Home » Modeling » UML2 » Applied Profile & ArrayStoreException
Applied Profile & ArrayStoreException [message #471354] |
Tue, 06 March 2007 17:03  |
I'm trying to import an UML2 model generated with RSA6 as ECORE model.
This has been working since I started to use it from Eclipse 3.1 on...
However, with the current version is the first which fails in
org.eclipse.emf.importer with the following exception. Any idea what to
do? Is it a bug?
Value 'org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl@191222b
(isStrict: false)' is not legal.
(file:/C:/coding/code/rsa_exports/pcm.uml2, 7, 85)
org.eclipse.emf.ecore.xmi.IllegalValueException: Value
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2506)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2491)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTy peName(XMLHandler.java:1944)
at
org.eclipse.uml2.uml.internal.resource.UML22UMLHandler.creat eObject(UML22UMLHandler.java:62)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLH andler.java:1653)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:957)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:87)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:936)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:681)
at
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:163)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:178)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1164)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:965)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
at
org.eclipse.uml2.uml.ecore.importer.UMLImporter.doComputeEPa ckages(UMLImporter.java:157)
at
org.eclipse.emf.importer.ModelImporter.computeEPackages(Mode lImporter.java:527)
at
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.refreshModel(ModelImporterDetailPage.java:406)
at
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage$3.execute(ModelImporterDetailPage.java:351)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1798)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
at
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 890)
at
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.refreshModel(ModelImporterDetailPage.java:374)
at
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage.handleOriginalModelFile(ModelImporterDetailPage.ja va:118)
at
org.eclipse.emf.importer.ui.contribution.base.ModelImporterD etailPage$1.run(ModelImporterDetailPage.java:109)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3467)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3107)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:115)
at
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:105)
at
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:243)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3490)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3104)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2264)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2228)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 03)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:457)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:452)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1124)
Caused by: java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:191)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:645)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:331)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:288)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHel perImpl.java:1088)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XM LHandler.java:2501)
.... 77 more
Re: Applied Profile & ArrayStoreException [message #471362 is a reply to message #471356] |
Wed, 07 March 2007 15:03   |
To add a bit more info ...
It seems that all the ecore2xml information is being ignored ( not just for
packageImport ). I can open your model with a text editor and remove all
the PackageImports to reduce your model to simply have a class with owned
attribute. When I try to open...still no luck.
If I take this one step further, I can replace ownedMember with
packagedElement then I will be able to open your model. ... not the kind of
migration experience you were hoping for ;).
I haven't pinpointed the problem in UML code just yet.
Please log a bugzilla on this for the UML component and it will be taken
care of shortly.
p.s. By the way, there seems to be several garbage characters at the
beginning of your model. This is not causing the problem but I'm not sure
how they got there.
- James.
"Steffen Becker" <becker@informatik.uni-oldenburg.de> wrote in message
news:eslkvo$820$1@utils.eclipse.org...
> Kenn Hussey schrieb:
> > Steffen,
> > Would you be able to provide a representative sample so that we can
> > investigate?
> > Kenn
> Sure, I can attach one. This is the most basic model of a bunch of UML
> models which belong together. However, this one is stand-alone and has
> only one class which is called "Identifier" to mark classed which should
> have IDs. The applied profile is the Ecore-Profile of RSA6 (maybe the
> source of the problem?). As I said before, this worked in all earlier
> versions of the plugin.
> If you open the file directly, there is no error message (which I find
> also strange) but the class is not there :-(. In the EMF Project Dialog
> it causes the afore meantioned exception.
> However, it is possible to open it in M4, save the imported uml file and
> open it with M5. This works correctly.
