Home » Modeling » UML2 » Installing uml2...
Installing uml2... [message #471815] Tue, 27 March 2007 07:52 Go to next message
Originally posted by: patrick.gelin.free.fr
This is my Eclipse version:
Version: 3.3.0
Build id: I20070323-1616
I downloaded and installed:
* emf-sdo-runtime-2.3.0M5.zip
* xsd-runtime-2.3.0M5.zip
* uml2-2.1M5.zip
But there is a problem because I can't see anything concerning uml into the
menu... so what is the problem?
Thank you for your help.
Patrick
Re: Installing uml2... [message #471816 is a reply to message #471815] Tue, 27 March 2007 09:06 Go to previous messageGo to next message
Hi Patrick,
Did you create a uml model? Did you read the "getting started" articles?
- James.
"Patrick Gelin" <patrick.gelin@free.fr> wrote in message
news:eub0ie$8tk$1@utils.eclipse.org...
> Version: 3.3.0
> * uml2-2.1M5.zip
the
> Patrick
Re: Installing uml2... [message #471819 is a reply to message #471816] Tue, 27 March 2007 10:59 Go to previous messageGo to next message
Hi James,
I can't create a UML model because there is no menu about that and I can't
find any help documentation into eclipse about the UML module... What I can
see is only into "Manage Configuration" and property, something like this:
UML2 Runtime + End-User Tools 2.1.0.v200702222305
Identifier: org.eclipse.uml2
Provider Eclipse.org
The size is very small, isn't it?
I'm really asking myself about the installation of the module. Is it
possible to uninstall simply and retry to install an other way?
Patrick
James Bruck wrote:
> Hi Patrick,
> Cheers,
> - James.
Re: Installing uml2... [message #471820 is a reply to message #471819] Tue, 27 March 2007 11:25 Go to previous messageGo to next message
Hi Patrick,
Articles can be found here http://wiki.eclipse.org/index.php/MDT-UML2
You can create a .uml model through...
File > New > Other ... > Example EMF Model Creation Wizards > UML model.
Once you've created your model, you can see the "UML Menu" item.
- James.
news:eubbgf$lj0$1@utils.eclipse.org...
> Hi James,
can
> Patrick
> James Bruck wrote:
> > Hi Patrick,
articles?
> > Cheers,
> > - James.
Re: Installing uml2... [message #471923 is a reply to message #471820] Tue, 27 March 2007 12:00 Go to previous messageGo to next message
ok, I follow the article until:
Creating Models
At the root of a typical UML model is a model element. It contains a
(hierarchical) set of elements that together describe the physical system
being modeled. To create a model using the UML editor, follow these steps:
1) Select a project (i.e. Getting Started with UML2) in the Navigator view
and select the File > New > Other... menu item.
2) Select the UML Model wizard from the Example EMF Model Creation Wizards
category and press the Next > button.
here I can't excute the point (2) because there isn't UML Model wizard into
my new Menu...
That is the problem!
What can I do? Uninstall and reinstall...
Patrick
James Bruck wrote:
> Hi Patrick,
> - James.
>> Hi James,
>> can't find any help documentation into eclipse about the UML module...
>> What I
> can
>> this:
>> Patrick
>> James Bruck wrote:
>> > Hi Patrick,
> articles?
>> > Cheers,
>> > - James.
Re: Installing uml2... [message #471927 is a reply to message #471923] Tue, 27 March 2007 12:58 Go to previous messageGo to next message
Patrick,
Sounds like you didn't install uml properly. Yes you will have to
reinstall.
- James.
news:eubf2k$34l$1@utils.eclipse.org...
> Creating Models
into
> my new Menu...
> Patrick
> James Bruck wrote:
> > Hi Patrick,
> > - James.
> >> Hi James,
> >> What I
> > can
> >> this:
> >> Patrick
> >> James Bruck wrote:
> >> > Hi Patrick,
> > articles?
> >> > Cheers,
> >> > - James.
Re: Installing uml2... [message #471931 is a reply to message #471927] Tue, 27 March 2007 14:46 Go to previous messageGo to next message
I said myself, may be you had to install UML2 TOOLS. So I dit it's the
same problem. I verifier with md5sum the UML2 package I downloaded, and
it's ok, the the problem is not here. I'm ok to reinstall it but I think
nothing will change. Do you know a dialog box where I can see error log or
something like that about plugin installation?
Patrick
Re: Installing uml2... [message #471934 is a reply to message #471931] Tue, 27 March 2007 15:06 Go to previous messageGo to next message
Patrick,
Do you have the EMF Wizards missing as well. If so, we got hit by
the fact that Eclipse M5 was running Java 1.4.2, but actually needs 1.5.
Deleting 1.4.2 did the trick.
Andy
news:pan.2007.03.27.18.46.07.959425@free.fr...
> Patrick
Re: Installing uml2... [message #471938 is a reply to message #471934] Wed, 28 March 2007 02:29 Go to previous messageGo to next message
This is the VM i'm using: j2sdk1.4.2_13
About the EMF wizard I can say it is missing too.This is what I can see
into the choice of wizard when I select 'new':
class
- interface
- java Project
- Java Project from existing Ant Buildfile
- Plug in project
- General (folder)
- CVS (folder)
- Java (folder)
- Plug in Development (folder)
- Server (folder)
- User Assistance (folder)
- Examples (folder)
About the example folder it contain wizard of UML2 TOOLS I installed at
last. The folders it contain are:
- EMFT Query Plug-ins
- EMFT Transaction Plug-ins
- EMFT Validation Plug-ins
- GEF
- GEF Plug-ins
- GMF Plug-ins
That's all! nothing about EMF or UML... So you think I've got a bad
Virtual Machine... This is my $JAVA_HOME=/opt/j2sdk1.4.2_13/jre. What can
I do? Change the virtual machine to 1.5?
