Installing UML2 Tools [message #472136] |
Tue, 18 December 2007 15:38  |
Hello my friends...
IŽm new in the project UML2 Tools, and IŽm trying to install it over my
windows.
IŽve seen the build dependecies list and there is a "Eclipse 3.4 for
linux" on it.
Is there a way to install UML2 Tools over windows?!
Sorry for the question, thatŽs because I tried to install UML2 Tools in my
windows with Eclipse 3.4 and didnŽt work.
Thanks everybody,
Raphael
Re: Installing UML2 Tools [message #472714 is a reply to message #472711] |
Fri, 25 January 2008 09:56   |
Bjorn,
Yes because EMF requires Java 5.0. It's quite useful to clear the error
log (either the view or remove <workspace>/.metadata/.log) run Eclipse
with -clean -debug, and look closely at the logged messages. If plugins
are disabled, it will explain what dependencies are missing, or if Java
5.0 is needed but isn't available, it will give messages about that.
Bjorn Regnstrom wrote:
> Tatiana Fesenko wrote:
>> Hello ayman,
>> Do you mean you succesfully installed all the required plugins and
>> after that you cannot find 'New/Other/UML 2.1 Diagrams' menu item? Do
>> you have anything in your Error Log? If yes, please send us its
>> content. Probably it will help us to solve the problem.
> Hello Tatiana,
> The above exactly describes my problem. The file .metadata/.log shows
> nothing, are there any other log files? Does uml2tools require Java5?
> Best regards,
> Bjorn
Re: Installing UML2 Tools [message #472717 is a reply to message #472711] |
Fri, 25 January 2008 09:57  |
Hi Bjorn,
Yes, it is. Look at http://www.eclipse.org/modeling/mdt/downloads/?project=uml2t ools:
Build Dependencies:
sun-java2-5.0
Best wishes,
Tatiana.
>> Hello ayman,
> Hello Tatiana,
> Best regards,
> Bjorn
Re: Installing UML2 Tools [message #611650 is a reply to message #472136] |
Tue, 18 December 2007 16:46  |
That build dependency for linux just reflects what was used in the automated
build environment. It should install and run fine under windows (with the
other platform independent features, e.g. EMF, UML2, etc).
See my previous post to Gary about using the update manager.
Dave
> I
Re: Installing UML2 Tools [message #614539 is a reply to message #472143] |
Mon, 31 December 2007 18:41  |
Originally posted by: ayman_java.yahoo.com
Iam trying to install UMLTools over windows with eclipse Version: 3.3.1.1.
I tried first to download all dependencies it doesn't work, I tried
install manager, it also didn't work. I can see the org.eclipse.uml2tools
in the feature details, seems nothing wrong. but I can't see New/Other/UML
2.1 Diagrams in the new project, any help?!!
Re: Installing UML2 Tools [message #614541 is a reply to message #472174] |
Wed, 02 January 2008 07:37  |
Hello ayman,
Do you mean you succesfully installed all the required plugins and after
Do you have anything in your Error Log? If yes, please send us its content.
Tatiana.
> 3.3.1.1. I tried first to download all dependencies it doesn't work,
> I tried install manager, it also didn't work. I can see the
> org.eclipse.uml2tools in the feature details, seems nothing wrong. but
> I can't see New/Other/UML 2.1 Diagrams in the new project, any help?!!
Re: Installing UML2 Tools [message #617567 is a reply to message #472176] |
Fri, 25 January 2008 08:18  |
> Hello ayman,
Hello Tatiana,
Bjorn
Re: Installing UML2 Tools [message #617571 is a reply to message #472711] |
Bjorn,
>> Hello ayman,
> Hello Tatiana,
> Best regards,
> Bjorn
Re: Installing UML2 Tools [message #617573 is a reply to message #472711] |
Hi Bjorn,
Build Dependencies:
sun-java2-5.0
Best wishes,
Tatiana.
>> Hello ayman,
> Hello Tatiana,
> Best regards,
> Bjorn
FUDForum. Page generated in 0.05975 seconds