> Cheers,
> Steffen
> <uml:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:Ecore_0="http:///Ecore_0.profile.uml2"
xmlns:uml="http://www.eclipse.org/uml2/1.0.0/UML"
xsi:schemaLocation="http:///Ecore_0.profile.uml2
pathmap://UML2_PROFILES/Ecore.profile.uml2#_v9VUsK87Edi5QpYe Y_yIpg"
xmi:id="_hl1PocjwEdu-zpdkLYojiw" name="identifier"
appliedProfile="_hl1PpcjwEdu-zpdkLYojiw _hl1PqMjwEdu-zpdkLYojiw
_hl1Pq8jwEdu-zpdkLYojiw _hl1Pr8jwEdu-zpdkLYojiw">
> <eAnnotations xmi:id="_hl1PosjwEdu-zpdkLYojiw"
source="http://www.eclipse.org/emf/2002/Ecore" />
> <eAnnotations xmi:id="_hl1Po8jwEdu-zpdkLYojiw"
source="appliedStereotypes">
> <contents xmi:type="Ecore_0:Ecore__EPackage"
xmi:id="_hl1PpMjwEdu-zpdkLYojiw" nsPrefix="identifier"
nsURI="http://sdq.ipd.uka.de/Identifier/1.0" basePackage="de.uka.ipd.sdq" />
> </eAnnotations>
> <packageImport xmi:type="uml:ProfileApplication"
xmi:id="_hl1PpcjwEdu-zpdkLYojiw">
> <eAnnotations xmi:id="_hl1PpsjwEdu-zpdkLYojiw" source="attributes">
> <details xmi:id="_hl1Pp8jwEdu-zpdkLYojiw" key="version" value="0" />
> </eAnnotations>
> <importedPackage xmi:type="uml:Profile"
href=" pathmap://UML2_PROFILES/Basic.profile.uml2#_6mFRgK86Edih9-GG 5afQ0g" />
> <importedProfile
> </packageImport>
xmi:id="_hl1PqMjwEdu-zpdkLYojiw">
> <eAnnotations xmi:id="_hl1PqcjwEdu-zpdkLYojiw" source="attributes">
> <details xmi:id="_hl1PqsjwEdu-zpdkLYojiw" key="version" value="0" />
> </eAnnotations>
href=" pathmap://UML2_PROFILES/Intermediate.profile.uml2#_Cz7csK87E dih9-GG5af
Q0g" />
> <importedProfile
Q0g" />
> </packageImport>
xmi:id="_hl1Pq8jwEdu-zpdkLYojiw">
> <eAnnotations xmi:id="_hl1PrMjwEdu-zpdkLYojiw" source="attributes">
> <details xmi:id="_hl1PrcjwEdu-zpdkLYojiw" key="version" value="0" />
> </eAnnotations>
href=" pathmap://UML2_PROFILES/Complete.profile.uml2#_M7pTkK87Edih9 -GG5afQ0g"
> <importedProfile
> </packageImport>
> <packageImport xmi:id="_hl1PrsjwEdu-zpdkLYojiw">
> <importedPackage xmi:type="uml:Model"
href=" pathmap://UML2_LIBRARIES/UML2PrimitiveTypes.library.uml2#_Ef RZoK86Edie
aYgxtVWN8Q" />
> </packageImport>
xmi:id="_hl1Pr8jwEdu-zpdkLYojiw">
> <eAnnotations xmi:id="_hl1PsMjwEdu-zpdkLYojiw" source="attributes">
> <details xmi:id="_hl1PscjwEdu-zpdkLYojiw" key="version" value="0" />
> </eAnnotations>
href=" pathmap://UML2_PROFILES/Ecore.profile.uml2#_siPt4K87Edi5QpYe Y_yIpg" />
> <importedProfile
> </packageImport>
> <ownedMember xmi:type="uml:Class" xmi:id="_hl1PssjwEdu-zpdkLYojiw"
name="Identifier" isAbstract="true">
> <ownedComment xmi:id="_hl1Ps8jwEdu-zpdkLYojiw" body="Identifiers are
not fixed to one realization.
GUIDs are recommend. GUIDs are
described in their own model. See GUIDModel (GUID.emx).
Identifier
implementations can be found in external projects only."
annotatedElement="_hl1PssjwEdu-zpdkLYojiw" />
> <ownedRule xmi:id="_hl1PtMjwEdu-zpdkLYojiw" name="idHasToBeUnique"
constrainedElement="_hl1PssjwEdu-zpdkLYojiw">
> <specification xmi:type="uml:OpaqueExpression"
xmi:id="_hl1PtcjwEdu-zpdkLYojiw" body="self.allInstances()->isUnique(p |
p.id)" language="OCL" />
> </ownedRule>
> <ownedAttribute xmi:id="_hl1PtsjwEdu-zpdkLYojiw" name="id">
> <eAnnotations xmi:id="_hl1Pt8jwEdu-zpdkLYojiw"
> <contents xmi:type="Ecore_0:Ecore__EAttribute"
xmi:id="_hl1PuMjwEdu-zpdkLYojiw" isID="true" />
> </eAnnotations>
> <type xmi:type="uml:PrimitiveType"
href=" pathmap://UML2_LIBRARIES/EcorePrimitiveTypes.library.uml2#_O RTUYa86Edi
eaYgxtVWN8Q" />
> </ownedAttribute>
> </ownedMember>
> </uml:Model>
Re: Applied Profile & ArrayStoreException [message #471363 is a reply to message #471362] |
Wed, 07 March 2007 15:47   |
James,
It turns out that the source of this problem is in EMF - a bug was
introduced when the Ecore2XML metamodel was updated based on generics.
Steffen, please open a bug against EMF and I'll fix it ASAP.
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:esn5qr$ati$2@utils.eclipse.org...
