Home » Modeling » UML2 Tools » Associations: Are they good for anything?
Associations: Are they good for anything? [message #473256] Wed, 30 January 2008 15:22 Go to next message
Originally posted by: m_lehmeier.gmx.de
Situation:
I read the "Using EMF" Tutorial at
http://www.eclipse.org/articles/Article-Using%20EMF/using-em f.html
It showed an UML diagram that is used to build the example metamodel.
It was done in Rational Rose, but I thought there are the uml2tools,
they should also be able to do that.
So I created a diagram and basically copied that diagram.
I didn't find out how to put the arrows on the associations, but I guess
that is not so important.
Note:
That important stuff like multiplicities have to be manually edited in
the properties and are even distributed into no less than four property
fields is very nasty and time-consuming. I hope this will be changed
soon.
Anyway, I then generated an EMF model out of the result which went fine.
The resulting model however, showed no associations. No reference
fields.
I wonder: Isn't model generation the main task of the uml2tools? If yes,
then it seems that associations only serve for decoration in the
diagram.
I hope not.
I wonder this especially because in the tutorial
http://www.vogella.de/articles/UML/article.html
the chapter for the explanation of associations makes up a pretty big
part.
But it never explains what purpose they serve in modeling with
uml2tools.
Or how to edit the multiplcities for that matter.
My suggestion to whoever made the tutorial is to add one example how all
the editing reflects in a concrete result, meaning either a generated
model, generated java code or whatever.
Lehmeier Michael (Nightshade Dragon UDIC)
8:00 - 12:00 : Frohlocken!
12:00 - 20:00 : Hosianna singen!
Re: Associations: Are they good for anything? [message #473259 is a reply to message #473256] Thu, 31 January 2008 09:49 Go to previous messageGo to next message
Hi Michael,
First you should understand that UML2Tools generates UML2 Models. You
can export these models to Ecore just like you describe below (I suppose
you used the UMl2Ecore model exporter?). To directly create Ecore
model(s) (diagrams) you could use the EMFT Diagram editor, or the
praised Topcase editor. (Maybe these are actually the same now?)
Did you consider reading an introductory UML Book? They recommended UML
Glasklar to me (in German). This should definitely explain how
associations work.
> soon.
I maybe agree. One could have one property field to enter upper and
lower multiplicity at a Time, like 0..* or so. The current
implementation just generically has a property field for every property
of the selected UML element. All commercial tools that I´ve seen so far
also use the 4 property fields approach too...
> fields.
How did you actually look at this model? The EMF Tree Editor? Maybe you
could post your original UML2 Model? This is actually not really an
UML2Tools Issue, but more an UML2 or Ecore question, you might consider
posting a seperate question on the UML2 or Ecore Group.
> diagram.
> I hope not.
No need to pray here... UML2 Tools merely creates UML2 Models by using
the notation we all know (or don´t no so well, it has a lot of
pitfalls...). It does so by relying on the UML2 Project which basically
provides an API to create UML2 models (look at the .uml2 file with a
Text Editor, this is equivalent to your diagram)
After you created your UML2 model, it´s up to you what you want do with
it. E.g. UML2 does not provide a code generation framework. Therefore
they created the UML2 to Ecore exporter, since Ecore generates first
class vanilla strawberry tastin´ code from your models. However some
things are not supported by that exporter - due to the fact that UML is
somehow more powerful (also much more complex) than Ecore.
> uml2tools.
You cannot just read Vogellas Tutorial and understand UML from his
Examples. You definitely should read a book on the issue. I also
recommend to look at Ecore directly, they are releasing a very promising
new Book in a few years :-p (maybe a few weeks...)
Felix
Re: Associations: Are they good for anything? [message #473262 is a reply to message #473259] Thu, 31 January 2008 20:28 Go to previous messageGo to next message
On 2008-01-31, Felix Dorner <felix_do@web.de> wrote:
> Hi Michael,
File->New->EMF-Model
Then select "UML Model" when asked from what it should be created.
I didn't know there was a graphical tool for EMF modeling.
Good to know.
But I didn't need it yet anyway.
> associations work.
Indeed I have a book here (The one from Booch, Rumbeaugh, Jacobson) and
have read it.
Oh, you mean the arrows not important? Of course they are important,
just not in the case that I was using them for here. I should have made
that more clear.
