Home » Eclipse Projects » JavaServer Faces » custom variableresolver support ?
custom variableresolver support ? [message #471790] Wed, 03 May 2006 17:25 Go to next message
Hi Ragu,
We talked at eclipescon about custom variable resolver support in the JSF
plugin.
How close are that to realized ?
/max
Re: custom variableresolver support ? [message #471791 is a reply to message #471790] Thu, 04 May 2006 21:11 Go to previous messageGo to next message
Hi Max,
We are currently working on the ability to attach a custom variable
resolver. Our current design is to allow you to create an extension point
that defines a factory class to create a "design time" variable resolver.
This resolver closely mimics the behaviour of the runtime counterpart. A
similar provision will be made for property resolvers.
The variable resolver will be replaceable on a per-project basis. It's
not entirely clear yet which mechanism we will use to programmatically
assign an active variable resolver factory to a project. Suggestions are
welcome.
--Cam
Max Rydahl Andersen wrote:
> Hi Ragu,
> plugin.
> /max
Re: custom variableresolver support ? [message #471792 is a reply to message #471791] Fri, 05 May 2006 17:19 Go to previous messageGo to next message
it is not enough to just read the jsf config file which has the class
listed ?
and then look up the extension points that support that classname ?
/max
> Hi Max,
> point that defines a factory class to create a "design time" variable
> resolver. This resolver closely mimics the behaviour of the runtime
> counterpart. A similar provision will be made for property resolvers.
> are welcome.
> --Cam
>> Hi Ragu,
>> JSF plugin.
>> /max
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: custom variableresolver support ? [message #471796 is a reply to message #471792] Tue, 09 May 2006 16:08 Go to previous messageGo to next message
> listed ?
I'm not sure what you are suggesting. Do you mean look up the a managed
bean's class? Or are you talking about a registered component? Or
something else?
--Cam
Re: custom variableresolver support ? [message #471942 is a reply to message #471796] Sun, 14 May 2006 16:49 Go to previous messageGo to next message
I was just thinking about
<faces-config>
<application>
<variable-resolver>XYZ</variable-resolver>
</application>
</faces-config>
...but i reckon that is not the only way of installing varaible-resolvers
in JSF.
>> listed ?
> something else?
> --Cam
Re: custom variableresolver support ? [message #471945 is a reply to message #471942] Mon, 15 May 2006 13:04 Go to previous messageGo to next message
> <faces-config>
> <application>
> </application>
> </faces-config>
> in JSF.
Raghu pointed out to me that might be what you meant. It's a good idea.
My basic aim is to provide a generic programmatic way to change it so that
adopters have the option to choose the scheme they want. If there is time
in this release, I'll look into providing your suggestion as a default
behaviour.
--Cam
Re: custom variableresolver support ? [message #471970 is a reply to message #471945] Sat, 20 May 2006 18:00 Go to previous message
cool! is there an eclipse bugzilla for it or ?
>> <faces-config>
>> <application>
>> </application>
>> </faces-config>
>> varaible-resolvers in JSF.
> idea. My basic aim is to provide a generic programmatic way to change
> it so that adopters have the option to choose the scheme they want. If
> there is time in this release, I'll look into providing your suggestion
> as a default behaviour.
> --Cam
Re: custom variableresolver support ? [message #600308 is a reply to message #471790] Thu, 04 May 2006 21:11 Go to previous message
Hi Max,
welcome.
--Cam
> Hi Ragu,
> plugin.
> /max
Re: custom variableresolver support ? [message #600316 is a reply to message #471791] Fri, 05 May 2006 17:19 Go to previous message
listed ?
/max
> Hi Max,
> are welcome.
> --Cam
>> Hi Ragu,
>> JSF plugin.
>> /max
Re: custom variableresolver support ? [message #600354 is a reply to message #471792] Tue, 09 May 2006 16:08 Go to previous message
> listed ?
something else?
--Cam
Re: custom variableresolver support ? [message #600429 is a reply to message #471796] Sun, 14 May 2006 16:49 Go to previous message
<faces-config>
<application>
</application>
</faces-config>
in JSF.
>> listed ?
> something else?
> --Cam
Re: custom variableresolver support ? [message #600434 is a reply to message #471942] Mon, 15 May 2006 13:04 Go to previous message
> <faces-config>
> <application>
> </application>
> </faces-config>
> in JSF.
behaviour.
--Cam
Re: custom variableresolver support ? [message #600506 is a reply to message #471945] Sat, 20 May 2006 18:00 Go to previous message
>> <faces-config>
>> <application>
>> </application>
>> </faces-config>
> --Cam
Previous Topic:JSF Tools Project Milestone RC2 build posted..
Next Topic:How do I obtain the latest development build
Current Time: Wed Jul 23 02:02:02 EDT 2025
Powered by FUDForum. Page generated in 0.07141 seconds