> for
> all
> of
> care of shortly.
> Regards,
> how they got there.
> - James.
>> > Steffen,
>> > investigate?
>> > Kenn
>> Cheers,
>> Steffen
>> <?xml version="1.0" encoding="UTF-8"?>
>> </eAnnotations>
>> </eAnnotations>
>> <importedProfile
>> </packageImport>
>> </eAnnotations>
> Q0g" />
>> <importedProfile
> Q0g" />
>> </packageImport>
>> </eAnnotations>
>> <importedProfile
>> </packageImport>
> aYgxtVWN8Q" />
>> </packageImport>
>> </eAnnotations>
>> <importedProfile
>> </packageImport>
> (GUID.emx).
Identifier
>> </ownedRule>
>> </eAnnotations>
> eaYgxtVWN8Q" />
>> </ownedAttribute>
>> </ownedMember>
>> </uml:Model>
Re: Applied Profile & ArrayStoreException [message #471622 is a reply to message #471621] |
Wed, 07 March 2007 16:05  |
Steffen,
I've retargeted the bug against EMF and committed the fix, which should be
available in Thursday's integration build.
Kenn
news:esn8jq$m9m$1@utils.eclipse.org...
>> care of shortly.
> Done, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=176645
>> sure
>> how they got there.
> I also don't know how they got there. It has sth. to do with the encoding,
> in TextPad there are gone but in other editors I see them, too.
> Thanks for investigating the issue,
> Steffen
Re: Applied Profile & ArrayStoreException [message #598285 is a reply to message #471354] |
Tue, 06 March 2007 17:22  |
Steffen,
investigate?
Kenn
news:eskoen$j8q$1@utils.eclipse.org...
> do? Is it a bug?
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 77 more
Re: Applied Profile & ArrayStoreException [message #598291 is a reply to message #471355] |
Wed, 07 March 2007 01:10  |
--------------000703060106050700020305
> Steffen,
> investigate?
> Kenn
Steffen
name="identifier.uml2"
Content-Disposition: inline;
filename="identifier.uml2"
<uml:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:Ecore_0="http:///Ecore_0.profile.uml2" xmlns:uml="http://www.eclipse.org/uml2/1.0.0/UML" xsi:schemaLocation="http:///Ecore_0.profile.uml2 pathmap://UML2_PROFILES/Ecore.profile.uml2#_v9VUsK87Edi5QpYe Y_yIpg" xmi:id="_hl1PocjwEdu-zpdkLYojiw" name="identifier" appliedProfile="_hl1PpcjwEdu-zpdkLYojiw _hl1PqMjwEdu-zpdkLYojiw _hl1Pq8jwEdu-zpdkLYojiw _hl1Pr8jwEdu-zpdkLYojiw">
<eAnnotations xmi:id="_hl1PosjwEdu-zpdkLYojiw" source="http://www.eclipse.org/emf/2002/Ecore" />
<eAnnotations xmi:id="_hl1Po8jwEdu-zpdkLYojiw" source="appliedStereotypes">
<contents xmi:type="Ecore_0:Ecore__EPackage" xmi:id="_hl1PpMjwEdu-zpdkLYojiw" nsPrefix="identifier" nsURI="http://sdq.ipd.uka.de/Identifier/1.0" basePackage="de.uka.ipd.sdq" />
</eAnnotations>
<packageImport xmi:type="uml:ProfileApplication" xmi:id="_hl1PpcjwEdu-zpdkLYojiw">
</eAnnotations>
<importedPackage xmi:type="uml:Profile" href=" pathmap://UML2_PROFILES/Basic.profile.uml2#_6mFRgK86Edih9-GG 5afQ0g" />
<importedProfile href=" pathmap://UML2_PROFILES/Basic.profile.uml2#_6mFRgK86Edih9-GG 5afQ0g" />
</packageImport>
<packageImport xmi:type="uml:ProfileApplication" xmi:id="_hl1PqMjwEdu-zpdkLYojiw">
</eAnnotations>
<importedPackage xmi:type="uml:Profile" href=" pathmap://UML2_PROFILES/Intermediate.profile.uml2#_Cz7csK87E dih9-GG5afQ0g" />
<importedProfile href=" pathmap://UML2_PROFILES/Intermediate.profile.uml2#_Cz7csK87E dih9-GG5afQ0g" />
</packageImport>
<packageImport xmi:type="uml:ProfileApplication" xmi:id="_hl1Pq8jwEdu-zpdkLYojiw">
</eAnnotations>
<importedPackage xmi:type="uml:Profile" href=" pathmap://UML2_PROFILES/Complete.profile.uml2#_M7pTkK87Edih9 -GG5afQ0g" />
<importedProfile href=" pathmap://UML2_PROFILES/Complete.profile.uml2#_M7pTkK87Edih9 -GG5afQ0g" />
</packageImport>
<importedPackage xmi:type="uml:Model" href=" pathmap://UML2_LIBRARIES/UML2PrimitiveTypes.library.uml2#_Ef RZoK86EdieaYgxtVWN8Q" />
</packageImport>
<packageImport xmi:type="uml:ProfileApplication" xmi:id="_hl1Pr8jwEdu-zpdkLYojiw">
</eAnnotations>
<importedPackage xmi:type="uml:Profile" href=" pathmap://UML2_PROFILES/Ecore.profile.uml2#_siPt4K87Edi5QpYe Y_yIpg" />
<importedProfile href=" pathmap://UML2_PROFILES/Ecore.profile.uml2#_siPt4K87Edi5QpYe Y_yIpg" />
</packageImport>
<ownedMember xmi:type="uml:Class" xmi:id="_hl1PssjwEdu-zpdkLYojiw" name="Identifier" isAbstract="true">
<ownedComment xmi:id="_hl1Ps8jwEdu-zpdkLYojiw" body="Identifiers are not fixed to one realization.