Anyway, I still haven't found out how to make an association navigable
(in one direction) in uml2tools.
>> soon.
I think the problem is that uml2tools share the same properties editor
with all other Eclipse plugins. It is not very optimized for UML
editing. Tools like ArgoUML are so much easier there.
Yes, I see that now.
I will probably ask there when I have the time.
>> diagram.
>> I hope not.
I just thought that associations are the logical UML representation of
Ecore references. How else could I model references with the UML tool?
I understand that not every feature of UML maps to something in Ecore,
but considering how powerful UML is, there should be *some* way to model
Ecore references with UML.
BTW, the example model from that tutorial was created with Rational
Rose. There was the Rational Rose Model of that diagram as a file, which
I could use for import to Ecore, with references and everything.
Since I don't have Rational Rose, I can't test if there was more to the
file than what I saw in the diagram, but because of that example I just
assumed that the UML generated from UML2Tools should also be able to map
associations to ecore references.
Apparently not.
>> uml2tools.
Of course, but the tutorial spends quite some time explaining
associations like talking to an absolute beginner.
But an absolute beginner usually also requires an example what to
actually do with it, or he will look for something else..
I mean, if I want to "sell" Uml2Tools to a beginner, if asking "what
do I get from an UML diagram?" you shouldn't answer "an UML2 model", because
immediate next question would be "and what do I do with an UML2 model?".
And someone who already knows what to do with the UML2 model surely
needn't be told what the difference between a aggregation and a
composition is, because he already knows that.
I just think that the tutorial really needs an example for a practical
application of the results.
Much more than an introduction to UML, that makes up about a third of
the whole tutorial!
> I also
Where's the fun in that?
Until now I modeled ecore in plain-text KM3. I thought UML should also
do it since it can be importet to Ecore. I failed, so I am back to KM3.
I don't need Uml2Tools, I just hoped it would help me.
I will have a look at EMFT though.
Re: Associations: Are they good for anything? [message #473265 is a reply to message #473262] Fri, 01 February 2008 05:28 Go to previous messageGo to next message
Hi Michael,
> Good to know.
I don't understand you. You created an UML model to then export it to
EMF. Why not directly edit Ecore models with the EMFT Editor and fall
into traps like the UML2Ecore mapping. This doesn't mean that you cannot
rely on this mapping, it worked fine in my simple test cases. For your
case, it would really be good to get a look at your UML source model, to
check why the eReferences are not created. (Maybe association ends were
owned by the association?)
In the tool-panel, click on the small black triangle. This opens sort of
combobox with an element "Navigable Association". Select this and draw
your associacion from the src to the target class.
That's a statement. I considered ArgoUML crap after 3 minutes :-p I am
curious: How do you enter multiplicities with that tool?
> Ecore references.
Hmm. UML associations are UML associations. These are similar to Ecore
references i.e. represent similar concepts, but they are not the same,
since you use a different (yet similar) language...
> I just
It definitely is.
> the whole tutorial!
People are always invited to contribute.
>> I also
The Fun in that is that you have no pain from modeling in a different
language and hope that the mapping works as you intend to. From your
statments it looks like you already "Think Ecore" when you are acutally
model UML... I don't think that's what the mapping was designed for.
Felix
Re: Associations: Are they good for anything? [message #473271 is a reply to message #473265] Fri, 01 February 2008 07:47 Go to previous messageGo to next message
--------------030204080509090902050807
Felix,
Comments below.
Felix Dorner wrote:
> Hi Michael,
>> Good to know.
> cannot rely on this mapping, it worked fine in my simple test cases.
> For your case, it would really be good to get a look at your UML
> source model, to check why the eReferences are not created. (Maybe
> association ends were owned by the association?)
Yes, I didn't quite understand not wanting to edit Ecore graphically
directly either and I had the same though about owned association ends.
This recent blog seems relevant to the topic of what happens with
associations that own their ends:
http://ed-merks.blogspot.com/2008/01/modeling-associations-w ith-ecore.html
> of combobox with an element "Navigable Association". Select this and
> draw your associacion from the src to the target class.
Why don't you say how you really feel? :-P
>> Ecore references.
>> I just
> It definitely is.
>> the whole tutorial!
