Home » Eclipse Projects » JavaServer Faces » 'xxx' validator is not registered
'xxx' validator is not registered [message #472140] Mon, 03 July 2006 03:15 Go to next message
Originally posted by: blacksnow666.gmail.com
i have a validator, in my faces-config.xml
when i open the faces-config.xml using the FacesConfig Editor,
the validator is there, in the Components tab,
no errors.
but on my jsp page
i get warnings
saying that 'xxx' validator is not registered.
Re: 'xxx' validator is not registered [message #472147 is a reply to message #472140] Mon, 03 July 2006 07:58 Go to previous messageGo to next message
> no errors.
> but on my jsp page
> i get warnings
Sorry..
I found the problem. I was using multiple faces-config.xml, so, my guess
was that the validator looked for a file named "faces-config.xml,
faces-config-navigation.xml" and did not see my validator in
"faces-config.xml"
Re: 'xxx' validator is not registered [message #472152 is a reply to message #472147] Mon, 03 July 2006 12:55 Go to previous message
Titi,
The JSF tooling has a manager that should be able to locate all the faces
configuration files if they are correctly named and in the right
locations, or if they are correctly registered in the web.xml file using
the javax.faces.CONFIG_FILES CONTEXT_PARAM.
Please see: http://www.jsf-faq.com/faqs/faces-configuration.html
If you think that there is still a problem, please log a bugzilla issue
and attach your project.
Gerry Kessler
WTP JSF Tools Team
Re: 'xxx' validator is not registered [message #600789 is a reply to message #472140] Mon, 03 July 2006 07:58 Go to previous message
> no errors.
> but on my jsp page
> i get warnings
Sorry..
"faces-config.xml"
Re: 'xxx' validator is not registered [message #600804 is a reply to message #472147] Mon, 03 July 2006 12:55 Go to previous message
Titi,
Gerry Kessler
WTP JSF Tools Team
Previous Topic:Resource bundle cannot be resolved
Next Topic:Resource bundle cannot be resolved
Current Time: Fri Jul 25 23:31:07 EDT 2025
Powered by FUDForum. Page generated in 0.04783 seconds
