Home » Modeling » UML2 » Unable to resolve applicable stereotype
Unable to resolve applicable stereotype [message #471641] Wed, 14 March 2007 11:19 Go to next message
I have deefined a UML profile and have successfully applied it to a model,
applying stereotypes without problems, using the eclipse UML editor.
However I am as yet unable to achieve this in my code.
I've checked that I'm calling model.applyProfile(profile), I create an
owned class for a package (called target) and then do:
Stereotype s = target.getApplicableStereotype(stereotypeName)
This always returns null. I also find that
target.getApplicableStereotypes() returns an empty list.
The code continues to build the model file but without applying
stereotypes. I can then manually apply the stereotypes using the UML
editor later, proving (perhaps) that the stereotypes are valid for the
classes being genereated.
I notice that the UMLArticles example does not use getApplicableStereotype
as it constructs the profile and then uses the stereotype references
directly when applying them to the model later on.
Any help would be greatly appreciated.
Re: Unable to resolve applicable stereotype [message #471642 is a reply to message #471641] Wed, 14 March 2007 12:27 Go to previous messageGo to next message
Some additional information:
It seems that getExtension() in
org.eclipse.uml2.uml.internal.operations.ElementOperations is failing to
determine a type for the metaclass extension attribute (the stereotype's
property starting with "base_"), i.e. attribute.getType() returns null.
I'm using UML 2.0.2.
Cheers
Re: Unable to resolve applicable stereotype [message #471643 is a reply to message #471642] Wed, 14 March 2007 14:56 Go to previous messageGo to next message
Hi Paul,
Can you post your profile so that I can have a look?
This sounds really bizarre because the UML editor doesn't do anything
special when applying stereotypes.
If it works with the editor, it should work with your program.
- James.
"Paul Gribben" <paul.gribben@gmail.com> wrote in message
news:a428fc3f553759070d30895594a158d5$1@www.eclipse.org...
> Cheers
Re: Unable to resolve applicable stereotype [message #471644 is a reply to message #471642] Wed, 14 March 2007 15:29 Go to previous messageGo to next message
Paul,
Have you registered the required pathmaps as outlined in the FAQ (and shown
in the source for the "Introduction to UML2 Profiles" article)?
Kenn
> Cheers
Re: Unable to resolve applicable stereotype [message #471645 is a reply to message #471644] Wed, 14 March 2007 17:06 Go to previous messageGo to next message
Yes I've set up the pathmaps. One alteration from the FAQ is that the
2.0.2 API doesn't have URI.create(..) so I've used URI.createURI(..)
passing my jar resource as a string argument.
Re: Unable to resolve applicable stereotype [message #471646 is a reply to message #471643] Thu, 15 March 2007 04:51 Go to previous messageGo to next message
I've found the problem. It seems that one of my esteemed colleagues
changed (incorrectly) the URI reference to the
org.eclipse.uml2.uml.resources-2.0.2.v200610251409.jar resource file,
causing the UML2 libraries to silently fail to resolve resource references.
It's quite difficult to debug this stuff when it goes wrong, as there's no
feedback from the uml2 library code.
Re: Unable to resolve applicable stereotype [message #471647 is a reply to message #471644] Thu, 15 March 2007 04:52 Go to previous message
Thanks for that clue Kenn.
Thanks again
Re: Unable to resolve applicable stereotype [message #598491 is a reply to message #471641] Wed, 14 March 2007 12:27 Go to previous message
Cheers
Re: Unable to resolve applicable stereotype [message #598496 is a reply to message #471642] Wed, 14 March 2007 14:56 Go to previous message
Hi Paul,
- James.
> Cheers
Re: Unable to resolve applicable stereotype [message #599487 is a reply to message #471642] Wed, 14 March 2007 15:29 Go to previous message
Paul,
Kenn
> Cheers
Re: Unable to resolve applicable stereotype [message #599498 is a reply to message #471644] Wed, 14 March 2007 17:06 Go to previous message
Re: Unable to resolve applicable stereotype [message #599508 is a reply to message #471643] Thu, 15 March 2007 04:51 Go to previous message
Re: Unable to resolve applicable stereotype [message #599523 is a reply to message #471644] Thu, 15 March 2007 04:52 Go to previous message
Thanks again
Previous Topic:Unable to resolve applicable stereotype
Next Topic:how to make a "middleweight" extension on L0 or LM.
Current Time: Sat Jul 26 21:00:01 EDT 2025
Powered by FUDForum. Page generated in 0.10125 seconds
