errors [message #471606] |
Sat, 08 April 2006 08:11  |
when i try to add a reference to a managed bean from a jsp page, i get a
stakoverflow :
java.lang.StackOverflowError
at java.lang.ClassLoader.findBootstrapClass(Native Method)
at java.lang.ClassLoader.findBootstrapClass0(ClassLoader.java:8 91)
at java.lang.ClassLoader.loadClass(ClassLoader.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:367)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:351)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:81)
Trying to design page flow is also not possible cause i'm unable to see any
jsp contained
in my web project, what i'm i missing?
thanks.
Re: errors [message #471617 is a reply to message #471616] |
Wed, 19 April 2006 21:01  |
The required WTP build was I20060310 (the March 10 integration build),
which I can't find anymore (actually all integration builds seem to have
disappeared). This build fixes a bug in a JSF dependency that caused the
stack overflow you are seeing.
Bugzilla: https://bugs.eclipse.org/bugs/show_bug.cgi?id=130402
--Cam
Alessandro Fredianelli wrote:
> wtp-S-1.5M5-200603022222.
> i tryied with 1.5m6 but i had problems.
Re: errors [message #596929 is a reply to message #471606] |
Tue, 11 April 2006 15:56  |
Hi Alessandro,
Can you give us a bit more detail? What version of the JSF deliverables
are you using? What version of the JSF dependencies (Eclipse, EMF etc.)?
Are you using a Dynamic Web project with the JSF facet enabled?
Also, can check the stack trace you have and try and find some line
entries that start org.eclipse.wtp.jsf?
--Cam
> stakoverflow :
> at
> at
> at
> jsp contained
> thanks.
Re: errors [message #596957 is a reply to message #471608] |
Tue, 18 April 2006 06:31  |
jsf deliverable milestone 5 and all dependancies described into related
tutorial.
I'm following the tutorial, everything works fine except the one i
mentioned.
I attach a more detailed stacktrace extract :
!ENTRY org.eclipse.ui 4 4 2006-04-18 12:22:16.109
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2006-04-18 12:22:16.109
!MESSAGE java.lang.StackOverflowError
!STACK 0
at
at
at
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:138)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.wst.sse.ui.internal.ExtendedConfigurationBuilder .createExtension(ExtendedConfigurationBuilder.java:89)
at
org.eclipse.wst.sse.ui.internal.ExtendedConfigurationBuilder .createConfigurations(ExtendedConfigurationBuilder.java:134)
at
org.eclipse.wst.sse.ui.internal.ExtendedConfigurationBuilder .getConfigurations(ExtendedConfigurationBuilder.java:203)
at
org.eclipse.wst.sse.ui.internal.contentassist.StructuredCont entAssistant.getContentAssistProcessor(StructuredContentAssi stant.java:90)
at
org.eclipse.wst.sse.ui.internal.contentassist.StructuredCont entAssistant.setContentAssistProcessor(StructuredContentAssi stant.java:52)
at
org.eclipse.wst.sse.ui.internal.contentassist.StructuredCont entAssistant.getContentAssistProcessor(StructuredContentAssi stant.java:95)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
it continues this way until the overflow.
"Cameron Bateman" <cameron.bateman@oracle.com> ha scritto nel messaggio
news:df94cc655456a877ce7a7eab86e0cfde$1@www.eclipse.org...
> Hi Alessandro,
Re: errors [message #596964 is a reply to message #471612] |
Tue, 18 April 2006 09:20  |
>> Hi Alessandro,
Also, which build of WTP are you using? This may already be fixed
in newer builds.
- Nitin
Re: errors [message #596969 is a reply to message #471615] |
Tue, 18 April 2006 09:30  |
"Nitin Dahyabhai" <nitind@us.ibm.com> ha scritto nel messaggio
news:e22p29$7go$1@utils.eclipse.org...
>>> Hi Alessandro,
>>> etc.)? Are you using a Dynamic Web project with the JSF facet enabled?
> Also, which build of WTP are you using? This may already be fixed in
> newer builds.
> - Nitin
Re: errors [message #596978 is a reply to message #471616] |
--Cam
FUDForum. Page generated in 0.04871 seconds
