Home » Eclipse Projects » Remote Application Platform (RAP) » Qooxdoo DateFormat
Qooxdoo DateFormat [message #47053] Thu, 13 September 2007 11:31 Go to next message
I'm trying to build a widget and in it I would like to use the Qooxdoo
function qx.util.format.DateFormat. I'm unable to as I discovered that this
is not present in the RAP "qx.js". Why is this missing?
Tiago
Re: Qooxdoo DateFormat [message #47116 is a reply to message #47053] Thu, 13 September 2007 17:43 Go to previous messageGo to next message
we waited for that moment that someone discovered that :p
Unfortunately in our qooxdoo build process (org.eclipse.rap.tools) we
exclude everything from the qooxdoo runtime not needed by RAP to
minimize the size of the qx.js. We think that this is in the interest of
most RAP developers and users as the rap startup process is much faster.
But we were aware of the fact that the community wants to use functions,
widgets, etc of qooxdoo excluded by us. There are now two ways:
a) Copy everything you need from the org.eclipse.rap.tools project (eg
DateFormat and Format) to your own plugin and register them as resources.
b) Get the org.eclipse.rap.tools project, get a copy of qooxdoo (you'll
need the generator.py scripts), remove the according lines from the
build-custom.sh and build your own qooxdoo library (you'll need python
and some other stuff). After that you need to replace the two js files
of RWT by the newly generated files.
We know that both ways are not that cool but there are no other options
at the moment to get the functionality back.
Maybe you have some ideas how to get the most out of qooxdoo without
having unneeded stuff in the qx build. I think generating qx at runtime
is just impossible as we would need to get the build to run on-the-fly
which requires lot of cpu usage and several tools installed on the
server - so no real option for us.
I think Rüdiger can also comment on this with his thoughts as he is
doing the build most of the time :)
Greets
Benny
Tiago wrote:
> Tiago
Re: Qooxdoo DateFormat [message #47195 is a reply to message #47116] Mon, 17 September 2007 03:29 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
without knowing your actual use-case, a typical RAP application would
not need to format dates on the client-side. Preferably this should be
done server-side and only the properly formatted string is sent to the
client.
If you would like to share your use-case we can maybe find a solution
that works without a client-side DateFormat.
Rüdiger
Benjamin Muskalla wrote:
> Greets
> Benny
> Tiago wrote:
>> Hi,
>> this is not present in the RAP "qx.js". Why is this missing?
>> Tiago
Re: Qooxdoo DateFormat [message #47244 is a reply to message #47195] Mon, 17 September 2007 09:54 Go to previous message
I wanted to have a clock running only on the client side with a specific
date/time format. I followed Benjamin sugestion to include the Qooxdoo
classes in my widget and it worked ok. Thanks for your time anyway.
Tiago
"R
Previous Topic:Creating an empty project, using the article in the current eclipse magazine
Next Topic:Some questions on RAP
Current Time: Sat Oct 25 04:31:10 EDT 2025
Powered by FUDForum. Page generated in 0.04562 seconds