GUIDs are recommend. GUIDs are described in their own model. See GUIDModel (GUID.emx).
Identifier implementations can be found in external projects only." annotatedElement="_hl1PssjwEdu-zpdkLYojiw" />
<ownedRule xmi:id="_hl1PtMjwEdu-zpdkLYojiw" name="idHasToBeUnique" constrainedElement="_hl1PssjwEdu-zpdkLYojiw">
<specification xmi:type="uml:OpaqueExpression" xmi:id="_hl1PtcjwEdu-zpdkLYojiw" body="self.allInstances()->isUnique(p | p.id)" language="OCL" />
</ownedRule>
<eAnnotations xmi:id="_hl1Pt8jwEdu-zpdkLYojiw" source="appliedStereotypes">
<contents xmi:type="Ecore_0:Ecore__EAttribute" xmi:id="_hl1PuMjwEdu-zpdkLYojiw" isID="true" />
</eAnnotations>
<type xmi:type="uml:PrimitiveType" href=" pathmap://UML2_LIBRARIES/EcorePrimitiveTypes.library.uml2#_O RTUYa86EdieaYgxtVWN8Q" />
</ownedAttribute>
</ownedMember>
</uml:Model>
--------------000703060106050700020305--
Re: Applied Profile & ArrayStoreException [message #598331 is a reply to message #471356] |
care of shortly.
how they got there.
- James.
> > Steffen,
> > investigate?
> > Kenn
> Cheers,
> Steffen
> </eAnnotations>
> </eAnnotations>
> <importedProfile
> </packageImport>
> </eAnnotations>
Q0g" />
> <importedProfile
Q0g" />
> </packageImport>
> </eAnnotations>
> <importedProfile
> </packageImport>
aYgxtVWN8Q" />
> </packageImport>
> </eAnnotations>
> <importedProfile
> </packageImport>
Identifier
> </ownedRule>
> </eAnnotations>
eaYgxtVWN8Q" />
> </ownedAttribute>
> </ownedMember>
> </uml:Model>
Re: Applied Profile & ArrayStoreException [message #598339 is a reply to message #471362] |
James,
Kenn
> for
> all
> of
> care of shortly.
> Regards,
> how they got there.
> - James.
>> > Steffen,
>> > investigate?
>> > Kenn
>> Cheers,
>> Steffen
>> </eAnnotations>
>> </eAnnotations>
>> <importedProfile
>> </packageImport>
>> </eAnnotations>
> Q0g" />
>> <importedProfile
> Q0g" />
>> </packageImport>
>> </eAnnotations>
>> <importedProfile
>> </packageImport>
> aYgxtVWN8Q" />
>> </packageImport>
>> </eAnnotations>
>> <importedProfile
>> </packageImport>
> (GUID.emx).
Identifier
>> </ownedRule>
>> </eAnnotations>
> eaYgxtVWN8Q" />
>> </ownedAttribute>
>> </ownedMember>
>> </uml:Model>
Re: Applied Profile & ArrayStoreException [message #598344 is a reply to message #471362] |
Wed, 07 March 2007 15:51  |
> care of shortly.
> how they got there.
encoding, in TextPad there are gone but in other editors I see them, too.
Steffen
Re: Applied Profile & ArrayStoreException [message #598354 is a reply to message #471621] |
Steffen,
Kenn
>> care of shortly.
>> sure
>> how they got there.
> Steffen
Current Time: Wed Jul 23 23:04:05 EDT 2025
Powered by FUDForum. Page generated in 0.06073 seconds
