Home » Modeling » UML2 » Ecore for Sequence diagram
Ecore for Sequence diagram [message #471188] Thu, 01 March 2007 16:35 Go to next message
Originally posted by: liang.cs.queensu.ca
Is there an Ecore metamodel for UML2 Sequence diagram available?
What I want to do is to transform SDs in XMI to another XMI based on a
predefined Ecore metamodel, say X. In order to make the transformation work,
I need to specifiy the mappings between elements in both metamodels SD and
X. So, if there is Ecore for UML2 SD already available, then I don't have to
manually create an Ecore for SD from scratch.
Thank you.
Re: Ecore for Sequence diagram [message #471343 is a reply to message #471188] Fri, 02 March 2007 09:20 Go to previous messageGo to next message
Hongzhi,
The Ecore representation of UML can be found at
org.eclipse.uml2.uml/model/UML.ecore.
Kenn
"Hongzhi Liang" <liang@cs.queensu.ca> wrote in message
news:es7h0k$j02$1@utils.eclipse.org...
> Hello,
> work, I need to specifiy the mappings between elements in both metamodels
> SD and X. So, if there is Ecore for UML2 SD already available, then I
> don't have to manually create an Ecore for SD from scratch.
> Thank you.
Re: Ecore for Sequence diagram [message #471352 is a reply to message #471343] Mon, 05 March 2007 16:04 Go to previous message
Thank you Kenn.
"Kenn Hussey" <khussey@ca.ibm.com> wrote in message
news:es9br9$hta$1@utils.eclipse.org...
> Hongzhi,
> Kenn
>> Hello,
>> Thank you.
Re: Ecore for Sequence diagram [message #594089 is a reply to message #471188] Fri, 02 March 2007 09:20 Go to previous message
Hongzhi,
Kenn
> Hello,
> Thank you.
Re: Ecore for Sequence diagram [message #598266 is a reply to message #471343] Mon, 05 March 2007 16:04 Go to previous message
Thank you Kenn.
> Hongzhi,
> Kenn
>> Hello,
>> Thank you.
Previous Topic:UML Profile for extended metadata
Next Topic:Applied Profile & ArrayStoreException
Current Time: Fri Jul 25 21:52:59 EDT 2025
Powered by FUDForum. Page generated in 0.04357 seconds
