visual stuff [message #472066] |
Mon, 10 December 2007 16:17  |
Originally posted by: nickkirtley.gmail.com
hi,
Regarding component diagram, I need to add some visualization things.
Is it possible to change the colour of components and packages?
How can I add a line between two ports or two components? So purely
visualization.
How can I add some text to that line.
One other thing,
I did the following:
Created two components a and b.
Created an owned port in component a and b.
Created a property in component a. Typed that property with component a.
Created a property in component a. Typed that property with component b.
Created an owned connector in component a.
Created two ends in connector, each with a role as one of the above
properties.
Created two classes, class1 and class2.
Created an Interface i1.
Typed port from component a with class1, typed port from component b with
class2.
Created a usage with client set to class1, supplier set to i1.
Created a realization with client set to class2, supplier set to i2.
This creates a connector between two components as described from the uml2
newsgroup.
It visualizes as the following in the class diagram: two components, each
with port. Two classes that are connected with lollypop notation.
Seems logical seeing as that's what I just described above.
Shouldn't it also be possible to have lollypop notation between two ports,
and thus the owning components? This is the component diagram notation,
will the component diagram show it in the same way as class diagram?
Not sure if the second question is clear, let me know if you don't
understand,
regards,
nick
and thanks for the help
Re: visual stuff [message #472167 is a reply to message #472066] |
Fri, 21 December 2007 11:56  |
----++Omea_Parts_Splitter.543397701132762
Content-Type: text/plain; charset=koi8-r
Content-Transfer-Encoding: quoted-printable
Hello=20Nick,
Let=20me=20answer=20the=20questions=20about=20visual=20stuff =20first=2e
> =20Regarding=20component=20diagram,=20I=20need=20to=20add=20 some=20visualization=20things=2e
>=20
> =20Is=20it=20possible=20to=20change=20the=20colour=20of=20co mponents=20and=20packages?
GMF=20provides=20two=20possibilities=20to=20change=20the=20c olor=20of=20the=20element:
-=20to=20change=20the=20color=20of=20the=20particular=20elem ent=20use=20'Appearance'=20group=20in=20Properties=20View
-=20to=20change=20the=20color=20of=20all=20the=20elements=20 use=20'UML=20Component=20Diagram/Appearance'=20preferences=2 0page=2e=20
> =20How=20can=20I=20add=20a=20line=20between=20two=20ports=20 or=20two=20components?=20So=20purely
>=20visualization=2e
>=20How=20can=20I=20add=20some=20text=20to=20that=20line=2e
I=20do=20not=20see=20any=20possibility=20to=20add=20a=20visu al=20line=20between=20two=20elements,=20but=20one=20could=20 create=20Note=20with=20any=20text=20(use=20Note=20entry=20fr om=20the=20Text/Note/Note=20Attachment=20palette=20group=20o n=20the=20very=20top=20of=20the=20palette)=20and=20then=20li nk=20it=20with=20Note=20Attachment=2e=20This=20is=20what=20y ou=20need=2e=20The=20construction=20is=20shown=20on=20the=20 picture=20attached=2e=20I=20also=20colored=20Component=20and =20Package=20on=20this=20example=20=3d)
Best=20wishes,
Tatiana=2e
Content-Type: image/pjpeg; name="ForNick.JPG"
Content-Disposition: attachment; filename="ForNick.JPG"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----++Omea_Parts_Splitter.543397701132762--
Re: visual stuff [message #614532 is a reply to message #472066] |
Hello=20Nick,
>=20
>=20visualization=2e
Best=20wishes,
Tatiana=2e
FUDForum. Page generated in 0.05767 seconds
