Home » Modeling » UML2 » Exporting UML diagram and profile
Exporting UML diagram and profile [message #472898] Mon, 14 May 2007 05:42 Go to next message
Originally posted by: antti.evesti.vtt.fi
I have a problem with ‘exporting’ UML model with the profile, i.e.
component diagram and applied profile. I have made component diagram which
contains stereotypes from UML profile, this is just I wish. However, when
I save the model and try open it from another project the problem appears.
The saved component diagram does not find the needed UML profile. So how I
must apply UML profile to the diagram, so that I can open diagram in
another project? Of course, I have moved both files to another project,
i.e. the component diagram and UML profile file.
Footnote, I am not trying make this by code, just using UML2 editor of
Eclipse.
BR,
Antti
Re: Exporting UML diagram and profile [message #472900 is a reply to message #472898] Mon, 14 May 2007 08:44 Go to previous messageGo to next message
Antti,
The profile must exist in the same location (relative to the model) in order
to successfully open it from another project. The alternative is to use
"pathmaps" as a way of referencing profiles (and other shared resources) in
a location-neutral way. If you do a search on this and/or the legacy UML2
newsgroup (eclipse.tools.uml2) you'll be sure to find useful information on
how to use pathmaps...
Kenn
"Antti Evesti" <antti.evesti@vtt.fi> wrote in message
news:a548b799946cfcafbacae5be98a8cbc8$1@www.eclipse.org...
Re: Exporting UML diagram and profile [message #473100 is a reply to message #472900] Wed, 06 June 2007 08:58 Go to previous messageGo to next message
Ok. But is these pathmaps something that has to be used via a programmatic
approach, or can I utilize it via the UML editor of Eclipse? Because I tried
to find the right place from the UML editor but I cannot find anything
relating about 'pathmaps'
Antti
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:f29ljm$d0s$1@build.eclipse.org...
> Antti,
> order to successfully open it from another project. The alternative is to
> use "pathmaps" as a way of referencing profiles (and other shared
> resources) in a location-neutral way. If you do a search on this and/or
> the legacy UML2 newsgroup (eclipse.tools.uml2) you'll be sure to find
> useful information on how to use pathmaps...
> Kenn
>> Hi,
>> I have a problem with 'exporting' UML model with the profile, i.e.
>> which contains stereotypes from UML profile, this is just I wish.
>> However, when I save the model and try open it from another project the
>> problem appears. The saved component diagram does not find the needed UML
>> profile. So how I must apply UML profile to the diagram, so that I can
>> open diagram in another project? Of course, I have moved both files to
>> another project, i.e. the component diagram and UML profile file.
>> Eclipse.
>> BR,
>> Antti
Re: Exporting UML diagram and profile [message #473104 is a reply to message #473100] Wed, 06 June 2007 13:37 Go to previous messageGo to next message
Antti,
"Pathmaps" must be declared either programmatically or via the EMF extension
point; there is no UI available to manage them in UML2.
Kenn
"Antti" <antti.evesti@vtt.fi> wrote in message
news:f46b1k$esd$1@build.eclipse.org...
> tried to find the right place from the UML editor but I cannot find
> anything relating about 'pathmaps'
> Antti
>> Antti,
>> Kenn
>>> Hi,
>>> UML profile. So how I must apply UML profile to the diagram, so that I
>>> can open diagram in another project? Of course, I have moved both files
>>> to another project, i.e. the component diagram and UML profile file.
>>> Eclipse.
>>> BR,
>>> Antti
Re: Exporting UML diagram and profile [message #473123 is a reply to message #473104] Fri, 08 June 2007 01:42 Go to previous message
So, I have to make an own plug-in, which make it possible to add profiles to
UML models in a consistent way.
Antti
news:f46rck$8jn$1@build.eclipse.org...
> Antti,
> extension point; there is no UI available to manage them in UML2.
> Kenn
>> programmatic approach, or can I utilize it via the UML editor of Eclipse?
>> Because I tried to find the right place from the UML editor but I cannot
>> find anything relating about 'pathmaps'
>> Antti
>>> Antti,
>>> to use "pathmaps" as a way of referencing profiles (and other shared
>>> Kenn
>>>> Hi,
>>>> Eclipse.
>>>> BR,
>>>> Antti
Re: Exporting UML diagram and profile [message #615854 is a reply to message #472898] Mon, 14 May 2007 08:44 Go to previous message
Antti,
Kenn
Re: Exporting UML diagram and profile [message #619751 is a reply to message #472900] Wed, 06 June 2007 08:58 Go to previous message
Antti
> Antti,
> Kenn
>> Hi,
>> Eclipse.
>> BR,
>> Antti
Re: Exporting UML diagram and profile [message #619762 is a reply to message #473100] Wed, 06 June 2007 13:37 Go to previous message
Antti,
Kenn
> Antti
>> Antti,
>> Kenn
>>> Hi,
>>> Eclipse.
>>> BR,
>>> Antti
Re: Exporting UML diagram and profile [message #619910 is a reply to message #473104] Fri, 08 June 2007 01:42 Go to previous message
Antti
> Antti,
> Kenn
>> Antti
>>> Antti,
>>> Kenn
>>>> Hi,
>>>> Eclipse.
>>>> BR,
>>>> Antti
Previous Topic:class name
Next Topic:dynamic pathmap:// variable registration & opening, editing, creating models with pathmap URIs
Current Time: Sat Jul 26 18:58:49 EDT 2025
Powered by FUDForum. Page generated in 0.04843 seconds
