply
> > they
on.
> > Regards,
> > - James.
am
occurs
> > diagram,
are
> > Eclipses
> >> using
> >> profiles'
> >> article.
> >> Antti
Re: Modifying existing profile [message #622570 is a reply to message #473283] |
Main-class:
open();
store();
try {
true);
System.exit(1);
return profile_;
true,
try {
Antti
> Hi Antti,
> that
> Cheers,
> - James.
> a
> but
>> Antti
>> save(profile, Uri);
>> uri)
>> try {
>> > Hi Antti,
>> > should
>> > be
>> > call
>> > the
>> > want
>> > kept
>> > reapply
>> > they
> on.
>> > Regards,
>> > - James.
> am
> occurs
>> > diagram,
> are
>> >> in
>> > Eclipses
>> >> using
>> >> profiles'
>> >> article.
>> >> Antti
Re: Modifying existing profile [message #622572 is a reply to message #473305] |
Hi Antti,
profile.
- James.
sample
same
it
mentioned
> Main-class:
> open();
> store();
> try {
> true);
> System.exit(1);
> return profile_;
uri)
> true,
> try {
> Antti
> > Hi Antti,
at
applied
> > that
> > Cheers,
> > - James.
were
in
> > a
up
proper,
> > but
> >> Antti
> >> save(profile, Uri);
> >> uri)
> >> try {
> >> > Hi Antti,
> >> > should
> >> > be
> >> > call
> >> > the
your
might
> >> > want
is
> >> > kept
> >> > reapply
functions
> >> > they
> > on.
> >> > Regards,
> >> > - James.
I
> > am
> > occurs
> >> > diagram,
UML
stereotypes
> > are
> >> >> in
> >> > Eclipses
> >> >> using
> >> >> profiles'
> >> >> article.
> >> >> Antti
Re: Modifying existing profile [message #622576 is a reply to message #473307] |
- James.
> Hi Antti,
steroeotypes
> profile.
the
> - James.
my
> sample
> same
saves
> it
from
> mentioned
> > Main-class:
> > open();
> > store();
> > try {
> > true);
> > System.exit(1);
> > return profile_;
> uri)
> > true,
> > try {
> > Antti
> > > Hi Antti,
> at
> applied
If
> > > that
> > > Cheers,
> > > - James.
> were
profile
> in
> > > a
come
> up
> proper,
> > > but
> > >> Antti
> > >> save(profile, Uri);
> > >> uri)
> > >> try {
> > >> > Hi Antti,
> > >> > should
> > >> > be
> > >> > call
> > >> > the
> your
> might
> > >> > want
> is
> > >> > kept
to
> > >> > reapply
> functions
> > >> > they
and
going
> > > on.
> > >> > Regards,
> > >> > - James.
way.
> I
> > > am
> > > occurs
> > >> > diagram,
> UML
> stereotypes
> > > are
profile
> > >> >> in
using
> > >> > Eclipses
profile
> > >> >> using
> > >> >> profiles'
> > >> >> article.
> > >> >> Antti
Re: Modifying existing profile [message #622584 is a reply to message #473307] |
Hi James,
Req1
Antti
> Hi Antti,
> steroeotypes
> profile.
> the
> - James.
> sample
> same
> it
>> from
> mentioned
>> Main-class:
>> open();
>> store();
>> try {
>> true);
>> System.exit(1);
>> return profile_;
> uri)
>> true,
>> try {
>> Antti
>> > Hi Antti,
> at
> applied
>> > that
>> > Cheers,
>> > - James.
> were
> in
>> > a
> up
> proper,
>> > but
>> >> Antti
>> >> save(profile, Uri);
>> >> uri)
>> >> try {
>> >> > Hi Antti,
>> >> > should
>> >> > be
>> >> > call
>> >> > the
> your
> might
>> >> > want
> is
>> >> > kept
>> >> > reapply
> functions
>> >> > they
>> >> > going
>> > on.
>> >> > Regards,
>> >> > - James.
>> >> >> way.
> I
>> > am
>> > occurs
>> >> > diagram,
> UML
> stereotypes
>> > are
>> >> >> profile
>> >> >> in
>> >> > Eclipses
>> >> >> profile
>> >> >> using
>> >> >> profiles'
>> >> >> article.
>> >> >> Antti
Re: Modifying existing profile [message #622658 is a reply to message #473323] |
Hi James,
file?
Antti
> Hi James,
> time.
> Req1
> Antti
>> Hi Antti,
>> steroeotypes
>> profile.
>> a
>> the
>> - James.
>>> my
>> sample
>> same
>>> saves
>> it
>>> from
>> mentioned
>>> Main-class:
>>> open();
>>> store();
>>> try {
>>> true);
>>> System.exit(1);
>>> return profile_;
>> uri)
>>> true,
>>> try {
>>> Antti
>>> > Hi Antti,
>> at
>> applied
>>> > If
>>> > that
>>> > Cheers,
>>> > - James.
>> were
>>> >> profile
>> in
>>> > a
>>> >> come
>> up
>> proper,
>>> > but
>>> >> Antti
>>> >> save(profile, Uri);
>>> >> uri)
>>> >> try {
>>> >> > Hi Antti,
>>> >> > should
>>> >> > be
>>> >> > call
>>> >> > the
>> your
>> might
>>> >> > want
>> is
>>> >> > kept
>>> >> > to
>>> >> > reapply
>> functions
>>> >> > they
>>> >> > and
>>> >> > going
>>> > on.