>>> I also
> acutally model UML... I don't think that's what the mapping was
> designed for.
> Felix
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Felix,<br>
<br>
Comments below.<br>
<br>
<br>
Felix Dorner wrote:
<blockquote cite="mid:fnus8m$cu7$1@build.eclipse.org" type="cite">Hi
Michael,
<br>
<br>
<br>
<blockquote type="cite">I didn't know there was a graphical tool for
EMF modeling.
<br>
Good to know.
<br>
<br>
</blockquote>
<br>
For your case, it would really be good to get a look at your UML source
model, to check why the eReferences are not created. (Maybe association
<br>
</blockquote>
ends.&nbsp; This recent blog seems relevant to the topic of what happens
with associations that own their ends:<br>
<blockquote><a
href=" http://ed-merks.blogspot.com/2008/01/modeling-associations-w ith-ecore.html"> http://ed-merks.blogspot.com/2008/01/modeling-associations-w ith-ecore.html</a><br>
</blockquote>
<blockquote cite="mid:fnus8m$cu7$1@build.eclipse.org" type="cite"><br>
<blockquote type="cite">Anyway, I still haven't found out how to make
<br>
<br>
</blockquote>
<br>
<br>
<blockquote type="cite">&nbsp;Tools like ArgoUML are so much easier there.
<br>
</blockquote>
<br>
</blockquote>
Why don't you say how you really feel?&nbsp; :-P<br>
<blockquote type="cite">I just thought that associations are the
<br>
Ecore references. </blockquote>
<br>
<br>
<br>
map
<br>
<br>
</blockquote>
It definitely is.
<br>
<br>
<blockquote type="cite">I just think that the tutorial really needs
<br>
<br>
<br>
the whole tutorial!
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite">I also
<br>
recommend to look at Ecore directly, </blockquote>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
Felix
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------030204080509090902050807--
Re: Associations: Are they good for anything? [message #473289 is a reply to message #473271] Fri, 01 February 2008 09:22 Go to previous message
Hey Ed,
I had read your article a week or so ago, It comes to the right time as
my thesis topic deals with object relationships and their support in OO
Pl's. I am still looking forward to post some comments at your site.
Felix
Re: Associations: Are they good for anything? [message #617598 is a reply to message #473256] Thu, 31 January 2008 09:49 Go to previous message
Hi Michael,
associations work.
> soon.
> fields.
> diagram.
> I hope not.
> uml2tools.
Felix
Re: Associations: Are they good for anything? [message #617604 is a reply to message #473259] Thu, 31 January 2008 20:28 Go to previous message
> Hi Michael,
Good to know.
> associations work.
have read it.
that more clear.
>> soon.
>> diagram.
>> I hope not.
Apparently not.
>> uml2tools.
the whole tutorial!
> I also
Re: Associations: Are they good for anything? [message #618249 is a reply to message #473262] Fri, 01 February 2008 05:28 Go to previous message
Hi Michael,
> Good to know.
> Ecore references.
> I just
It definitely is.
> the whole tutorial!
>> I also
Felix
Re: Associations: Are they good for anything? [message #618255 is a reply to message #473265] Fri, 01 February 2008 07:47 Go to previous message
Felix,
Comments below.
Felix Dorner wrote:
> Hi Michael,
>> Good to know.
>> Ecore references.
>> I just
> It definitely is.
>> the whole tutorial!
>>> I also
> designed for.
> Felix
<html>
<head>
</head>
Felix,<br>
<br>
Comments below.<br>
<br>
<br>
Michael,
<br>
<br>
<br>
EMF modeling.
<br>
Good to know.
<br>
<br>
</blockquote>
<br>
<br>
</blockquote>
<blockquote><a
</blockquote>
<br>
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
<br>
<br>
<br>
map
<br>
<br>
</blockquote>
It definitely is.
<br>
<br>
<br>
<br>
<br>
the whole tutorial!
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
Felix
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: Associations: Are they good for anything? [message #618257 is a reply to message #473271] Fri, 01 February 2008 09:22 Go to previous message
Hey Ed,
Felix
Previous Topic:Which UML2 "Diagram Element" should be selected for GMF
Next Topic:Extending UML model properties
Current Time: Sat Jul 26 19:13:23 EDT 2025
Powered by FUDForum. Page generated in 0.04975 seconds
