Home » Eclipse Projects » Platform - User Assistance (UA) » Infocenter web app: configuring logging in JBoss 4.2.1
Infocenter web app: configuring logging in JBoss 4.2.1 [message #472519] Tue, 08 April 2008 00:08 Go to next message
I've been using the Infocenter web application in JBoss 4.0.1 for some
time now. I am required to also make it work under JBoss 4.2.1.
Unfortunately JBoss 4.2.1 will not run the web application because of
some incompatibility between log4j in JBoss and commons-logging in the
WAR file.
I see this error when I try to open the infocenter.
org.apache.commons.logging.LogConfigurationException:
org.apache.commons.logging.LogConfigurationException: No suitable Log
constructor [Ljava.lang.Class;@1cfc277 for
org.apache.commons.logging.impl.Log4JLogger (Caused by
java.lang.NoClassDefFoundError: org/apache/log4j/Category) (Caused by
java.lang.NoClassDefFoundError: org/apache/log4j/Category))
Has anyone else run the infocenter web application under JBoss 4.2 or
higher? Did you see this problem and were you able to fix it?
One developer I consulted suggested configuring the web application to
use Java logging instead of log4j. I am trying to try that but have not
succeeded yet.
Thanks for your help.
Peter Desjardins
Re: Infocenter web app: configuring logging in JBoss 4.2.1 [message #475115 is a reply to message #472519] Thu, 12 February 2009 03:42 Go to previous message
did any one get the solution of this problem as i am also facing the same
problem and yet to find the solution..
Any help in this regard would be highly appreciated.
Thanks in advance
Re: Infocenter web app: configuring logging in JBoss 4.2.1 [message #623229 is a reply to message #472519] Thu, 12 February 2009 03:42 Go to previous message
Thanks in advance
Previous Topic:Using standalone help system and displayHelp() method not displaying new browser
Next Topic:mailto links don't work in help view under OS X
Current Time: Sat Jul 26 18:49:38 EDT 2025
Powered by FUDForum. Page generated in 0.03195 seconds
