Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471935] |
Sun, 14 May 2006 12:27  |
Originally posted by: mark.slytechs.com
I've been following the instructions given using ht WTP Tutorials (MS5):
http://www.eclipse.org/webtools/jsf/dev_resource/JSFTutorial -M5/JSFTools_milestone5_tutorial.html
I'm able to setup the JSF libraries (Win->pref->Web&XML->JSF Libraries)
according to the instructions using Sun's JSF RI and Apache's JSTL.
The problem is in the Dynamic Web Project dialog. I don't see the JSF
facelet on screen #2 of the dialog and I don't see the "JavaServer Faces
v1.1 Project" preset either.
I tried setting it up without it and going back to Project
Properties->Project Faces -> Add/Remove Facets, but the JSF facets don't
appear there as well.
I installed a clean version of the
wtp-all-in-one-sdk-R-1.0.2-200604280245-win32 and
wtp-jsf-I-I200604261958-200604261958 of the JSF plugin in brand new
workspace.
Any help would be greatly apprechiated, already spend 3 days on this and
can't really afford any more delay in getting this working.
I've tried to setup JSF manually as well by dropping all the libraries
in WEB-INF/lib directory in Tomcat 5.5(15), but can't get it to work.
Always some kind of error, usually with missing TLDs, unresolvable URI
or unknown tag such as 'taglib'. So far this has been a major pain to
setup in Eclipse.
mark...
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #471939 is a reply to message #471935] |
Sun, 14 May 2006 14:26   |
I resoled the issue with the manual install and can get JSF working
manually. The problem was that, I had to clear the Eclipse's
internet-cache, it had cached empty/corrupt files and that is why none
of my XML files were validating.
I still would like to know why the JSF facets don't appear. Also one
more piece of information. When I click on Projet Properties->JSF
Libraries I get an error message saying that view contains invalid values.
mark..
> workspace.
> setup in Eclipse.
> Cheers,
> mark...
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600424 is a reply to message #471935] |
mark..
> workspace.
> setup in Eclipse.
> Cheers,
> mark...
Re: Missing JSF facet config for Dynamic Project using latest all-in-one w/ wtp [message #600478 is a reply to message #471950] |
Tue, 16 May 2006 07:28  |
Justin Chen wrote:
> Mark,
> Do you happen to capture the log file for the JSF Library Reference
> property page error? I.e., view contains invalid values.
> You probably saw this error because a JSF library was not configured
> during project creation. This is a bug in JSF Library Reference
> property page if no JSF library configured first. This bug should be
> fixed in next build.
> Justin
The log file contains a lot of error messages that are pretty much the
same with the stack traces:
!SESSION 2006-05-13 17:00:37.896
eclipse.buildId=M20060118-1600
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.wtp.jsf.core 1 0 2006-05-13 17:01:05.15
!MESSAGE Could not load JSF Library Registry; creating new registry
!STACK 0
java.io.FileNotFoundException: E:\Documents and
Settings\markbe\workspace-3.2\.metadata\.plugins\org.eclipse .wtp.jsf.core\JSFLibraryRegistry.xml
(The system cannot find the path specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createF ileInputStream(URIConverterImpl.java:462)
at
org.eclipse.emf.ecore.resource.impl.URIConverterImpl.createI nputStream(URIConverterImpl.java:424)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:829)
at
org.eclipse.wtp.jsf.core.internal.JSFCorePlugin.loadJSFLibra ryRegistry(JSFCorePlugin.java:126)
at
org.eclipse.wtp.jsf.core.internal.JSFCorePlugin.start(JSFCor ePlugin.java:83)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:969)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:316)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
org.eclipse.wtp.jsf.ui.internal.classpath.JSFLibrariesPrefer encePage.getJSFLibraries(JSFLibrariesPreferencePage.java:184 )
at
org.eclipse.wtp.jsf.ui.internal.classpath.JSFLibrariesPrefer encePage.createContents(JSFLibrariesPreferencePage.java:91)
at
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:232)
at
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1371)
at
org.eclipse.jface.preference.PreferenceDialog$12.run(Prefere nceDialog.java:1138)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 8)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1132)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:351)
at
org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceDialog.java:638)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:763)
at
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:761)
at
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1042)
at
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1062)
at
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:231)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:226)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 392)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3102)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2761)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.905
!MESSAGE Version [2.4 of project facet jst.web has not been defined.