>>> >> > Regards,
>>> >> > - James.
>>> >> >> way.
>> I
>>> > am
>>> > occurs
>>> >> > diagram,
>> UML
>> stereotypes
>>> > are
>>> >> >> profile
>>> >> >> in
>>> >> >> using
>>> >> > Eclipses
>>> >> >> profile
>>> >> >> using
>>> >> >> profiles'
>>> >> >> article.
>>> >> >> Antti
Re: Modifying existing profile [message #622825 is a reply to message #473445] |
Antii,
Kenn
> Hi James,
> model file?
> Regards,
> Antti
>> Hi James,
>> the time.
>> Req1
>> Antti
>>> Hi Antti,
>>> steroeotypes
>>> profile.
>>> a
>>> the
>>> - James.
>>>> my
>>>> model
>>> sample
>>> same
>>>> saves
>>> it
>>>> from
>>> mentioned
>>>> Main-class:
>>>> open();
>>>> store();
>>>> ResourceSetImpl();
>>>> try {
>>>> true);
>>>> System.exit(1);
>>>> return profile_;
>>> uri)
>>>> true,
>>>> try {
>>>> Antti
>>>> > Hi Antti,
>>>> > look
>>> at
>>> applied
>>>> > If
>>>> > that
>>>> > Cheers,
>>>> > - James.
>>> were
>>>> >> profile
>>> in
>>>> > a
>>>> >> come
>>> up
>>> proper,
>>>> > but
>>>> >> Antti
>>>> >> save(profile, Uri);
>>>> >> URI
>>>> >> uri)
>>>> >> try {
>>>> >> > Hi Antti,
>>>> >> > should
>>>> >> > be
>>>> >> > simply
>>>> >> > call
>>>> >> > the
>>> your
>>> might
>>>> >> > want
>>>> >> > it
>>> is
>>>> >> > kept
>>>> >> > to
>>>> >> > reapply
>>> functions
>>>> >> > they
>>>> >> > and
>>>> >> > going
>>>> > on.
>>>> >> > Regards,
>>>> >> > - James.
>>>> >> >> way.
>>> I
>>>> > am
>>>> >> >> problem
>>>> > occurs
>>>> >> >> UML
>>>> >> > diagram,
>>>> >> >> the
>>> UML
>>> stereotypes
>>>> > are
>>>> >> >> profile
>>>> >> >> in
>>>> >> >> using
>>>> >> > Eclipses
>>>> >> >> profile
>>>> >> >> using
>>>> >> >> profiles'
>>>> >> >> article.
>>>> >> >> Antti
Re: Modifying existing profile [message #623316 is a reply to message #473766] |
Hi Kenn,
for your hints.
Antti
try {
try {
> Antii,
> model.
> Kenn
>> Hi James,
>> model file?
>> Regards,
>> Antti
>>> Hi James,
>>> all the time.
>>> Req1
>>> Antti
>>>> Hi Antti,
>>>> steroeotypes
>>>> which
>>>> profile.
>>>> add
>>>> add a
>>>> do the
>>>> - James.
>>>>> my
>>>>> model
>>>> sample
>>>> same
>>>>> saves
>>>> it
>>>>> from
>>>> mentioned
>>>>> normal?
>>>>> Main-class:
>>>>> open();
>>>>> store();
>>>>> ResourceSetImpl();
>>>>> try {
>>>>> Resource resource =
>>>>> true);
>>>>> System.exit(1);
>>>>> return profile_;
>>>> uri)
>>>>> true,
>>>>> try {
>>>>> Antti
>>>>> > Hi Antti,
>>>>> > look
>>>> at
>>>> applied
>>>>> > If
>>>>> > that
>>>>> > Cheers,
>>>>> > - James.
>>>>> >> methods
>>>> were
>>>>> >> profile
>>>> in
>>>>> > a
>>>>> >> come
>>>> up
>>>> proper,
>>>>> > but
>>>>> >> Antti
>>>>> >> save(profile, Uri);
>>>>> >> URI
>>>>> >> uri)
>>>>> >> try {
>>>>> >> > Hi Antti,
>>>>> >> > should
>>>>> >> > be
>>>>> >> > simply
>>>>> >> > call
>>>>> >> > the
>>>> your
>>>> might
>>>>> >> > want
>>>>> >> > ( it
>>>> is
>>>>> >> > kept
>>>>> >> > to
>>>>> >> > reapply
>>>> functions
>>>>> >> > they
>>>>> >> > and
>>>>> >> > going
>>>>> > on.
>>>>> >> > Regards,
>>>>> >> > - James.
>>>>> >> >> way.
>>>> I
>>>>> > am
>>>>> >> >> problem
>>>>> > occurs
>>>>> >> >> UML
>>>>> >> > diagram,
>>>>> >> >> the
>>>> UML
>>>> stereotypes
>>>>> > are
>>>>> >> >> profile
>>>>> >> >> in
>>>>> >> >> using
>>>>> >> > Eclipses
>>>>> >> >> profile
>>>>> >> >> using
>>>>> >> >> profiles'
>>>>> >> >> article.
>>>>> >> >> Antti
Current Time: Sat Oct 04 19:57:15 EDT 2025
Powered by FUDForum. Page generated in 0.07511 seconds
