Problem with split packages [message #47114] |
Fri, 18 March 2005 09:14  |
I am seeing a problem with resolving a split package across bundles (using
Eclipse 31 M5a driver). Here is the scenario:
Bundle-A :
Export-Package: package.split
Bundle-B :
Require-Bundle: Bundle-A
Bundle-glue:
Require-Bundle: Bundle-A, Bundle-B
Reexport-Package: package.split; foo="bar"
After launching, Bundle-Glue doesn't seem to get resolved.
If I turn on tracing on OSGi resolver options, I see the following message,
before Bundle-glue is declared not resolved:
"* grouping clash with [Bundle-A] : package.split"
Can someone explain what this means ? Is this not a valid split-package
scenario ?
Subbarao
Re: Problem with split packages [message #47173 is a reply to message #47114] |
Wed, 23 March 2005 07:47  |
Originally posted by: stepper.sympedia.de
Subbarao,
are you sure you may name your package "package.XYZ"?
"package" is not allowed as identifier in Java.
Cheers
/Eike
> Bundle-A :
> Bundle-B :
> Bundle-glue:
> scenario ?
> Subbarao
FUDForum. Page generated in 0.03713 seconds