!STACK 1
org.eclipse.core.runtime.CoreException: Version [2.4 of project facet
at
org.eclipse.wst.common.project.facet.core.internal.VersionMa tchExpr.parseVersion(VersionMatchExpr.java:95)
at
org.eclipse.wst.common.project.facet.core.internal.VersionMa tchExpr. <init>(VersionMatchExpr.java:73)
at
org.eclipse.wst.common.project.facet.core.internal.Versionab le.getVersions(Versionable.java:55)
at
org.eclipse.wst.common.project.facet.ui.internal.Conflicting FacetsFilter.check(ConflictingFacetsFilter.java:117)
at
org.eclipse.wst.common.project.facet.ui.internal.Conflicting FacetsFilter.check(ConflictingFacetsFilter.java:61)
at
org.eclipse.wst.common.project.facet.ui.internal.Conflicting FacetsFilter.check(ConflictingFacetsFilter.java:52)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.isFilteredOut(FacetsSelectionPanel.java:1247)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.access$0(FacetsSelectionPanel.java:1242)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$TableRowData.getVersions(FacetsSelectionPanel.java :1491)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$TableRowData.isVisible(FacetsSelectionPanel.java:1 542)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$ContentProvider.getElements(FacetsSelectionPanel.j ava:1591)
at
org.eclipse.jface.viewers.StructuredViewer.getRawChildren(St ructuredViewer.java:848)
at
org.eclipse.jface.viewers.AbstractTreeViewer.getRawChildren( AbstractTreeViewer.java:896)
at
org.eclipse.jface.viewers.StructuredViewer.getFilteredChildr en(StructuredViewer.java:790)
at
org.eclipse.jface.viewers.StructuredViewer.getSortedChildren (StructuredViewer.java:905)
at
org.eclipse.jface.viewers.AbstractTreeViewer.updateChildren( AbstractTreeViewer.java:1707)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh Struct(AbstractTreeViewer.java:1268)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1245)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1201)
at
org.eclipse.jface.viewers.AbstractTreeViewer.internalRefresh (AbstractTreeViewer.java:1188)
at
org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:1264)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:1201)
at
org.eclipse.jface.viewers.CheckboxTreeViewer.preservingSelec tion(CheckboxTreeViewer.java:364)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1262)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:1221)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.refresh(FacetsSelectionPanel.java:1079)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.addFilter(FacetsSelectionPanel.java:760)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPage.createControl(FacetsSelectionPage.java:159)
at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:179)
at
org.eclipse.wst.common.project.facet.ui.AddRemoveFacetsWizar d.createPageControls(AddRemoveFacetsWizard.java:259)
at
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:965)
at
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1016)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:114)
at
at
at
at
at
at
at
!SUBENTRY 1 org.eclipse.wst.common.project.facet.core 4 0 2006-05-13
17:03:58.905
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.915
!MESSAGE Version [2.3 of project facet jst.web has not been defined.
!STACK 1
org.eclipse.core.runtime.CoreException: Version [2.3 of project facet
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
17:03:58.915
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.935
!STACK 1
at
at
at
at
at
at
at
at
at
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.refreshPresetsCombo(FacetsSelectionPanel.java:1112 )
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.addFilter(FacetsSelectionPanel.java:761)
at
at
at
at
at
at
at
at
at
at
at
at
17:03:58.935
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:03:58.945
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
17:03:58.945
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.447
!STACK 1
at
at
at
at
at
at
at
at
at
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$TableRowData.isSelected(FacetsSelectionPanel.java: 1517)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel.getSelectedProjectFacets(FacetsSelectionPanel.java :673)
at
org.eclipse.wst.common.project.facet.ui.internal.FacetsSelec tionPanel$12.check(FacetsSelectionPanel.java:440)
at
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el.isFilteredOut(RuntimesPanel.java:254)
at
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el.access$0(RuntimesPanel.java:247)
at
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el$LabelProvider.getForeground(RuntimesPanel.java:514)
at
org.eclipse.jface.viewers.StructuredViewer$ColorAndFontColle ctorWithProviders.setFontsAndColors(StructuredViewer.java:17 6)
at org.eclipse.jface.viewers.TableViewer.doUpdateItem(TableView er.java:439)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:434)
at
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1763)
at org.eclipse.jface.viewers.TableViewer.createItem(TableViewer .java:344)
at
org.eclipse.jface.viewers.TableViewer.internalRefreshAll(Tab leViewer.java:850)
at
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:748)
at
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:737)
at
at
at
org.eclipse.jface.viewers.CheckboxTableViewer.preservingSele ction(CheckboxTableViewer.java:289)
at
at
at
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el.refresh(RuntimesPanel.java:265)
at
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el$4.handle(RuntimesPanel.java:172)
at
org.eclipse.wst.common.project.facet.core.runtime.internal.R untimeManagerImpl.notifyRuntimeListeners(RuntimeManagerImpl. java:261)
at
org.eclipse.wst.common.project.facet.core.runtime.internal.R untimeManagerImpl.bridge(RuntimeManagerImpl.java:418)
at
org.eclipse.wst.common.project.facet.core.runtime.internal.R untimeManagerImpl.getRuntimes(RuntimeManagerImpl.java:129)
at
org.eclipse.wst.common.project.facet.core.runtime.RuntimeMan ager.getRuntimes(RuntimeManager.java:84)
at
org.eclipse.wst.common.componentcore.datamodel.FacetProjectC reationDataModelProvider.getValidPropertyDescriptors(FacetPr ojectCreationDataModelProvider.java:289)
at
org.eclipse.wst.common.frameworks.internal.datamodel.DataMod elImpl.getValidPropertyDescriptors(DataModelImpl.java:320)
at
org.eclipse.wst.web.ui.internal.wizards.DataModelFacetCreati onWizardPage.launchNewRuntimeWizard(DataModelFacetCreationWi zardPage.java:65)
at
org.eclipse.wst.web.ui.internal.wizards.DataModelFacetCreati onWizardPage$1.widgetSelected(DataModelFacetCreationWizardPa ge.java:101)
at
at
at
at
at
at
at
17:04:35.447
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.457
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
17:04:35.457
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.487
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.wst.common.project.facet.ui.internal.RuntimesPan el$LabelProvider.getImage(RuntimesPanel.java:482)
at
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:1878)
at org.eclipse.jface.viewers.TableViewer.doUpdateItem(TableView er.java:458)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
17:04:35.497
!ENTRY org.eclipse.wst.common.project.facet.ui 4 0 2006-05-13 17:04:35.507
!STACK 1
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.ec
FUDForum. Page generated in 0.05701 seconds