Patrick
Le Tue, 27 Mar 2007 20:06:44 +0100, ase a écrit :
> Patrick,
> Andy
Re: Installing uml2... [message #471952 is a reply to message #471938] Wed, 28 March 2007 10:09 Go to previous messageGo to next message
Patrick,
You need a Java 5 VM to use EMF 2.3 and UML2 2.1.
Kenn
news:pan.2007.03.28.06.29.12.247315@free.fr...
> class
> - interface
> - java Project
> - Plug in project
> - General (folder)
> - CVS (folder)
> - Java (folder)
> - Server (folder)
> - Examples (folder)
> - GEF
> - GEF Plug-ins
> - GMF Plug-ins
> Patrick
Re: Installing uml2... [message #471959 is a reply to message #471952] Wed, 28 March 2007 11:11 Go to previous messageGo to next message
Kenn,
ok this is my JAVA_HOME:
JAVA_HOME=/opt/jre1.5.0_11
But the problem is the same.
- Is it possible, into Eclipse, to see if it use the good jre...
- Do you think I have to delete UML plugin and reinstall it?
Patrick
Le Wed, 28 Mar 2007 10:09:44 -0400, Kenn Hussey a écrit :
> Patrick,
> Kenn
Re: Installing uml2... [message #471966 is a reply to message #471952] Wed, 28 March 2007 11:36 Go to previous message
Ok, I've found the solution!
The problem is that the JAVA_HOME variable into my .bashrc is not take
into account. Alternatives defined the java command as
/opt/j2sdk1.4.2_13/... so I have to redefined it as /opt/jre1.5.0_11/...
Thank you everybody for your help.
Have a good day!
Patrick
Re: Installing uml2... [message #603216 is a reply to message #471815] Tue, 27 March 2007 09:06 Go to previous message
Hi Patrick,
- James.
> Version: 3.3.0
> * uml2-2.1M5.zip
the
> Patrick
Re: Installing uml2... [message #603231 is a reply to message #471816] Tue, 27 March 2007 10:59 Go to previous message
Hi James,
Patrick
James Bruck wrote:
> Hi Patrick,
> Cheers,
> - James.
Re: Installing uml2... [message #603234 is a reply to message #471819] Tue, 27 March 2007 11:25 Go to previous message
Hi Patrick,
- James.
> Hi James,
can
> Patrick
> James Bruck wrote:
> > Hi Patrick,
articles?
> > Cheers,
> > - James.
Re: Installing uml2... [message #603257 is a reply to message #471820] Tue, 27 March 2007 12:00 Go to previous message
Creating Models
my new Menu...
Patrick
James Bruck wrote:
> Hi Patrick,
> - James.
>> Hi James,
>> What I
> can
>> this:
>> Patrick
>> James Bruck wrote:
>> > Hi Patrick,
> articles?
>> > Cheers,
>> > - James.
Re: Installing uml2... [message #603264 is a reply to message #471923] Tue, 27 March 2007 12:58 Go to previous message
Patrick,
reinstall.
- James.
> Creating Models
into
> my new Menu...
> Patrick
> James Bruck wrote:
> > Hi Patrick,
> > - James.
> >> Hi James,
> >> What I
> > can
> >> this:
> >> Patrick
> >> James Bruck wrote:
> >> > Hi Patrick,
> > articles?
> >> > Cheers,
> >> > - James.
Re: Installing uml2... [message #603270 is a reply to message #471927] Tue, 27 March 2007 14:46 Go to previous message
Patrick
Re: Installing uml2... [message #603272 is a reply to message #471931] Tue, 27 March 2007 15:06 Go to previous message
Patrick,
Andy
> Patrick
Re: Installing uml2... [message #604044 is a reply to message #471934] Wed, 28 March 2007 02:29 Go to previous message
class
- interface
- java Project
- Plug in project
- General (folder)
- CVS (folder)
- Java (folder)
- Server (folder)
- Examples (folder)
- GEF
- GEF Plug-ins
- GMF Plug-ins
Patrick
> Patrick,
> Andy
Re: Installing uml2... [message #604064 is a reply to message #471938] Wed, 28 March 2007 10:09 Go to previous message
Patrick,
Kenn
> class
> - interface
> - java Project
> - Plug in project
> - General (folder)
> - CVS (folder)
> - Java (folder)
> - Server (folder)
> - Examples (folder)
> - GEF
> - GEF Plug-ins
> - GMF Plug-ins
> Patrick
Re: Installing uml2... [message #604076 is a reply to message #471952] Wed, 28 March 2007 11:11 Go to previous message
Kenn,
Patrick
> Patrick,
> Kenn
Re: Installing uml2... [message #604086 is a reply to message #471952] Wed, 28 March 2007 11:36 Go to previous message
Have a good day!
Patrick
Previous Topic:WrappedException: feature eGenericType not found while loading model
Next Topic:Can enumerations specialize primitive types ?
Current Time: Sun Jul 27 02:25:55 EDT 2025
Powered by FUDForum. Page generated in 0.06898 seconds
